Question about Compaq Computers & Internet
ALOT service error
MY COMPAQ PRESARIO CQ50 105 NR DISPLAYS "ALOT service" error and does not boot.
5 Suggested Answers
nyilasrobert
  • 627 Answers
SOURCE: System unit error in pentium 3 compaq presario
304 error reffers to keyboard error. Verify if your keyborad is properly plugged in, also verify if it's working (pressing Num Lock will turn on the led, pressing again will turn off).
If you plugged in an USB keyboard it won't work, it is necessary to be present an PS/2 keyboard.
Posted on Sep 02, 2009
Testimonial: "that i know i remove keyboard error but wat about system unit error.. nyways thanx"
parrotheadpc
  • 2600 Answers
SOURCE: I need to find compaq presario v5207 NR drivers to
Click the link below, select your operating system, XP or Vista and download whatever drivers you need.
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&dlc=en&cc=us&lang=en&product=3197924&
Posted on Oct 04, 2009
parrotheadpc
  • 2600 Answers
SOURCE: how do i reset a cmos/bios pasword on a compaq
The power on password is a little harder to break in laptops than desktops and this tip may or may not help. Each computer manufacturer is different in how they set thier systems up. Disassemble the laptop down to the chassis where the RTC battery can be seen in its socket. Make sure that all power is removed from this device and remove the RTC battery. Let the motherboard sit without the battery in it for up to one hour. replace the RTC battery and reassemble the laptop. Do not put the main system battery in just yet, power on only with the AC adapter. Power the laptop up and if it asks for a password, just hit enter, if it still asks you for a password, type in "clear". If it still wants a password, then the only other option is to "short" the two contacts in the battery socket for the RTC battery, using a small wire to jump the positive and negative points in the socket, make sure nothing else is touched or you will Nuke your motherboard. With the battery contacts "shorted" power the motherboard up with the AC adapter, wait approx 1-2 minutes allowing the motherboard to post. Shut the board down, and follow the previos procedures for reassembly and powerup.
Posted on Jan 10, 2010
  • 3 Answers
SOURCE: Error Message: F12=Network Service Boot
The BIOS may have reset to the default settings. Sounds like this was originally a workstation on a Corporate Domain Network. Access the BIOS and reset the boot order for CD first, then Hard Drive - you can even disable Network as a boot option. Power spike won't affect the Hard Drive contents, but it can reset a BIOS. Your win2000 should be intact.
Posted on Mar 11, 2010
How o i connect my compaq presario 62-231 NR notebook to wireless network
might find this manual to be of some assistance in setting up that wireless
click here please
May 16, 2012 | Compaq Presario CQ62-215DX Laptop
Main OS does not mount
Boot in safe mode
Start msconfig.exe and configure windows to start with a clean boot.
a. Log on to the computer by using an account that has administrator rights.
b. Click Start, type msconfig.exe in the Start Search box, and then press ENTER to start the System Configuration Utility.
If you are prompted for an administrator password or for confirmation, type your password, or click Continue.
c. On the General tab, click Selective Startup, and then click to clear the Load startup items check box. (The Use Original Boot.ini check box is unavailable.)
d. On the Services tab, click to select the Hide all Microsoft services check box, and then click Disable all.
Note Following this step lets Microsoft services continue to run. These services include Networking, Plug and Play, Event Logging, Error Reporting, and other services. If you disable these services, you may permanently delete all restore points. Do not do this if you want to use the System Restore utility together with existing restore points.
e. Click OK, and then click Restart.
Boot the machine in normal mode.
Nov 11, 2011 | Compaq Hewlett Packard Presario SR5110NX ...
Compaq Presario S5300NX (DM174A#ABA) PC Desktop: Compaq Presario Dekstop: CPU Fan error on bootup. ...
The fan has a third wire, that is used to tell the uProcessor that it is spinning and in some cases how fast.
Replace the fan and that should fix it. Spares form many suppliers on ebay
May 18, 2010 | HP Compaq Presario S5300NX (DM174A#ABA) PC...
Sep 02, 2009 | R.A.M. Computers Compaq Presario 1075,...
Need a sound sofware
i can't find sound and audio driver after formatting my laptop compaq presario C700 notebook pc
Nov 09, 2008 | Compaq Presario 700 470024-192 Notebook
Compaq presario v5000
Boot into Setup and run the TOOLS / PRIMARY HDD TEST / SHORT TEST.
If it fails, try another HDD.
If OK, verify Boot Order is Floppy, CD-ROM, HDD. Exit Setup.
Print Table 1 Low Level Format instructions from http://support.microsoft.com/kb/106419
Boot with a DOS disk that contains Debug. Run the Table 1 script. Turn V5000 Off.
Boot with the HP Operating System CD. XP install should now proceed normally.
Good luck.
Sep 12, 2008 | Compaq Presario V5005us Notebook
Compaq Presaio S4200NX displays Compaq Splash Screen then a single continuous beep with but nothing else.
Most Compaq desktop that exhibits 1 long never ending beep indicates Memory error; Bad RAM. Corrective measure therefore would be replace and test.
You can try removing the memory and cleaning the gold pins with a pencil eraser and try again. If this doesn't work, guess you're back to replacing.
Good luck and kind regards.
Nov 04, 2007 | Compaq Presario S4200NX (DF215AR#ABA) PC...
Laptop Boot Problem
It seems all Compaq laptops are infected by this problem. If you are sure that the AC port and the AC adapter is working? Can you hear the laptop trying to boot? ..e.g. Hard Drive spinning up, Floppy Disk Drive noise, etc.. if so ...Try hooking up a external monitor.. Does it smell like anything has burnt? (Call for service) Is there anything that sounds loose when you shake it? (Call for service or you can to open it?) Try booting your laptop from a bootable floppy if you have one. Or use Compaq's Recovery CD. But I doubt if you use recovery CD, you might lose data on your HDD. Which O.S. are you using? The Boot-up mechanism checks all the hardware before starting Windows. Some times floppy drive doesn't allow the laptop to boot further by either not responding or sending wrong signal.
Jan 16, 2006 | Compaq Presario 1200XL104 Notebook
Computers & Internet Logo
180 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
