Question about White Sewing Sewing Machines
White sewing machine 954 bobbin - White Sewing Sewing Machines
  • 27 Answers
SOURCE: Brother Sewing Machine model:CS8150 bobbin thread problems
The top of the machine is not threaded correctly. First raise the presserfot then rethread the machine. Bottom looping is usually caused by a lack of top tension. There could allso be a bur on the hook.
Posted on Feb 23, 2008
SOURCE: need help making a bobbin...
Ahah! I was having a similar problem, but figured it out. What you do is you first put the spool of thread you want on the bobbin in its normal place, just as if you were sewing. Then you take the end of the thread and wrap it around the metal button-looking thing on the top of the metal string catcher on top of the machine. Wrap it around once in a figure eight sort of pattern (or kinda like a Jesus-fish symbol). Then you take the end and put it through one of the holes on the bobbin. Make sure there's enough so that it won't slide out, because it will wind at sewing speed. Now, you take the bobbin and put it on the metal post on the right-hand side of the machine, the one in front next to the white plastic round with a screw in the middle. It should fit on tightly.
Now, here's the part that took me forever: on most machines I've encountered, there's a switch somewhere that tells the machine to wind the bobbin. On the White Fashionaire 2380 that switch is the bobbin-holder itself (the metal post it is on right now!). Push the post, bobbin and all, towards the white plastic thing (sorry, but it's late and proper teminology eludes me). It should click over, and your thread should be going from the spool, around the metal button (in a figure eight fashion) and should be threaded through one of the holes in the bobbin. Now you hold the end of the thread and press the pedal, and after a short while the thread will be pulled out of your hand (or possibly not, if it's long enough). Keep going until you have enough thread on the bobbin, and cut it loose! You're done!
Posted on Aug 20, 2008
  • 47 Answers
SOURCE: How to Thread the bobbin on my sewing machine
Visit us at www.ifixmachine.com to avail for a new manual for only $10.00
Posted on Jul 24, 2009
bargainbox
  • 1388 Answers
SOURCE: For the White Mighty Mender W100 sewing machine,
Same as with all machines essentially.......
Check the timing of the needle to the hook.
Here is a guide to generic principles of Timing
Posted on Aug 30, 2009
SOURCE: machine does not sew- it does not catch the thread from bobbin
The timing mechanism is likely off. Take off the plastic bobbin case and see if the eye of the needle, on its way up, is just below the metal hook that catch the thread. If not,open the bottom cover with a flat screwdriver, loosen the two 2 mm hex screws, push out and disengage the gears. Adj the hook position by turning left or right so that it is right above the eye of the needle when the needle is on its way up. Tighten the hexes. I also give my machine a good old job with a high grade geese on the gears and light old drop on all moving parts before I close the cover.
Have fun.
Posted on Jan 01, 2010
I need help with a white sewing machine model 765 I can't get it to sew it doesn't pick up the bobbin thread
First thing to try is a brand new needle. A bent/damaged needle may not be able to pick up the bobbin thread.
Otherwise, it is possible it has a timing issue, ie the needle is arriving at the bobbin at the wrong time in order to connect with the bobbin thread. Search the internet web sites and videos. There is a lot of information on how to fix sewing machine timing. Or take it for service.
Jul 11, 2016 | White Sewing Sewing Machines
What size bobbin for White 915?
On sewing machines with the removable metal bobbin case the bobbin size will be a class 15, very common and inexpensive.
Dec 10, 2015 | White Sewing 915
White bobbin
try a1sewingmachines.com and see if they can help about the bobbins
Oct 29, 2013 | White Sewing 1730 Mechanical Sewing...
I have a Simplicity SE3 machine and I can not fine bobbins for this machine. Where can they be purchased?
The Simplicity SE3 bobbins are used for several other machines. The metal version of the bobbin is available here: http://www.mysewingmachineparts.com/top-quality-metal-sewing-machine-bobbins-125701-001-baby-lock-bernina-brother-riccar-simplicity-white/ . These are 10 for $6. There is a plastic version that's a bit cheaper: http://www.mysewingmachineparts.com/top-quality-plastic-sewing-machine-bobbins-136492-001-baby-lock-bernina-brother-riccar-simplicity-white/ . These two links include both other machines that use the bobbin and alternative part numbers to locate them from other vendors.
If you ask at a local sewing machine store for the Brother PE100 or BabyLock BL2100 bobbins, they should be able to help you find them.
I hope this helps.
Apr 17, 2013 | Simplicity SE3 Computerized Sewing Machine
Do not know what size prewound bobbin i need to buy for a white 3300 embroidery machine
try this link, sewing parts on line says this is the bobbin for your machine, compatible with some Whites and Husquvarna Viking machines.
http://www.sewingpartsonline.com/bobbins-viking-white-10-pack-4120612-45.aspx
Genuine Part #412 06 12-45 or alternate code is 11770P
Jun 06, 2011 | White Sewing W3300 Computerized Sewing...
I got a White 3032 sewing machine for Christmas last year and I couldn't get the bobbin to thread, I exchanged it and the new one does the same thing. Why won't it pick up the bobbin thread?
Have you got the bobbin in the right way ? Is the bobbin thread in tension? Turn flywheel towards you while holding the tail of the top thread, turn through one rotation so needle goes down into rotary hook then up again to top position. Now pull thread tail and bobbin thread should come up through needle plate in a loop. Draw the rest of bobbin tail up to top. Can you get a lesson from sm retailer? They should give you a basic demo at least. Consider buying a reference book on the sewing machine such as singer sewing machine book or similar. Sewing is a skill best learnt in classes if you can.
Apr 16, 2011 | White Sewing White 3032
I have a WHITE 3300 EMBROIDERY MACHINE and the thread bunches up at the bobbin site. I have tried a new needle, adjusted upper thread tension , changed bobbin threads and nothing helps, it keeps bunching...
Refer to your machine for cleaning the bobbin area.
You will need to clean this area often as lint and thread snips can build up can cause the bobbin feed to malfunction.
If this continues after you have cleaned the machine, the timing may need to be adjusted by a sewing machine tech.
Mar 18, 2010 | White Sewing W3300 Computerized Sewing...
How do you oil a white sewing machine model 954?
Oil any and all moving parts you have access to. Make sure you use sewing machine oil.
Feb 22, 2010 | Sewing Machines
Need instruction manuel for white sewing machine model 954
Visit us at www.janomestuff.com to avail for a new manual for only $10.00
Feb 18, 2009 | White Sewing Sewing Machines
Replacement Sewing Machine Bobbin Case
Hi Jo,
Is there a way for you to email me a digital picture of your old bobbin case? I guarantee you we have one for your machine I just need to know what yours looks like!
- Jeremy
http://sewingpartsonline.com
Feb 11, 2009 | White Sewing 1418 Mechanical Sewing...
Sewing Machines Logo
Top White Sewing Sewing Machines Experts
Tally Girl
Tally Girl
tsalagi152
Are you a White Sewing Sewing Machine Expert? Answer questions, earn points and help others
