Question about SMC Barricade g SMCWBR14T-G Wireless Router (SMCWBR14TG)
SMC barricade g and timing out
I'm using adsl modem connected to the smc barricade g smcwbr14t-g router and my internet applications die out after a few minutes of use: internet explorer won't display all pages/pages information, telnet sockets will reset, and online games will freeze and i'll have to restart them. Any idea on what is wrong?
    President:
  • 2,961 Answers
Just a few things that can be checked, firstly in the routers settings look at the transfer speed of the router(not the connection speed) and see if it's set at 108MBPS, if so your wireless network cards on your pc's may only be able to connect at a maximum speed of 54MBPS, unless you have the latest 108 or 125MBPS g type cards. Secondly you should be able to check the wireless signal strength by the icon in your task bar or software you use, as if you have thick walls or objects in the line of the signal from router to pc's, the strength drops and can read low and therefore cause you to lose internet connection entirely. You can also try changing the channel at which the router runs, normally this is channel 2, but trying channel 11, which is the farthest away from appliance interference may give you better results, but both router and network card channel numbers will have to be changed.
Posted on May 13, 2007
SOURCE:
Tried to upgrade firmware. It accepted everything, I can connect locally through wireless. But the "Internet" status is constantly set on "Disconnected". I have reset the router,...
did you put the modem in bridge mode?
try plugging computer into to the modem to see if the internet is working
then add router to see if it has internet at the router. try pinging the router and the modem
Jul 04, 2017 | SMC Barricade g SMCWBR14T-G Wireless...
I have a belkin vision N1 modem router connected to the Internet by ADSL and I wish to connect to it a SMC Barricade N with a 20Meter cat 6 cable to improve wireless reception on the other side of the...
Can you clarify the problem?
Consdier first that both devices are NAT firewalls and your ISP probably only allows one address. So you would need to put one behind the other. This may not work like you plan. PCs behind the second will not be seen on the LAN by PCs on the first.
The N1 is a very good router. Consider relocting it to a more central location.
Another trick is to locate it near a central wall if it is block. By adding 1 remote antenna and drilling through that wall witha short antenna cable you can get much better coverage on the other side.
It could also be an ethernet problm 1. Power down SMC, plug WAN of SMC to LAN of router and power up SMC. If both devices show link lights and activity the hardware is OK. If not you need a "crossover" cable.
Hope that helps.
Oct 07, 2010 | SMC Barricade SMC7401BRA (SMC7401BRA-ADSL)...
Using the SMC100 Barricade as a Wireless Access Point
use the wrt310n router as the router for the internet (where dsl modem is connected) then just connect the ethernet port (not wan port or internet port) of the SMC to the ethernet port of wrt310n
Oct 31, 2009 | SMC Barricade SMC7404WBRA (SMC7404WBRA EU)...
No driver or internet
try checking www.opendrivers.com
if i'm not mistaken your driver could be found there
Aug 06, 2009 | SMC Barricade g SMCWBR14T-G Wireless...
Master_egypt85@yahoo.com
Username :admin
Password :barricade
OR
Username :smc
Password :smcadmin
Aug 14, 2008 | SMC Barricade SMC7401BRA (SMC7401BRA-ADSL)...
SMC Barricade g SMCWBRT14T-G router
You need to open the port that Utorrent is using check this link for the step by step way on how to do that on the utorrent and on the router http://portforward.com/english/routers/port_forwarding/SMC/WBR14T-G/Utorrent.htm
Hope that helps..............
Aug 08, 2008 | SMC Barricade g SMCWBR14T-G Wireless...
For SMC7904WBRA :: How to use Cable Modem on ADSL router/modem combo?
Did you have DSL prior? if so, was the MAC address cloned to the router? You may need to check that setting, its pretty common with this type of setup
Jul 29, 2007 | SMC Barricade g SMCWBR14T-G Wireless...
Looks like your device does not support playing router for cable internet. Would recommend you get an actual router, or alternately if you have a computer with two network adaptors you could plug one into cable modem, plug other in to LAN side of router, then configure turn Windows Internet Connection service, will need to disable the DHCP service on the router. I highly recommend you get a real cable/dsl router to do this tho. Linksys 54g series has been one of my favorites. Router homepage on SMC site. http://www.smc.com/index.cfm?event=viewProduct&localeCode=EN%5FUSA&cid=1&scid=4&pid=1588
Jul 29, 2007 | SMC Barricade SMC7404WBRA (SMC7404WBRA EU)...
SMC Barricade g SMCWBR14T-G Wireless Router (SMCWBR14TG) Logo
311 people viewed this question
Top SMC Computers & Internet Experts
Prashant M
Prashant M
J John
Are you a SMC Computer and Internet Expert? Answer questions, earn points and help others
