Question about Ingersoll Air Tools & Compressors
Ingersol rand ssr 50-100 Hp 37-75 Kw manual - Ingersoll Air Tools & Compressors
  • 89 Answers
SOURCE: Cant set my compressor to automatic start/stop mode
U NEED TO ADJUST THE PRESSURE SWITCH ON THE BACKUP TO A LOWER PSI. TO COME ON AFTER THE PRIMARY. EXAMPLE: PRESSURE SWITCH ON PRIMARY COMP. SET AT 140-175 PSI AND BACKUP SET AT 135-170 PSI. U CAN USUALLY TURN ONE CENTER SCREW IN THE PRESSURE SWITCH COUNTERCLOCKWISE TO LOWER THE PSI.
Posted on Dec 27, 2008
  • 1388 Answers
SOURCE: manual
Ingersoll rand parts and manuals are available at www.grainger.com, or call you local grainger store, they have a very good customer service for faxing parts lists to your place. Notice: some Ingersoll rand compressors have been recalled. Check the address below. If you have general questons about a problem that you are having, post again. Good Luck
http://www.cpsc.gov/cpscpub/prerel/prhtml02/02108.html
Posted on Jan 10, 2009
SOURCE: Ingersoll Rand SSR-EP75 owners manual, I need to
The pulley is held on by a compression type of coupling. Loosen all the screws in the coupling. Remove two screws and they should thread into two or more threaded holes in the coupling. These are holes that should be 180 degrees apart....they will be the only holes threaded. If all the other bolts in the circumference are loose you should be able to thread these two bolts into the coupling and the bolts actually "jack" the coupling apart. The coupling and fan should easily come off the front of the motor. The motor should be held on by 4 screws to the motor tower in front of your air/oil cooler.
Posted on Sep 04, 2009
Testimonial: "Although the information is way late, it is accurate information"
SOURCE: ingersoll Rand SSR compressor shuts down loaded or
When it shuts down, press DISPLAY SELECT button once and use the up down arrows to see the code just before shutdown.
HIGH AIREND TEMP
HIGH AIR PRESSURE
LOW SUMP PRESSURE
PRESSURE OR TEMP SENSOR FAIL
CHECK MOTOR ROTATION
MOTOR OVERLOAD
FAN MOTOR OVERLOAD
STARTER FAULT
I am assuming this has a Intellisys controller.
Posted on Sep 25, 2009
compman66
  • 169 Answers
SOURCE: what type of oil for ingersoll rand model 2475 air
Ingersoll Rand likes you to buy their all season select oil for their air compressors, most piston air compressors use an R+O 100 oil it is equivalent to n SAE 30 wt oil.
Posted on May 12, 2010
How to change from BAR to PSI on INGERSOLL RAND INTELLISYS CONTROL for INGERSOLL RAND SSR-6-20-125 AIR COMPRESSOR
Ingersolll Rand website support section should be able to provide a manual.
Failing that contact customer services.
Aug 03, 2016 | Ingersoll Rand Air Tools & Compressors
What does alarm start fault mean on the control panel on a ingersoll rand ssr ep-30 air compressor
I use to start up a 25 HP Ingersol screw type compressor. The only alarms I got were from power spikes which just needed the reset button to be pushed, then the on button - and the low oil sensor would shut it down and give an alarm when the tank was about half way down. They will blow up with no oil so there is a saftey margin on oil level.
Mar 28, 2011 | Ingersoll Rand Stationary Air Cooled...
Air Tools & Compressors Logo
153 people viewed this question
Top Ingersoll Air Tools & Compressors Experts
elunsford
John Trevino
Joe Garcia
Joe Garcia
Are you an Ingersoll Air Tool and Compressor Expert? Answer questions, earn points and help others
