Question about Acer Aspire 3680 Laptop
Replacing acer aspire dc jack
I have dissassemble the computer all the way and i have easy access to the dc jack, i have a new one ready for the replacement but i cannot get the old one out :(
I dont want to force it out and ruin the computer...can you tell me how to get it out?
  • 56 Answers
You just heat the connecting point of the circut boar with a soldering iron:), its pretty easy i did it on a compaq armada m700:)
Posted on Jan 03, 2009
Instrutions how to replace charging port aspire 6935g
Replacing a DC Power jack in any computer is no easy task. However, it can be done by any novice. First, get on ebay and see what jack you need. Search for you jack by entering Acer Aspire 6935g jack. Most of the new ones have the cable attached to the jack instead of the old fashion solder.
Next, Google this question and check out the YouTube videos regarding Acer DC Jack replacement. It will give you an idea as to what you need to do. You may want to take a video camera and record what steps you take when you take it apart so you can review how to put it back together. Also, get a sewing box or something so you can put the screws in a separate container for the order you removed them; ie: bottom screws; hard drive screws, DVD mount screw... etc..
You always have to start with the bottom and work your way to the top. You will have to remove the palm rest, keyboard, heat shields and any other piece of hardware to get to it.
YouTube is your friend...
Aug 16, 2014 | Acer Aspire Computers & Internet
How to replace the DC Power jack of my acer aspire 7735Z
Replacing a DC Power jack in any computer is no easy task. However, it can be done by any novice. First, get on ebay and see what jack you need. Search for you jack by entering Acer Aspire 7735z jack. Most of the new ones have the cable attached to the jack instead of the old fashion solder.
Aug 12, 2014 | Acer Laptop DC Power Jack for Acer...
Acer 5610 charging difficulty
Yes! the DC jack will probably need to be resolded, and I would recommend replacing the power adapter because it may fix your problem, I find the universal supplies don't fit as tight as the original ones. www.ebay.com is a good place to start for power supply replacement.
Mar 30, 2012 | Acer Aspire 5600 Series 5610-2013 Notebook
Does this computer have a dc power jack plug or cable
Acer Aspire One D250 AOD250 has cabled dc jack, do not need to solder, plug in and your laptop will work, view this page for reference: http://www.lapdiy.com/acer-aspire-one-d250-aod250-wire-harness-power-jack-dc-in-cable-p-26502.html
hope this can help you!
Dec 27, 2011 | Acer Laptop DC Power Jack for Acer Aspire...
DC jack for aspire 8943g
Just go to any electronic shop and bring the sample jack, surely they have one for you.
Hope that helps!
Nov 23, 2011 | Acer Aspire Ethos 8943G-5464G50Bnss...
I reset my surge protector and the computer wont power up. i think i need a new power supply. the power cord is working fine. Please let me know where i can find a power supply for the aspire...
The Acer Aspire L100 is a desktop computer powered by a special DC adapter and power cable. The computer's motherboard incorporates a fuse designed to prevent any power surges from damaging the computer. If the fuse burns out due to a power surge or for any other reason, the computer will no longer function. You can check the motherboard fuse for damage yourself, then take it to a trained technician for replacement if needed
Shut down the Acer Aspire L100 and turn the tower around.
Press the "On/Off" button on the front of the tower. If the computer will not boot and the fan does not turn on, the fuse may be burned out.
Unplug the power cord from the rear of the tower
Turn the tower on its side and remove the Phillips-head screws connecting the back panel to the Aspire L100's cabinet.
Pull out the motherboard assembly gently from the back of the cabinet. The internal fuse is located on the motherboard behind the DC power jack, which is to the right of the monitor jack
Let me know if this helped..
  • 2 Press the "On/Off" button on the front of the tower. If the computer will not boot and the fan does not turn on, the fuse may be burned out.
  • 3 Unplug the power cord from the rear of the tower.
  • 4 Turn the tower on its side and remove the Phillips-head screws connecting the back panel to the Aspire L100's cabinet.
  • 5 Pull out the motherboard assembly gently from the back of the cabinet. The internal fuse is located on the motherboard behind the DC power jack, which is to the right of the monitor jack.
  • Read more: Fuse Location on Acer Aspire L100 ' eHow.co.uk http://www.ehow.co.uk/how_7815704_fuse-location-acer-aspire-l100.html#ixzz1XUVwmxuA
    Sep 09, 2011 | Acer Aspire L100 PC Desktop
    No power at all, tried a new charger still no power and replaced the battery.
    Hi
    After the battery and AC cord replacement and still not getting power there's only once culprit there and that is the motherboard of the laptop. I recommend you call Acer and have them replace it for you. Thanks
    Feb 21, 2011 | Acer Laptop DC Power Jack for Acer Aspire...
    What is a dc jack and what is the price . For a acer net book. my home page is small how to make it large .
    First thing...when you have a browser window open holding the CTRL key down and tapping the + or - keys will enlarge or shrink the font.
    The dc jack is the port on the side or back of the computer that the power adapter fits into, the adapter receives AC current from the wall outlet, iy goes into the power adapter "Brick" and is converted to DC current to the correct voltage for your particular laptop. The dc jack is either a direct solder onto the motherboard (main board) inside the computer or it is connected to the main board by a cable. The direct solder piece cost a few dollars but has to be replaced professionally with the correct equipment. The cable type can be done by the home user with the right manual and dissassembly instructions. I have included a link below for the service manual of that laptop. Good luck, ParrotHead PC Repair
    copy and paste the link below in your internet browsers address bar and hit enter. Remember, if you need to make the text etc. bigger....CTRL / +
    http://tim.id.au/laptops/acer/aspire%20one.pdf
    Sep 06, 2009 | Acer Aspire One Netbook 8.9" Notebook
    DC input jack broken
    you need to buy a new jack for replacement. then solder the broken one out of the mainboard and clean the place and solder the new one. or some acer have a separet jack then that one is easy only to change.
    Dec 25, 2008 | Acer Aspire 5500 5570-2609 Laptop
    DC power input center pin is gone
    Part costs about $ 5-10 bucks.....labor to fix it ranges from $ 100 - $250. Problem is caused by jerking or tugging on the power cable too much. All laptops need a Cable Retention Device like the one in this video. . .
    Jan 05, 2008 | Acer Aspire 3610 Notebook
    Acer Aspire 3680 Laptop Logo
    87 people viewed this question
    Mohammed Ebrahim M
    Mohammed Ebrahim M
    Alun Cox
