Question about Sony Handycam DCR-PC350 Mini DV Digital Camcorder
Camera won't charge/shows "replace cassette" window
This is a veteran machine that's worked well for nearly a decade. Recently the "replace cassette" window pops up and/or a low battery icon.   For a while I reset the cassette and it seemed to help, but now the  unit clearly doesn't have the power to open or shut the cassette bay. This is even after I replaced the battery. Full disclosure:  new battery was a $20 Chinese-made Internet buy. First time  hat to replace the battery. Orange light appears on the  camera when sitting on the power stand. In my mind are the  words, "Duh, $20 battery..." but, well...any comments?
  • acbaruch Jan 03, 2009
    Thanks Drumbanger.   I would go to Radio Shack, but there aren't any in Yamanashi, Japan.  But that's what I was thinking.  I could probably get it tested somewhere around here.  Logical.   At least I can see if the Chinese one is a dud.
    Genius:
  • 1,199 Answers
I would go to radio shack there they will let you test the battery before you buy! I would say you got a bad battery!
Posted on Jan 03, 2009
Handy cam hi8 dcr
Try removing the battery and charging it. Then put the battery back on the camera. This will reset the cassette system. The cassette should open or close depending upon what status it is in. Once you get the camera to eject fully, clean your heads with a dry head cleaner cassette for Hi8 video. If your camera is still eating tape, could be a broken pin or damaged heads.
Aug 26, 2013 | Sony Handycam DCR-TRV280 Digital Camcorder
Camera only works when charger is plugged into it, the battery is showing 3.4 volts of charge, is the camera at fault and can it be fixed cheaply?
If the rechargeable battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods.
Oct 24, 2012 | Pentax Optio Cameras
I have a Sanyo Xacti VPC-E60 EX Digital Camera.
If the recharageable battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
Jun 16, 2012 | Sanyo Xacti VPC-E60 EX Digital Camera
Nikon Coolpix L110 camera was bought for me for Christmas 2010. Worked fine at first, but now seems to be having problems. Batteries don't last. I just bought new batteries in Feb/March this year...
You have to charge the batteries for nearly 8-10 hours. Brand new batteries also require a full recharge of 8-10 hours.Not only making sure the batteries are charged, have you changed the battery in the menu under type of batteries.
Download this manual :
http://www.nikonusa.com/pdf/manuals/noprint/L110_ENnoprint.pdf and go to page #114
Buy EN-MH2-B4/MH-73 Kit (4 Rechargeable Batteries + Charger)
Jun 14, 2011 | Nikon Coolpix L110 Digital Camera
The shape of the cursor in Visual Foxpro
I, too, am a veteran of DOS to Windows conversions, in fact, I make my living at it. But I learned over a decade ago to get over the differences, like using Tab instead of Enter to move around the screen, and of course, the cursor shape.
If you want your converted program to be accepted by people who have never seen DOS, you need it to follow Windows UI conventions.
Dec 13, 2009 | Microsoft Office Excel 2003 for PC
Canon ZR900 cassette won't eject
you could hit like the method for if a canon won't let you put in a cassette but i don't know if that will work. just hit it on the non screen side a few times and in theory it should work.
if nothing it will get rid of stress
Dec 12, 2008 | Canon ZR900 Mini DV Camcorder
Camera does not record
First I would suspect the record safety switch on the cassette. Look near one of the rear corners for a little red tab. If it's closed (covering the hole), then recording is disabled on that cassette.
Is there any indication in the viewfinder that recording is disabled? Usually an icon like indicator showing a cassette with a circle and slash over it.
If that's not the case, you might have a problem with you're record switch. Try using the remote to do it if you have one.
Nov 17, 2008 | Sony Handycam CCD-TRV318 Camcorder
"DEW"
Dew has condensed in the camera. Eject the cassette but leave the cassette door open.remove the battery . Borrow a hair drier . set it to optimum temperature(not vey hot but but hot enough to cause discomfort when blown on fingers). direct the hot air through the cassette compartment door for about five minutes. reattach the battery and reinsert the tape.
Good Luck,
Luwangula
May 05, 2008 | E.Digital Sharp VL-Z7E Digital Viewcam...
Flashing red power light
The problem here is condensation inside the camera. I leave the camera turned off, remove the cassette tape and then point a hair drier on warm or low heat and slow speed right into the innards of the camera through the open cassette tape door. I run the hair dryer for 5 minutes and then replace the cassette. If the camera still dosen't work just wait for another 5 or 10 minutes and then it will work OK.
Jan 26, 2008 | Panasonic Palmcorder PV-DV102 Mini DV...
No power
first it is not the volt but the current the barrery is having. check it with milliampere meter, because even a recently dead battery may show you proper voltages. second yes there are safety fuses in the power section near the battery terminals and power socket. try locating and check for continuty.
Oct 09, 2006 | Canon PowerShot G2 Digital Camera
Sony Handycam DCR-PC350 Mini DV Digital Camcorder Logo
67 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
