Question about Sony KP-53HS30 53" Rear Projection HDTV-Ready Television
Sony Rear Projection KP-53HS20 distorted multi colored screen
My tv is distorted with multi color (red, green and pink). It shows more when there is writing on the screen and it it curved. I do have pictures of it.
  • 4 more comments
  • kimscriv4157 Jan 03, 2009
    I would like to do the repair myself
    I have the service manual and a supply store nearby. What would I have to do
  • jason May 11, 2010
    yours is the NTE 7180
    this is the convergence ic's for your tv and thier specs. http://www.nteinc.com/specs/7100to7199/p...
    do you have soldering tools , solder wick ( for removing old solder ) the service manual , or a electronic parts supply store to get the STK 392-020 convergence chip set to correct the picture colors and alignment? ( also replacing the resistors on the chip's would be advisable )
    are you going to do the repair yourself or are you going to need a repair center ?
  • Sony Master
  • 3,459 Answers
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony, Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit from the link below.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on - TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a solution
93a1209.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you know what you are doing. If you have never done this before we would advise calling a shop or if you want to do it yourself get a complete kit with instructions and support from www.TvRepairKits.com
Posted on May 15, 2010
  • 899 Answers
First check the resistors on the chips to make sure thier value is good enough ( within 5% is best for lasting longer , but no more than 10% ) then just look for the big IC's on the big heat sink , confirm STK & #'s , then order the IC's and resistors if needed
then make sure you have the soldering iron working , solder wick for removing old solder , and solder for the job , also you will need a tube of heatsink compound to put some fresh compound on the back of the IC's ,
Posted on Jan 03, 2009
  • jason Jan 03, 2009
    after you have done this repair you will have to use your service manual for the alignment procedure
Sony Projector Color Display
These sets have several common problems which are listed below.
Problem #1) Convergence
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
Your TV may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find the fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 03, 2010 | Sony KP-57HW40 57" Rear Projection...
Our Sony KP-46WT510 rear projection screen TV just
Convergence ICs, they are big black ICs will have part# on them if they are STK392-110s use 180s better ICs also CK pico fuses in front and behind ICs
they will look like resistors but will be Yellow or Green 5amps/6amp fuses
Mar 18, 2010 | Sony KP-46WT510 46" Rear Projection HDTV
My Sony KP-46WT500 screen shows the tv image in blue only for a few seconds, then it goes completely blank (as if it were off). Do I need to replace the bulbs?
It is rear projection TV that use 3 picture tubes of red-green-blue to show color picture on tv front screen.
Do you see standby red light blinking when TV shuts off after showing blue image for a while?
If red standby light is blinking, please count it how many times it blinks, there would be 3 seconds pause between blinks so count pause to pause and post it here to find out possible solution.
Thanks.
Dec 22, 2009 | Sony KP-46WT500 46" Rear Projection...
GREEN AND PINK COLORS ARE SEPERATED PICTURE IS ARCHED TOP AND BOTTOM. HOW DO I REPAIR THIS??
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Video may look distorted
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Red/Orange looking video
You can see some examples and find a fix here...
Dec 09, 2009 | Sony KP-57WS510 57" Rear Projection HDTV
Picture with green and pink outline
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
Here are some of the most common problems with these sets...
  • Screen Looks 3-D
  • Colors wont align
Problem #2
You can see some more examples and find a fix here
Nov 21, 2009 | Sony KP-46WT500 46" Rear Projection...
RCA 52" Model D52W23 Color Distorted
its not due to the fuse.its the problem of the ic on the maIN BOARD of the tv just check out for the faulty on the main board with multi meter and replace it.
Dec 19, 2008 | Sony KP-51WS520 51" Rear Projection...
Arched pink lines across screen. Now green and pink double stacked wording.
Projection sets have two very common problems.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Oct 25, 2008 | Sony KP-57WS500 57" Rear Projection...
Red ghosting on rear projection sony tv year 2002 how to fix
The model number is KP-53HS30, the screen is blurry displayin colors of red green pink
Jun 30, 2008 | Televison & Video
Sony 65 Inch Projection TV Color Red Green Separation
Sounds like a convergence issue. Call Sony for an ASC that can come out and give you an estimate. You are probably looking at $200-400 to do the repair.
Nov 02, 2007 | Sony KP-65WS500 65" Rear Projection...
Sony KP-53HS30 53" Rear Projection HDTV-Ready Television Logo
219 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
