Question about ASUS WL-330N3G 6-in-1 Wireless-N Mobile Router
Can't connect my asus wl-330n3g router to my imac
Can't in stall on my imac
alex8642
  • 21 Answers
SOURCE: Limited or No Connectivity
are you running windows xp or vista? if so make sure that your DHCP service is running, and also make sure your IP address is configured to "obtain automatically" if your router is configured to do just that. Otherwise I would say: 1 - upgrade firmware 2 - make sure everything is configured correctly on router and pc (I suggest making same as other computers connected) 3 - uninstall and reinstall your network adapter or install newer drivers for network adapter. 4 - your router is bogged down due to the fact there is more than one computer connecting to it. It may not be built to work well with more than 1 pc, even though it is capable. 5 - your router is not within good strength connection of your pc. - i can help you more if you give me more information and try the things listed above. but be careful when screwing around on the router settings, you could click something causing everything to stop working.
Posted on Jun 19, 2007
  • 67 Answers
SOURCE: Connecting 2 routers (ASUS WL-500W and D-Link DSL-G604T Wireless)
This will give you a "Double NAT" setup. Meaning, Your D-Link router is connected to the external internet address assigned to you by your internet service provider. More than likely this is a DHCP address you do not control. Your D-Link router is then translating the address to the 192.168.1.x network. This is the first NAT translation. You are then connecting the ASUS router to DLINK, causing a second NAT translation. (Internet ADSL --> D-Link WAN Port --> D-Link Lan Port --> ASUS WAN Port --> ASUS Lan Port to computer/server/etc. ) If both of your routers are giving out DHCP addresses, then this is all that is required.
Posted on Dec 10, 2008
SOURCE: I am not able to properly set up my network with an ASUS Wl-500B
Both routers need to be on the same IP scheme and subnet i.e. 192.168.0.X subnet 255.255.255.0. First, unplug the Asus router. Next, make sure you have connection to the internet by hooking directly to the Apple router. Once you've established a connection to the internet plug the Asus router into the Apple router but go LAN port to LAN port.
Posted on Mar 23, 2009
hcsr
  • 65 Answers
SOURCE: Asus WL 520gu can't connect internet
1, connect your wireless router with cable to your laptop,
2. Login into your Asus-WL520gu and setup your wireless how you want it to run." do not bother with putting your username settings in there"
3. In your Asus-WL-520gu after setting up your wireless turn the DHCP off in it.
4. Now connect the cable that you have connected to your laptop to your router instead of your laptop.
""You should now be able to connect to the wireless with your settings. and connect anything ells you want to the other 4 ports on the back of you wireless router"" note: do not connect anything to the WAN port as it is used for DSL modems; and not Routers with ADSL modem.
when connecting a router to a router - the one that is connecting you to the internet needs DHCP turned on because it is the one that will be giving you IPs and Gateway settings - the other router such as wireless router after setting it up needs its DHCP turned off - other wise you will have 2 routers trying to do the same thing with ip's and gateways. And you should never connect a modem router to the WAN port as it is a modem router and NOT just a DSL-modem. The WAN port is intended for DSL-modems only. Not only consumers but also many technicians make that mistake
Posted on Aug 23, 2009
govinda123
  • 2260 Answers
SOURCE: ASUS WL-500W - no connection unless the router is reset
I think when you shut down all the computers , the connection between the modem and the router might be dropping.
You can try to upgrade the firmware of the router.
Click Here for more info
Posted on Oct 28, 2009
I do not want wireless router to assign ip addresses for lan
not sure if you are doing it right
your wireless router has 2 "sides" one is it's upload, it's wan network and that is where you should set DHCP - so that the router itself gets an ip from your LAN
other side is behind your wireless router and there DHCP should also be off. it would be best if you could put your router in bridged mode - just to extend your network over WIFI
Mar 08, 2012 | ASUS WL-500g Wireless-G Router + WL-100gE...
I use WL-330N3g to be a hotspot. My ipod connected, but can't surf internet. Is it somethimg wrong ?
Yes, sounds like it.
Firstly I would try resetting the router.
Also make sure the internet works on other devices.
Jul 22, 2011 | ASUS Computers & Internet
Can 't connect to the internet with my ASUS wl-167g I have an ASUS wl-167g wireless usb adapter on my Win7 Home Premium PC, with the latest ralink drivers. I can perfectly detect the wireless network my...
You need to enter the wireless key from your router once before the adapter will connect. The key is either on the label on the router or in the wireless section of the router.
May 04, 2017 | ASUS (WL-167G) 802.11g/b (wl167g) Wireless...
Mar 23, 2009 | ASUS WL-500B Wireless Router
Cannot through ASUS WL-530G connect to internet
I've settle my problem. Set the correct VPI and VCI provided by ISP.
Nov 12, 2008 | ASUS WL-530g Router
Want to change password on router for extra security
My asus wl520 g router always reboot. Anyone have same problem?
Apr 06, 2008 | ASUS WIRELESS ROUTER |WL-520G - RT...
ASUS WL-500W not connected to the internet
how your ADSL internet service provider, lock connection from any his machine ? Or your ISP dont provider for IP ADDRESS for DHCP or your ASUS dont set up get IP from DHCP.
Check this information.
Good Luck!
Mar 27, 2008 | ASUS WL-500W Router (WL500W)
Asus WL 530g Router
If you press and hold the reset button on the router for about 30-45 seconds, it should reset all settings on the unit. Generally by default there is no security enabled so you will need to set this up if you want to secure your connection.
Feb 10, 2008 | ASUS WL-530g Router
WL 520 GC can only acess net in "default" before encrypting
To enable WEP encryption requires configuration changes in two places the router (WL-520G) and for the network adapter on the associated with the computer expecting to use the wireless router. Do you both believe you made the appropriate changes to both devices required? The router and the computer
Another possible issue is either the router or the network adapter do not support WEP meaning the option is not possible at all.
Oct 24, 2007 | ASUS WIRELESS ROUTER |WL-520G - RT...
ASUS WL-330N3G 6-in-1 Wireless-N Mobile Router Logo
37 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
