Question about Frigidaire GLTF2940ES Front Load Washer
Detergent drawer will not close and washer will not run.
Magnet fell to floor after removal of detergent drawer.Need to know where it goes.
  • 640 Answers
Pull draw out on right hand side fron you will see a little square recess,,,there a sensor on the in side of the main control,,if you cant seem to place take another magnet and place it on the side of control..and thats where to put the magnet
Posted on Jan 03, 2009
  • suenik1 May 06, 2011
    Thank you so much!!!! I spent two hours trying to take apart that whole tray and fit in the magnet after reading others' advice, and you explained it so simply!!!! My wash is now running. Thank you!!!!!!!!!!!!!!!!!!!!!
Pulled out detergent compartment and magnet fell out. where does it go machine wont run.
Welcome to FixYa.
The dispenser drawer on many Electrolux/Frigidaire built machines do require a magnet on the right hand side of it to activate the reed switch inside the console located there. It should fit in the bottom of the drawer, if you flip it upside down you should see it's intended location.
Let me know how you make out and I'll help further in any manner I can. Good luck.
Regards,
Macmarkus :)
Mar 04, 2011 | Frigidaire GLTF2940ES Front Load Washer
Washer is reading ddo. what does that mean?
Hi
Error DDO means dispenser drawer open. This error appears when the washer senses that the dispenser door is not closed. If the dispenser door seems to be closed then it seems to be an issue with the magnet. There is a little magnet attached to the right hand side of the detergent drawer which activates a reed switch & signals the washer that the drawer is closed. This magnet might have moved from its place and that's why you are getting error DDO. Pull the drawer out and check the handle part for a magnet. When the drawer is closed the magnet activates a switch in the console that tells the control the detergent drawer is closed. Hope this helps... Please post back if you need more information.
Daniel
Jan 13, 2011 | Frigidaire Washing Machines
Our magnet fell out, where does it go
If you are talking about a small, rectangular magnet, about a 1/16" think or so, it goes in the detergent dispenser drawer. Looking at the front of the drawer, right side, a little behind the front. This magnet triggers a ( or should if its not falied) a magnetic reed switch which allows the washer to operate only if the drawer is closed.
If you take the drawer out, and remove the front, you will see where it goes.
Apr 26, 2010 | Frigidaire GLTF2940ES Front Load Washer
Ddo problem
Hi
Thanks for using FixYa. Error DDo means dispenser drawer open. There is a little magnet attached to the right hand side of the detergent drawer which activates a reed switch to "tell" the machine that the drawer is closed. That magnet might have moved from it's place and that's why you are getting error ddo. magnet is part key number 51. Pull the drawer out and check on the handle part for a magnet. When the drawer is closed the magnet activates a switch in the console that tells the control the detergent drawer is closed. Please check this link for details(part #51)--
ftp://ftp.electrolux-na.com/ProdInfo_PDF/Webster/5995430112.pdf
You can glue the magnet back and the error will go way.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Aug 17, 2009 | Frigidaire GLTF2940ES Front Load Washer
Ddo error code on frigidaire front washer
Hi
Frigidaire exploded parts catalog
Thanks
Rylee
Aug 14, 2009 | Frigidaire GLTF2940ES Front Load Washer
The washer won't fill because the magnet fell out from the detergent drawer after being removed for cleaning. Where does the magnet go?
On the right side - halfway down the try - you'll see the witness marks.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jun 25, 2009 | Kenmore Washing Machines
Fridgidare Model #LTF2940ESO won't start Error Message DDO
The code means the detergent door is open. There is a magnet placed inside the detergent door cover housing that has probably fallen out. This magnet completes a circuit when the door is closed. It usually happens when cleaning the compartment and can usually be found stuck somewhere on the washer metal body itself or somewhere on the path you took while taking it to wash it out. Take the detergent tray out and dissamble it by pushing open the plastic tabs that hold it together. Look for the small 1"long magnet. If there isn't one. take your tray assembly to a repair dealer and have them put a new one back in. It is just a few dollars and your problem will be solved.
Mar 20, 2009 | Frigidaire Washing Machines
Frigidire front loader washer
The magnet goes on the front piece of the detergent tray. You must be getting a "DDO" (Detergent Drawer Open) error message. When you removed the detergent tray for cleaning, you probably also removed the white plastic (front) portion of the drawer from the darker plastic reservoir portion. That's when the magnet fell out. That magnet has to be in place for the washer to function properly.
It goes into the white plastic portion of the detergent tray. It is placed in the vertical position just inside the vertical wall of the front portion of the drawer on the right side (of the detergent tray) as you are looking at the washing machine. You really have to look for its' location, but with some effort you will see a vertical slot with "plastic retaining clips" which hold the magnet in place.
Hope you are successful but if not, post another problem citing details about what you have tried. I tried to post this message to you twice already, but the web site will not accept it for some reason. Perhaps they want you to purchase their "professional" (spelled expensive) service to resolve problems. We'll see.
Rascal
Feb 02, 2009 | Frigidaire GLTF2940ES Front Load Washer
Frigidaire + ddo error code
Excellent solution. I had a similar problem. The trick is to figure out where to put the magnet. I had a hard time with that.
For those like me who might have difficulty finding the spot for the magnet, it goes on the right hand side of the detergent door. The easiest way to do it is to pull the detergent door all the way out of the machine and look at it such that the back of the door is facing you. The magnet fits vertically in a slot on the left side as you are looking at the door (right side of the doorwhen inserted in the machine) in the white plastic. It sits vertically and is held by a small latch. This is not obvious at all...
Jun 25, 2008 | Frigidaire GLTF2940ES Front Load Washer
Magnet
if it's a small rectangular magnet that appears, in our case, fell out, when you add detergent, softener, etc...the magnet goes on the right hand bottom corner of the drawer face, straight up and down, not sideways. this is evidently some type of sensor allowing the washer to start. we had an error code of "ddo" when the magnet fell out.
Sep 04, 2007 | Frigidaire GLTF2940ES Front Load Washer
Frigidaire GLTF2940ES Front Load Washer Logo
133 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
