Question about Magic Chef CTF1826AR Top Freezer Refrigerator
Freezer cold fridge not cold model ctf1826arw
Tried to thaw out in back of fridge compartment but still not cooling
mikedurland
  • 481 Answers
SOURCE: Our Magic Chef fridge model
yes the freezer door not closing properly will effect the refrigerator. also check in the freezer back wall and bottom for any frost buildup. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items.
Posted on Jul 16, 2008
aasc
  • 1606 Answers
SOURCE: freezer temp is wear fridge shoud be.fridge temp 55 degress.
Check the fan in back which cools the compressor . Also check the coils to make sure they are clean of dust , lint , etc...
Posted on Aug 02, 2009
SOURCE: fridge stopped being cold and freezer not freezing
Switch off the refrigerator. Let all ice melt completely. it may take 4 hours. Switch it ON again. does it work better for 2-3 days. if yes,change bimetal and timer.
Posted on Aug 09, 2009
woodchuck789
  • 4059 Answers
SOURCE: Is there a replacement part for the freezer
The evaporator can be replaced and a damaged line can be repaired. It's not cheap as a qualified tech will have to recharge the system besides the repair. With the proper model number you can look up parts here. http://www.searspartsdirect.com/partsdirect/index.action?psid=26129238&sid=PSx20071217x00001a Model number help here. http://www.appliancepartspros.com/modelnumber_locator.aspx
Posted on Aug 22, 2009
  • 22 Answers
SOURCE: the motor on my frostfree fridge never stops
Hi, seen this a few times when i did apartment maintenance,the most likely cause is a bad thermostat.
Posted on Mar 06, 2011
Refrigerator won't cool
seal on door must be letting moisture into compartment, need new door seal
Aug 20, 2012 | Kenmore Top Freezer Refrigerator
Model # MFF2557HES Top refrigator section stoped cooling freezer is working
You may have Ice buildup in the freezer. You freezer has a fan in the bak that sends the cool air to the fridge. Your fridge dial determines how muh cold air comes from the freezer. Try defrosting the freezer. You may have to pull the back panel off of the inside of the freezer to get the ice thawed. The ice build up is likely causing the air to not get to the fridge. Hope it works.
Aug 16, 2012 | Maytag MFD2560HES Bottom Freezer French...
Refridgerator isn't cooling, but freezer is cooling more than it should
Some fridges use the same air fridge gets its cold from freezer the duct could be frozen closed a good defrost could do the trick
Jun 30, 2012 | Maytag Appliances Magic Chef 18 cu. ft....
The top freezer is working but lower part refrigerator compartment doesn't cool at all even adjusting temperature to Max cooling??? It is like fan doesn;t blow cold air from the freezer
There is a drain that carries water from the freezer to a drain pan in the base of the fridge. It has plugged preventing water from draining and in turn the water has froze blocking the flow of air to the fridge. First you must find the drain line in the rear of the fridge and unplug it as well as thaw the fridge out overnight to allow the water to drain... be patient as there will be a lot of ice to be thawed out, let me know if it works! good luck!
Jul 20, 2011 | Kenmore Top Freezer Refrigerator
Samsung Model SR 21 NME. The freezer is on the top, this freezers fine, but the fridge isnt even cool. We have taken the back off the freeze to do a complete defrost. The fan works fine. But the ttemp dial...
Inside the fridge compartment, at the back, is a panel that can be removed, remove the screws careful with the bulb, its plugged in behind the panel.
the panel has a vent that allows cold air flow from the freezer, this will often freeze completely shut with ice. let it thaw out, then check to see that the vent opens, or closes when you turn the dial, the best thing is to open it as wide as possible, I even used toothpicks to open the valve even more, its just a thin flap, surrounded by Styrofoam.
afterwards if your fridge is too cold, adjust the real thermostat located in the freezer.
Jan 06, 2011 | Samsung Refrigerators
I have a GE Profile model # TPX2451YEBS side by side fridge. Both sides are not cold on upper part. The food in fridge on top 2 shelves and door shelves is just cool. The frozen food in door...
Sorry to hear about your problem.
Sounds like you have a defrost issue. Hence your unit is not defrosting. All of this apply's if your freezer side has ice . If not. you have other issues, this does sound funny, but this is why your refrigerator side is warm, or not cooling.
Here is a list of some things that can go wrong.
1. Defective heat coil
2. Defective defrost timer
3. Defective defrost sensor
4. Defective Fan
5. Defective compartment inlet damper (on some models)
You should call a service company to resolve your issue.
Since I tried to help you, Please help me and Rate/Vote on the response. Thanks
Jan 02, 2011 | GE 23.1 Cu. Ft. Side-by-Side Refrigerator...
Freezer on top gets iced up and drips into fridge. When thawed it drains easily. Would tilting it back help? This is a GE tbx14satglwh model.
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Dec 16, 2010 | Refrigerators
Magic Chef CTF1826AR Top Freezer Refrigerator Logo
Top Magic Chef Refrigerators Experts
John Tripp
John Tripp
Lawrence Oravetz
Are you a Magic Chef Refrigerator Expert? Answer questions, earn points and help others
