Question about Coleman Propane Forced Air Heater w/Electronic Ignition (50,000-80,000 BTU)
Coleman Presidential II Heater won't come on
I have a 1977 Mobile home with a Coleman Presidential II heater. The pilot light comes on but nothing else comes on. I just over hauled the enter system and oiled the motor... put it all back together and it does not fire up.
  • 61 Answers
You should have 3 wires going to the gas valve - MV(mainvalve), PV(pilot valve) and MV/PV (or Common). Make sure all of these are properly wired and tight.
You also may have a dirty FLAME SENSOR on your pilot/ignitor assembly. You may need to remove the pilot tube and the pilot assembly to clean the sensor with sandpaper.
Be careful not to damage any parts while cleaning them. Be careful not to crossthread the gas line when re-installing it.
Posted on Jan 04, 2009
I have a Coleman Presidential III, pilot light lights then in 10-15 minutes the heater cycles off. How do I fix it?
Check pilot is strong and blue if not clean it . Check thermocouple is clean and not brunt out . check flame sensor is clean and in position . check air filter is clean . Check pressure switch .
Nov 11, 2016 | Coleman Heating & Cooling
I have the Coleman Presidential Heater in a 1976 travel trailer and the pilot light/gas unit has broken off and I need to know where can I find an NEW ENTIRE HEATER to replace it? Thank you
They are pretty standard... get the old one OUT...
Take it to the hardware store and have the STAFF there help you do a STARE & COMPARE).
Be careful not to overtighten the coupler when re-installing
Sep 14, 2016 | Coleman Heating & Cooling
What is the correct way to light a Coleman Presidential heater?
The older Coleman Presidentials had a screw-cap with mica in the center. You unscrewed the cap and used a telescoping match holder to reach in to the thermocouple/pilot light and lit it once you twisted the gas control to the 'pilot' position and depressed the controls button or lever. I don't know the specifics on the newer Preidentials Chester, but it has to be similar.
Sep 22, 2015 | Coleman Heating & Cooling
yOU CAN PURCHASE FILTER MATTING AT ANY HARDWARE store and cut to size. Its cheaper anyway.. It comes in rolls.
Jun 05, 2009 | Coleman Propane Forced Air Heater...
Need replacement glass for pilot cover of Coleman Presidential II
the glass is there as a service tool to veiw pilot and flame or relite just get a peice of sheet metal and cover hole with it ,it will work short term or long term
Feb 05, 2009 | Coleman Propane Forced Air Heater...
Looking to find an owner's manual for an old furnace
I remeber we took out a Coleman kero heater out of my grandmothers mobile home. Just had it repaired but she wanted a new unit. Would have to go and check to see how many BTU's it is and also to see if the book is there as well.
Jan 29, 2009 | Coleman Heating & Cooling
Coleman presidential II furnace blower on and off
Sounds like the flame sensor. But it could be the thermostat. Is the furnace standing pilot or electronic spark or hot surface ignition. I would start by checking thermostat. Turn power off to furnace take thermostat off wall and take wires marked r & w and connect them together. Turn power back on if furnace works then change out thermostat.Most eclectronic ignition Furnaces have a flam sensor, You could take flame sensor out and clean it up with steel wool or wire brush. If you need anymore help just reply back .
Jan 17, 2009 | Coleman Propane Forced Air Heater...
Coleman Presidential II mobile home furnace. When burner lights the blower cycles on and off instead of blowing constant through burner cycle.
Is this furnace standing pilot or electronic ignition. If standing pilot i would check furnace filter then the thermastat. To test themostat first turn power off to furnace. Take thermostat off wall and take wires labled R & W and connect them together. If you have electronic ignition I would start with cleaning the flame sensor with steel wool or wire brush.If you have and more questions i will be glad to help.
Heating & Cooling Logo
435 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
Paul Carew
Dan Webster
Dan Webster
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
