Our canon copier ir3570 experiences paper jam even there are no paper jam
The canon copier ir3570 detect paper jam even their are no paper has jam,what will i do?
SOURCE: Canon Pixma iP1200 always reports "Paper is jammed"
not printer 5600 serveice ink who Repair it frome pleas helpe me thank you
Posted on Mar 04, 2008
SOURCE: Canon Pc720 Copier Paper Jam
The problem with the paper jam (but not feeding) is that a small
piece of plastic that holds one end of a spring the causes the feed
gears to push against the powered gear on the back side of the toner
cartridge breaks off. So the unit does not feed (no pickup rollers
etc) and it thinks there is a paper jam (no moving paper). Orienting
the front as the side you work at, the back being the back, the
feed being the side the paper goes into and the output being the
side the finished copy comes out, open the unit. Looking into it
from the output side almost to the input on the bottom notice the
small hairlike things sticking up. Move to the left (back of the
machine) and see a few white gears all hooked into this gray metal
housing that moves up and down about 1/2 inch (It pivots). At the
top input side of this metal you will see a part of the metal that
stick up and has a small slot in it. the spring used to hook onto
this and the other end hooked to a small piece of plastic down and
more to the input side a bit, onto the upper input side of the white
plastic part that houses a shaft to a roller (fat little spring
about 1 inch long). the plastic part breaks off and you usually
can't see that a part was even there. The spring will still be in
the area. If you are handy, you can figure out how to fix it. I got
a longer spring (same strength) bent the metal toward the back 1/4"
and ran the new spring from there to a 1/16 hole I drilled in the
plastic side next to the circuit board (down low and back). I shaped
the end of the spring (where I drilled)to keep it more inside and
not hit anything. Works fine.
Steven
Posted on Mar 30, 2008
namizhka
  • 148 Answers
SOURCE: Copier canon mf4150 says it
1. First, clean your printer. Get some spray-n-wipe cleaner and a clean cloth and clean the entire inside of the printer. Also ensure your paper isn't dirty. Now print a test page. Does the symptom persist?
2. Remove all jammed paper. Check the paper tray first. Look closely at the paper rollers nearest where the paper exits the printer; this is a common source of jams. If you’re trying to print labels, they will often jam just before exiting the printer.
3. Try to print a test page. Does the printer still jam? If you can find no source of the jamming, check the printer's message display window and refer to your user’s manual to look up the printer error code.
Posted on Sep 16, 2008
  • 100 Answers
SOURCE: Paper Jam in Bowels Of
It needs a new fixing unit. If you are careful and have a long skinney screw driver you could do this. Open the right side door. Remove the small screw in front this secures the control panel.
Shift panel to the left and remove the ribbon cable. Put right top door down. Shift top feeder back to the right. remove all the screws on the left side and remove the plastic. There is a top piece held by one screw in the middle. One on the left and two hold the bottom plate on. Remove this plastic. Now the dangerous part. Remove the two screw on top of the the machine that hold the two white guide pins. Now you are going to rock the top feeder up and to the back. Before you do this you need to know there is a plastic finger that comes up out of the copier and is part of the main drive gear pack. IF YOU BREAK THIS you can just throw your machine away in the trash. SLOWly look under the top *** you rock it back. You want to shift the feeder unit left or right to get clearnace of the white 90 degree angle finger that is in a grove of the feeder. Clear it and rock the feeder back resting on the rear of the copier. DO THIS CLOSE TO A WALL. SO WHEN YOU ROCK BACK THE SIDE CAN SIT ON THE BACK OF THE COPIER. There are hole in the top that allow a screwdriver to remove the three screw for the fixing unit. and you will unplug two wires. GOOD LUCK !!
Posted on Jan 06, 2009
idriss47
  • 26 Answers
SOURCE: i am using canon copier
Hello
try to clean carefully the "Heater roller" when it will be heat by any clean cloth.
Posted on Jan 25, 2009
Canon 3010 problem jam indecate
If the error indicator light is lit, then the Canon printer is jammed. To fix a paper jam you must remove the paper tray, disconnect the AC power adapter, wait 5 seconds, then plug the printer back in. If the jammed paper does not automatically eject, carefully remove the paper manually. To help prevent further jamming, fan the paper in the paper tray to prevent the paper sticking together.
Great people delivering a superior customer experience. Canon Printer offers a complete line of printers, scanners, all-in-one office machines and paper jammed problem. Facing the problem with Bother printer, Scanners, Call our technical expert and get quick help. Dial Canon Printer tech Support Phone Number (18777788969) and fix your problem. For more information visit us: http://printertechnicalhelp.com/Canon-printer-technicalhelp.html
Sep 02, 2016 | Canon Office Equipment & Supplies
Sir canon ir3570 duplex paper jam jam code010d jamtype ps17 deleay sensor
Check the Clutch on the back side.
  1. Clean the all sensors in duplex.
  2. If problem persists Replace Clutch.
  3. If problem Persists Replace Dc controller
Jun 21, 2016 | Canon ImageRUNNER 3570 Copier/Printer
Two IR2270 is converted to IR3570, problem is when duplex printing, paper is getting rolled on the exit tray. During simplex printing paper is not getting rolled but it is wavery. Very rarely paper jam...
You may have a damp paper issue, when damp paper passes through the hot element it curls or crinkles the paper resulting in paper jams and poor output , if you turn all you paper round in the paper trays to A4R it will help, or use dry paper, recycled paper is the worst as it collects moisture much quicker, especially left over night
Oct 10, 2013 | Canon Office Equipment & Supplies
Canon ir3570 show error 00024
check for paper jammed in fuser assy, u need to reset error code by pressing smarthead then 2and 8 SAME TIME then smarthead should go into service mode press copier then function then err ok then off on
Feb 19, 2013 | Canon ImageRUNNER 3570 Copier/Printer
My Canon MF4010 printer shows "paper jam" even i have already removed paper
the paper jam could have caused errors so remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and connect the Printer to be detected and installed. Check printer properties to see the ink levels.
Use head cleaning before a test is taken .
Sep 28, 2010 | Office Equipment & Supplies
Paparjam but we have no paper
There is a "sensor" that detects the "paper-jam" status.
That sensor is reporting that status, even though you cannot see the jam.
Contact your local CANON retailer, and place a service-call for their technician to come out and service your printer.
Sep 01, 2010 | Canon imageRUNNER 3300 All-In-One Laser...
My printer suddenly stops printing then it says paper jammed even it isnt... i try not to load paper but still that message appears.
the paper sensor pin is jammed up in sensor so it detects that the paper is still there.even though its not there.get the printer serviced so that the sensor moves freely.this will solve the problem. please do not forget to rate the solution.thanks
Jun 12, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
Paper jams at heater section in ir4570 in A4, A4R is OK for some time. replaced film but problem not solved. require original fixing film for ir4570 part number
Depending on your voltage requirements; Fixing Film Unit FM2-1793-010 120V FM2-1812-010 230V FM2-1792-020 100V These numbers fit iR4570 and iR3570.
May 21, 2009 | Canon Office Equipment & Supplies
Error code E584 and paper jams
• Feeder motor , • Shutter closed sensor • The shutter closed detecting switch does not turn on even when the feeder motor has been driven in reverse for 1 sec or more.
clear dust from the finisher sensor
Feb 23, 2009 | Canon imageRUNNER 400S Copier
82 people viewed this question
k24674
jasbo
jasbo
