Question about Sharp AR-M237 Copier
I need to change the IP for my ar-m237
I am unable to detect my ar-m237, I run the administration tools adn it does detect it. Do you a form I can change my ip from my AR-M237 directly without conecting it to my PC, I thik that my router doesn;t detect it because is out of range from my router, the IP that tne copier has is 192.168.0.150 and my router range is 192.168.1.2 through 192.168.1.100
  • michelfranco Jan 03, 2009
    How I may change the IP in my AR-m237, (directly in the copier)
  • Sharp Master
  • 32,281 Answers
Try to increase the router range to include the ar-m237 or change the copier to a lower IP address within the range of the router.
Posted on Jan 03, 2009
Attempting to print to my Sharp ARM237 Network printer. It gives me the error Unable to access server. Check server address on device web page" . It used to be networked then I moved the loacation...
you must put the right IP adress for the machine: from the menu
  1. choose system setting
  2. Network settings
  3. IP address setting
  4. copy the the ip adress from your computer and type it in the special field
Dec 06, 2010 | Sharp AR-M237 Copier
How do I change the IP address for the scanner on a Sharp AR-M237 multi function
Custom Settings/Admin mode/ passworrd 000000 print settings/ network settings
Aug 27, 2010 | Sharp AR-M237 Copier
Change the toner cartridge message doesn't go away on AR-M237
plese check you have changed the same partno toner or not. if its ok you have problem in connector wich hold the toner cartrdge ic
Feb 10, 2010 | Sharp AR-M237 Digital Copier
Sharp AR-M237 EXPANSION MEMORY 8MB: AR-MM9 installation procedure
You are needing the installation manual for this. Please contact me so I can e-mail you the pages that you need. administrator@aokoffice.com
Oct 08, 2009 | Sharp AR-M237 Digital Copier
Unable to access internet through local area network.
hello
in this case first you need to check the ip address by goin on start- run - type cmd -- then type ipconfig , if its giving you a valid ip address then try to access internet and select the option that says automatically detect settings and you will find that option under -- open internet explorer then go to tools- internet option- connections - lan settings
and
if you are not getting any ip address then do a right click on my compuetr icon on your desktop adn go to properties-- hardware- device manager-- network adaptors - and uninstall all the adaptors and then do a right click on network adaptors and then scan for hardware changes .
and the third option is to uninstall Internet explorer 8 adn try with IE 6
kindly rate this solution as well
Mar 24, 2009 | Microsoft Internet Explorer 8
Sharp ar m237 assigned static ip address
You can print the configuration data by Simulation 22 sub 6.
This is how to :
1) #/P key (program) ON → Asterisk (*) key ON → CLEAR key ON →
Asterisk (*) key ON → Ready for input of a main code of simulation
2) Entering a main code with the 10-key → START key ON
3) Entering a sub code with the 10-key → START key ON
4) Select an item with the scroll key and the item key.
5) The machine enters the mode corresponding to the selected item.
Press START key to start the simulation operation.
To cancel the current simulation mode or to change the main code
and the sub code, press the CUSTOM SETTINGS key.
* Canceling the simulation mode to return to the normal mode
1) Press CLEAR ALL key.
Mar 11, 2009 | Sharp AR-M237 Digital Copier
I have a AR-M237 small copier and I need to put in some new account codes and delete some old account codes. I have a manual but it doesn't seem to tell me how to accomplish this. Please help.
You need to have the ADMIN code to access, change, edit, delete or install new codes. Look in the Management setting under user tools. Look for user codes or key operator codes. Defualt ADMIN code is normally 000000 or 11111, that is if the ADMIN code was not changed.
Dec 18, 2008 | Sharp AR-M237 Copier
IP Address on a Sharp AR-M237
The easy way to do it is to set the copier up for AUTO DHCP.  That way the copier will connect to the router and assign a free IP address to the copier.
Then go into internet explorer and type in the ip address of the copier.  If you can get a control panel screen of the copier to appear.  It worked.
Once you get the IP address, take it off of AUTO DHCP and type in the IP address that the router assigned to the copier.
Oct 16, 2008 | Sharp AR-C270 Color Copier
Sharp AR-M237 Copier Logo
413 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
