Question about Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator
Kenmore elite 106.5778 700 ice wont despence
(ice bin on door) i removed the bin from door & the auger moves fine.
when you push the swicth you here a slight groan like its going to engage but nothing happens
  • 2 more comments
  • nursedolittl Jan 04, 2009
    I have the Kenmore Coldspot Elite 5779. It makes ice just fine, but won't dispense it. It does groan for a second then stops. Have taken the ice bin out and unloaded all the ice and cleared it out, still have problem. Would hate to make a service call if it's something easy to fix.
  • bhumphrey_46 Jan 06, 2009
    i have taken the bin out and removed the ice and the auger moves freely. I also opened freezer door and depressed the inside door switch and then pressed ice despence to see if the motor would turn. It still makes the same noise like its going to work but does not
  • toiron Jan 21, 2009
    106.5778 / 106.5778700 will not dispense ice. The groan I hear is the ice door opening, but the dispenser motor is not turning. 11/2 years old.
  • neilellis May 11, 2010
    Have you removed the bin long enough to totally de-ice it?
  • 1073 Answers
SOURCE: Ice despencer and light kills
what is the model number
Posted on Apr 24, 2008
huuum
  • 750 Answers
SOURCE: kenmore elite, will not make ice, but it does dispeanse
Dear tnsmarchini
You said, Kenmore elite, ice maker in door...........................???What????????
And we need more detail than Ice maker in door.
What does your ice maker do?
Posted on Sep 27, 2008
  • 14 Answers
SOURCE: Replacing the Ice dispenser motor on Kenmore elite refrigerator?
There is a small door under neath ice maker shelf (literally) w/ 2 small screws that keep it in place,or a button that can release ice maker on the rt. side of machine. Good luck!!
Posted on Apr 04, 2009
buddymcl777
  • 67 Answers
SOURCE: freezer door not sealing
replace the seals and / or have the hinge adjusted
Posted on May 01, 2009
  • 6 Answers
SOURCE: how do I access the ice auger motor on a kenmore
I am not sure who made your kenmore i need a model no
Posted on Aug 30, 2009
Ice maker auger not moving ice when you press glass under
Remove the ice container and look in the slots or grooves where the container rests. You should find a build up of frost that is elevating the container slightly. When it is raised just a bit, the auger drive fails to engage adequately into the dispenser auger.
Use a hair dryer and a dry towel to sop up the frost melted with the hair dryer. Be careful not to use 'high' heat position as you could warp the plastic of the compartment.
Good Luck !!!
Feb 19, 2015 | GE Refrigerators
Kenmore elite 106.5770 ice auger motor is out. Flaps move, microswitch seems fine. Ice bucket already pulled and cleared. Ice maker works fine. Still no action from auger motor...how do I get at it? ...
This is probably one of the best videos I have ever found on replacing auger motors...at least how to access them in Kenmore units. I hope this helps you with your issue.
Nov 28, 2017 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore model number 253.55693400 when I push the ice dispenser tab the motor to push ice is on, but not pushing ice out.
You have an auger type of ice dispenser, so when you say you hear the motor is on, do you mean it is turning the auger? Take out the ice bin and close the door, push the dispense button and then open the door quickly to see if the auger is turning. If is is then dump your ice bin and let it sit out until it is completely defrosted and dry. Reinstall the ice bin and put the lever down. And see if that will clear the problem. The auger motor is not that strong and if you get any ice build up under the auger it will stop working. So defrosting and drying will normally clear it up.
Oct 02, 2011 | Kenmore Side by Side Refrigerator
Everything works fine for this refrigerator except that when you press ICE on the control panel and insert your glass into the discharge area, the ice maker paddle (auger) does not turn to extract ice from...
Does the auger sound like it is turning ? If it sounds like it is turning there maybe a drive gear that is missing drive teeth or a shear pin has sheared preventing the auger from turning and despencing the ice
Dec 28, 2010 | Refrigerators
I have a Kenmore side by side, not sure the model, but it's probably 10 years old or so. It has an ice maker with water, cube and crushed ice dispenser. The ice maker works fine, but it will not dispense...
Most of the time the bin has been removed and not put back in properly. When this happens ice blocks the drive motor. Remove the bin and turn the auger by hand make sure it will turn and is not jammed. Now with the bin out push the light button in that turns the light out and have someone push the button for ice while the door is still open the motor should turn in the back make sure thereis no ice blocking it. If it turns nothing is wrong with the motor. The clicking sound is usually the motor jammed by ice or the auger not engaged on the motor. hope this helps good luck
Aug 15, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Ice auger not working
normally someone has removed the bin to empty the ice or it was pulled out a little by accident. Try removing the bin and make sure that no ice is jaming the auger motor try turning the auger by hand. Hold down on the door switch and have someone push the demand buttom for ice and see if the motor turns. If it does reinstall bin. If it doesnt make sure ice has not blocked it. reinstall bin and try the ice button. hope this helps if this doesnt fix it the drive motor has went out.
Aug 11, 2010 | Kenmore 50532 / 50534 Side by Side...
Ice dispenser will not dispens ice . light dims when pushed. ice maker works fine
It may be a good Idea to remove the ice bin, clean and dry ant the same time with bin removed see if while pushing the door light switch and the dispense ice control if the auger fork in the rear of the ice bin that normally turns the auger will rotate. Sometimes ice or water collects in the bin and locks the motor from turning and sometimes the motors go bad. Tell me your results, Thanks, Sea Breeze
Apr 23, 2010 | GE Profile 23.3 Cu. Ft. Counter-Depth...
No ice comes out when pad is depressed.
does your auger turn? thats what pushes the ice doun the shoot. if not replace the auger
Oct 29, 2009 | KitchenAid Superba Architect KSCS25INSS...
Kenmore side by side fridge - ice dispenser stopped working
You might check out this site and ask a question. They have drawings on many of the fridges and I have bought many parts from them.
http://www.appliancepartspros.com/partsearch/
Jul 28, 2009 | Refrigerators
Ice dispenser auger does not work.
Hi, On GE refrigerators the motor is not quiet. Open your freezer, remove the ice bin, press the door switch, make sure it turns off the light, and then press the ice dispenser lever. The solenoid will click, which also opens the ice door and the auger motor will turn on and you can definitely hear it. If the motor runs then inspect the auger connection on the rear of the ice bin, its plastic and they break. On some models, like my GE Adora there is a switch just for the ice maker behind the ice bin. If you need more help let me know as with all long distance troubleshooting we try with the information we have. Thanks and Good Luck!
Feb 15, 2009 | GE Refrigerators
Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator Logo
474 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
