Question about Delta Drills
GUARDIAN drill press CHUCK KEY needed. Someone donated a Guardian 5-speed Heavy Duty 1/2 inch 1/3 h.p. drill press, Model # DPMINI 5(NW), to the Main Line Art Center, but it can't be used because it lacks a chuck key. Does anyone know where we can find a chuck key for this equipment?
2 Suggested Answers
puertobori
  • 7733 Answers
SOURCE: I have a Guardian bench mount drill press Model #
Look at eReplacementParts.com and the parts diagrams
Posted on Nov 02, 2010
Where can i find a 5/8 in. chuck for a Pit Bull CH-16NF Drill press
Take it to a local engineering sales shop. They are all basically the same and fit into the shaft with a morse taper. You just need the correct taper.
  • 5/8 in. Keyed Drill Press Chuck ' Princess Auto www.princessauto.com/en/detail/5-8-in-keyed-drill-press-chuck/A-p...
    • 4.5/5
    • 2 REVIEWS
    Email Signup. Never miss a sale and receive special online only offers.
  • King Canada KDC-58M Chuck, Drill Press, 5/8" JT6 for ... https://eastcoastpowertools.ca/chuck-drill-press-5-8-jt6-for-milling King Canada KDC-58M Chuck, Drill Press, 5/8" JT6 for Milling At East Coast Power Tools
  • 5/8 in. Keyed Drill Press Chuck ' Princess Auto www.princessauto.com/en/detail/5-8-in-keyed-drill-press-chuck/A-p... Help others make a decision about this product by sharing your experience.
  • Related searches for 5/8 in. chuck for a Drill press
  • Woodstock D3455 Drill Chuck, 5/8-Inch by JT33 - Amazon.ca https://www.amazon.ca/Woodstock-D3455-Drill-Chuck-8-Inch/dp/B000HRXOLS This item: Woodstock D3455 Drill Chuck, 5/8-Inch by JT33 CDN$ 47.71. In Stock. Ships from and sold by Amazon.ca. FREE Shipping. ... (Canadian Tire) Drill Press.
  • 5/8 Drill Chuck ' eBay 2q== www.ebay.com/bhp/5-8-drill-chuck Suitable for drill presses or lathes spindle accepts R8 shank. Chuck key and R8-JT33 arbor are also included in the package. Special quenching treated ...
  • 5/8" Drill Press Chuck [MAG-DPC58] - $29.99 : KMS Tools ... https://www.kmstools.com/5-8-drill-press-chuck-2990 KMS Tools & Equipment from Vancouver BC 5/8 ... Home > Metalworking > Lathes and Milling Machines > Chucks and Taper Adapters > 5/8" Drill Press Chuck 5 /8 ...
  • 1 32 5 8 Heavy Duty Drill Chuck with Chuck Key and R8 Arbor Amazon com
    Jun 05, 2016 | Drills
    I have a guardian power floor model drill press model FDM 58 12SP where can I find a 5/8 chuck
    in perth i would try ron mac machinery sales.. in other states also machinery sales for trades or companies in steel work.. pete
    May 11, 2014 | Drills
    How do you get a morse taper chuck out of a guardian power 12 sp drill press
    Everywhere there is the same kind of remove or by a long axle insite the top pulley down
    How To Remove Morse Taper Mounted Chuck From Drill Press AutoDrill
    Mar 17, 2013 | Delta 15 331 15" 115/230V Variable Speed...
    Drill press chuck fix
    The chuck on almost all drill presses is held on by friction only by use of the tapered fit you mention. Make sure both the spildle tip and the chuck hole surfaces are completely clean and dry. Set your table so when you move the spindle down it will contact the table. With the drill OFF, put the chuck on the spindle and press it down on with the table as hard as you can without bending any handles or gears. This should be sufficient to hold it in place.
    Jul 19, 2012 | Drills
    I have an old Guardian Power 3/4 HP 12 speed drill press. When the drill is on, I can hold the chuck with my hand. The Pully spins the but spindle is slipping...got any suggestions
    sounds like either the pulley is not tight to the spindle or the spindle is broken in half either in a bearing race or between the two spindle bearings
    Feb 26, 2011 | Drills
    I have a Guardina Power 5 speed heavy duty drill press, model number DP-MINI 1/2 inch chuck. The chuck will not stay on the spindle. There doesn't seem to be any set screw, threads or any type of method...
    The chuck is held in by the tapered shaft and friction. Make sure the tapered shaft on the chuck is clean with no burrs. Do the same for the socket side in the spindle. Swing the table out of the way and set a wood block under the chuck. Bring the spindle/chuck down into the block quite firmly which should lock the two tapered parts together. Hope this helps as it worked on my drill press!
    Nov 19, 2010 | Garden
    I need the owners manual for a Guardian Power drill press Model# FDM-58-16S........Help...................
    I'm looking for a Owner's Manual for a 16 speed, 1/2 hp, Heavy duty Guardian Power drill press.
    Apr 17, 2010 | Drills
    Hi, I have a Clarke Drill Press Model No:- CDP 12HBN
    You can get a universal chuck key at Home Depot, Lowes and many other tool outlets. They have 4 different keys in one.
    Nov 24, 2009 | Clarke Power Products Clarke 16-Speed...
    How do you change a chuck on a DW995. I took the center screwn left handed screw out. How do you back the old chuck out?
    u need allen key that fit to the chuck. insert the short end to the chuck. tighten the chuck if u can. hold the drill at the edge of the table & smack the allen key counter clockwise. do it again if needed. but before u do it set the speed to #1 position & drill mode.thanx good luck
    Jul 17, 2008 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
    Open Questions:
    How fix Delta/Rockwell 15 drill press from chuck wobbling. I purchased a Delta / Rockwell 15 drill press model 15-091. The chuck wobbles. I ordered some wedges to remove chuck.jacobs #6 wedges After soaking in pb blaster I removed chuck with ease with the wedges. must have Now after looking at what is called the spindle I believe...it is wobbling. I wonder if I am looking at an arbor or the spindle? Above this piece is a threaded section that is about 1/2. I thought of maybe getting a jacobs 34-33c chuck to screw onto this. Seems like if the spindle/arbor is wobbling it still would not run straight or be difficult to properly seat it. I do know that some quills come with a slot to fit a wedge for removing the arbor. Mine does not have this. Without a proper way to remove an arbor it leads me to believe maybe it doesn't have an arbor. Seems that I am looking at the actual spindle. I need this drill press for precision work. If you know about this model.. Please Help !!!!! I am stuck. Do I need to buy a whole spindle? If it is in fact an arbor how are you supposed to remove it? I thought if it is an arbor I could take a grinder and cut 2 slots in the arbor. Then take a really thick washer and cut out a section. to make it a u shape then slide the washer into the grooves I cut out. Then use the wedges on top of that. After tapping the wedges I would think it would come free. Unless it is one solid rod with a taper at the end like an arbor usually has AKA the spindle....HELP!!!! I can't find ANY info on this anywhere. I know someone must have worked on these before.
    May 05, 2016 | Delta Drills
    Drills Logo
    267 people viewed this question
    Top Delta Drills Experts
    DocZachary
    DocZachary
    Bill Boyd
    Are you a Delta Drill Expert? Answer questions, earn points and help others
