Question about HP w1907 LCD Monitor
HP W1907 Monitor
I installed an HP W1907 monitor to my Dell computer and it worked fine, the picture was great. All of the sudden, as I was installing the drivers, the monitor started having horizontal lines and now it won't do anything but showing these lines. Can anybody help? Thanks.
  • Anonymous Mar 15, 2014
    HP w1907 monitor turns black after a short run time .
    Renaissance:
    An user who is expert in 3 categories / brands.
  • HP Master
  • 848 Answers
HP W1907 Monitor? This trouble maybe power supply or inverter boards is defective.
first you can test the voltage of the multr,and then check which part is defective.From Wisiny.com can find those parts
if you have any question,please let us know email:service@wisiny.com.thanks,we sincerely hope we can help you!
you can also check this boards whether suit you:
http://www.wisiny.com/490481400600rilpi-027-hp-790871400600r-power-supply-backlight-inverter
Posted on Mar 02, 2015
  • 4 Answers
You might have to re install your driver, unplug your monitor and then use your older monitor to uninstall driver, then plug new monitor in and install it again from the manufaturer site
Posted on Jan 03, 2009
    Master:
  • 461 Answers
If it was working fine why install additional software? Try booting into safe mode and uninstalling the software or drivers.
Hp monitor 2031s does not scan signal from gateway gt5432...
Go back to Dell monitor. Remove any video drivers from hp.change video resolution both in windows and in video card settings to standard 1024 x 768 (yes it will look horrible) then hook up hp monitor. Don't install drivers if prompted get them from hp website then adjust resolution through video card settings after drivers installed which probably require restart.
Dec 01, 2013 | HP Computers & Internet
Hooked up old monitor and everything is working fine it probally is the monitor is it worth fixing
If you mean that you used an older monitor to test the computer and it worked and you think the monitor mentioned is failing, it is probably worth getting it checked by a tv repairman who can advise you whether it can be fixed. Generally, a monitor that refuses to show a picture, cuts off after being powered on, or has a display that is poor or with a colour cast is probably NOT worth fixing
Jul 22, 2011 | HP w1907 LCD Monitor
I have a HP w1907 monitor. It works for a while, then goes black. We move the mouse around but it won't light up. We used our old monitor and it works fine. What is wrong, and can it be fixed?
This is usually one of two problems. 1. The backlight of the monitor just might be dying out. This is what is usually the issue and is fixable. Basically you'll just have the LED lights inside it replaced.
2. The internal wiring of the monitor might be flawed, and may need fixing/replacing. This might be a result of poor or frayed wiring.
If your other monitor works just fine, it should mainly be an issue with the trouble monitor and you shouldn't have to worry about your computer especially if it even runs for a while before going black.
Hope this was helpful! Best of luck.
Apr 11, 2011 | HP w1907 LCD Monitor
My monitor will not allow me to even get a menu screen with the computer off. How can I get it reset back to factory settings without accessing the monitors menu? Should I just get a new monitor?
What is wrong with your hp w1907 lcd monitor? It won't allow you to get to the menu screen with the computer off?
The computer must control the monitor and should have a graphics card that supports the different resolutions of the monitor which will be connected to the computer via DVI or VGA.
I think your monitor is fine, unless you cannot get it to work with your computer.
Good luck on getting your monitor to work on your computer.
Jan 02, 2011 | HP w1907 LCD Monitor
Can the hp w1907 copy video games in the cyberlink dvd suite?
Firslty hp w1907 is a monitor model no:
now comming to ur issue, cannot copy an already installed game to a DVD, but if its the installation file you can burn them in cyberlink dvd suite. using a data Disk option.
Jun 26, 2010 | HP OfficeMax - HPHP Pavilion a6130n...
My HP 1907 lcd monitor did not take an update. I was told that I would have to re-install it. How do I do this?
There is no update for this monitor. You just have to mkae sure you have the correct video card driver install in your computer. Just use this monitor with another computer to find out if it is monitor or computer problem.
Nov 30, 2009 | HP w1907 LCD Monitor
Monitor (hp w1907)
Pls power on your PC & press F8 button continously then you see last known good configuration option. select your option & press enter. i hope your problem will be solved.
Nov 13, 2009 | HP w1907 LCD Monitor
No Input Signal, Monitor Going to Sleep
if you have twisted od bent the cord to much the wires could have broke inside the cord.
Jul 31, 2009 | HP w1907 LCD Monitor
I installed w1907 monitor all fine except now I have no sound
DVI is a hardware interface. It's a type of plug.
Does your monitor have speakers built into it?
On many computers, the output for the sound is very near the output for the monitor. Is it possible that you loosened the wire for the sound when you installed the monitor (plugged it in), or unplugged the sound altogether and plugged it back into the wrong place? The outbound sound hole on most, but not all, computers is green.
All computers have at least two places to plug in sound, most have 3, and the newer machines have 6. If you are unsure which is the correct hole to plug that sound wire into, you can play something on your computer that makes sound for a while (like a song) and move the plug from one to the other until sound is heard.
If you have 6 holes that the sound wire fits, you most likely have software on your computer that pops up and tells you were you have plugged it in.
If the speakers are built into the new monitor, check the monitor for controls and ensure that the volume controls are not all the way down.
All of these solutions are hardware solutions. Now, we have software solutions:
Open the control panel and find Sounds and Audio controls. Open that.
Check to see that nothing has "mute" checked.
Check also to see that the sound levels are high enough to hear something.
Good luck.
May 17, 2009 | HP w1907 LCD Monitor
HP w1907 LCD Monitor Logo
394 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
