Question about UPPAbaby VISTA Baby Gear
Bassinet stuck in frame backwards
I placed the bassinet in, locking in, in the wrong direction. Now it's stuck.
momsjustknow
  • 135 Answers
SOURCE: bassinet to seat
If you do not have your manual, go to www.bugaboo.com and download one. It will explain how the frame for the bassinet is used on the seat set up.
Good Luck! from Moms Just Know
Posted on Oct 29, 2008
Babycare_nl
  • 21 Answers
SOURCE: does quinny dreami bassinet fit 2005 buzz frame?
Yes, you can!
Basically, the design for the Quinny Dreami has not been changed since 2002. So any Quinny Dreami since 2002 will fit any Quinny stroller/pushchair since 2002.
With kind regards,
www.Babycare.nl
Erwin de Raad
Posted on Jun 23, 2009
  • 130 Answers
SOURCE: stroller broke in two places
U CAN USE A METAL SCREW WITH NUT ON OTHER END JUST FACE SCREW AND NUT OUTWARD ,U CAN FIND RIGHT SZ.AT HARDWARE STORE
Posted on Jul 15, 2009
  • 274 Answers
SOURCE: Compatible Parts for Bugaboo Gecko?
No the Gecko is a different size to the frog or cameleon, but you can ask any questions on bugaboos ask for Fred @ www.buggypitstop.co.uk they have all the answers and are very helpful
Posted on Apr 27, 2010
macnutz
  • 541 Answers
SOURCE: will the chameleon fabric for
No sorry. They are different sizes. The Cameleon set is the bigger so it could possibly be worked on to fit if someone was giving it to you but it would not be the best solution. Just find a Frog set on eBay.
Posted on Nov 15, 2010
Bassinet the first year model y3073
I need a replacement for the bottomof the 5n1 bassinet frame
Feb 17, 2013 | The First Years Carry-Me-Near 3-in-1...
How to put bassinet cover back on
It's easy. Hold the main skirt fabric and drop the pressboard support into the bottom with the feet/nubs down away from the inside. Now the metal frame drops in and next slide the hinged U supports outward. This raises the edges and gives height to the bassinet. The U supports either lock under a plastic clasp on the pressboard or sit into holes on the board. Now button down all the buttons around the interior or zip the zipper closed. Set it back on the frame and snap the bassinet to frame snaps on. Add the hood and baby's new, clean bed is ready for a lullaby. Good luck and you should be able to download a PDF version of the instructions from the maker. Just go to their site and search.
Aug 21, 2012 | Delta Luv Baby Gear
How do u conect bassinet to frame of quinny buzz
You need to get hold of a pair of adaptors - they are sold on Ebay. They slot into the Buzz frame and then the carrycot locks onto the adaptors. The adaptors work for the carrycot and the car seat.
Search for quinny buzz adaptors and you will see what I mean!
Aug 19, 2011 | Quinny Dreami - Black Bassinet
My bugaboo cameleon frame wont click on the chassis
The chassis must be fully opened out and the handle locked in position before the seat / bassinet frame can lock down on to it. The seat / bassinet frame is the safety lock keeping the frame ridged. You should see a square hole (made by two half squares from adjoining hub disks) at the top of the chassis hub assembly when fully open. A square pin under the seat frame must engage into it and the white release button must click. Your Bugaboo will not br safe unless this happens and you should contact the seller to help.macnutz_36.jpgmacnutz_35.jpg
Jul 10, 2011 | Bugaboo Cameleon - Tailored Fabric...
I washed the cover and can't recover the fame.Can you please get bagk with me today ,Mother and baby are coming home today.
Welcome to Fixya
Click here to view the instructions to assemble the Bassinet.
Click here to view the manual for your Bassinet.
You will need to carefully place the covers on the frame. Work out the correct orientation.
Then does it get strapped on or is it threaded onto the frame. I am not sure but you may need to slip the wire through the loops in the cover and then insert it into the bottom movement pinion.
You will need to remember a bit, of how you took it off and then work backwards.
Take care!
damnor01
Apr 23, 2011 | Kolcraft Cuddle 'n Care Bassinet
When the baby lays down on it the mattress part leans to to side.
If this is the Bassinet that rocks, there should be a set of locking slides at the top
where the bolts run thru connecting the bassinet to the frame. Slide the locks into
the groves and the bassinet should remain centered. If it is a different model please advise.
Mar 12, 2011 | Eddie Bauer Baby Gear
Once I have the cloth attached to the cardboard part can't figure out how to put it on the crib?
It's easy. Hold the main skirt fabric and drop the pressboard support into the bottom with the feet/nubs down away from the inside. Now the metal frame drops in and next slide the hinged U supports outward. This raises the edges and gives height to the bassinet. The U supports either lock under a plastic clasp on the pressboard or sit into holes on the board. Now button down all the buttons around the interior. Set it back on the frame and snap the bassinet to frame snaps on. Add the hood and baby's new, clean bed is ready for a lullaby. Good luck and you should be able to download a PDF version of the instructions from the maker. Just go to their site and search.
Mar 09, 2011 | Kolcraft Cuddle 'n Care Bassinet
Instructions for delta portable baby bassinet
May 09, 2010 | Delta Portable Baby Bassinet
Simplicity 4 in 1 bassinet
I need instructions to back together the 4 in 1 bassinet
Thanks,
Mary
Jan 05, 2009 | Simplicity for Children 4-in-1 Convertible...
Tilting bassinette
Hey momofila:
This may help:
While installing the bassinet fabric set onto the bassinet/seat frame, there are two Velcro straps that hold the bottom portion of the bassinet fabric onto the vertical connectors that attach to the chassis. You can find these if you follow the vertical connectors up from the ground (if the bassinet is sitting on the ground). They should be about 2 inches from the bottom of the bassinet on both sides. These Velcro straps hold the bassinet fabric onto the frame so the bassinet does not tilt. If these are fastened properly, and the bassinet is still tilting, you can take a photo of the problem and email me at strollerinfo@gmail.com. I will take a look at the situation and try and help more.
Hope this helps!
StrollerInfo
www.StrollerInfo.com
Jul 23, 2008 | Bugaboo Frog Stroller
Baby Gear Logo
278 people viewed this question
Top UPPAbaby Baby Gear Experts
Dorel UK
Dorel UK
Are you an UPPAbaby Baby Gear Expert? Answer questions, earn points and help others
