Question about Brother MFC-7440N Laser Printer
Brother mfc-9460cdn jam tray problems - Brother MFC-7440N Laser Printer
5 Suggested Answers
pineworks
  • 4041 Answers
SOURCE: problem paper jam printer brother no mfc-490cw
Hello there
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 27, 2010
reyjoshua07
  • 1157 Answers
SOURCE: Brother MFC 8460n paper pickup
Hi tkennedy0720,
Please follow these steps to assure you have made sure there is no jam.
1. Press the cover release lever to open the front cover.
2. Take out the drum unit and toner cartridge assembly.
3. Open the back cover.
4. Pull the tabs at the left and right hand sides toward you to open the fuser cover (1).
5. Using both hands, gently pull the jammed paper out of the fuser unit.
6. Close the back cover.
7. Put the drum unit and toner cartridge assembly back in the machine.
8. Close the front cover.
9. Press the cover release lever to open the front cover.
10. Take out the drum unit and toner cartridge assembly.
11. Hold down the lock lever on the right and take the toner cartridge out of the drum unit. Take out the jammed paper if there is any inside the drum unit.
12. Put the toner cartridge back into the drum unit until you hear it lock into place. If you put it in properly, the lock lever will lift automatically.
13. Put the drum unit and toner cartridge assembly back in the machine.
14. Close the front cover. Pull the paper tray completely out of the machine. Use both hands to slowly pull out the jammed paper.
15. Press the cover release lever to open the front cover.
16. Slowly take out the drum unit and toner cartridge assembly. The jammed paper may be pulled out with the toner cartridge and drum unit assembly, or this may release the paper so you can pull it out of the paper tray opening.
17. Put the drum unit and toner cartridge assembly back in the machine.
18. Close the front cover.
20. Put the paper tray firmly back in the machine.
21. Take out any paper from the ADF (automatic document feeder) that is not jammed. Open the ADF cover. Carefully pull out the jammed document to the left. Check for and remove any small pieces of paper stuck in the machine. A small piece of paper stuck in ADF will cause a document jam.
22. Close the ADF cover. Press Stop/Exit. If the Document is jammed under the document cover. Take out any paper from the ADF that is not jammed. Lift the document cover. Pull out any jammed documents to the right. Again, carefully check for and remove any small pieces of paper.
23. Close the document cover. Press Stop/Exit. If the Document is jammed at the output tray. Take out any paper from the ADF that is not jammed. Pull the jammed document out to the right.
24. Press Stop/Exit. If the Document is jammed in the duplex slot (only for machines which support Duplex printing). Take out any paper from the ADF that is not jammed. Pull the jammed document out to the right.
25. Press Stop/Exit. Make a Copy to test. Before placing your document(s) in the ADF verify the error message "Document Jam" in no longer displayed on the LCD. If the error message continues to appear on the LCD, please contact Brother Customer Service from "Contact Us". Verify the ADF document support (located on the top of the ADF) is pulled out. Verify the document(s) are between 5.8 to 8.5 in. wide and 5.8 to 14in. long. Make sure the documents are inserted face up in the ADF, top edge first. The ADF can hold up to 50 pages and feeds each sheet individually. Use standard 20 lb (80 g/m²) paper and always fan the pages before putting them in the ADF.
Note:
DO NOT use paper that is curled, wrinkled, folded, ripped, stapled, paper-clipped, pasted or taped. DO NOT use cardboard, newspaper or fabric. Make sure documents written with ink are completely dry. Adjust the paper guides to fit the width of your documents. This ensures the document(s) will feed straight, preventing jams. Make a copy listed below:
For MFC users :
Press Start.
For DCP users :
Press Copy located below the LCD and then press Start.
Hope it helps.
Thank you for using FixYa.
Posted on Jul 06, 2011
Daniel S
  • 4323 Answers
SOURCE: Brothers MFC-9460cdn papaer tray cannot
Hi
Make sure the paper tray is installed properly. Re-install the paper tray. Hope this helps...please post back for further assistance.
Daniel
Posted on Jul 10, 2011
SOURCE: brother mfc 9700 keeps jamming
Hi, maibe it is the cartidge, the pinions not working. Pull out the toner cartridge and replace with another, if you have. If not you must try to rotate the cilinder and see if work.
Posted on Sep 14, 2012
I just got a new computer with windows 7 and it doesn't have show the mfc9460cdn printer. I need to download the installation.
Brother Website should have the drivers and software for the printer. If it doesn't have the driver and software for Windows 7 then it is likely they have chosen not to support the interface. If this is the case you may need to try googling the driver and see if any bright sparks out there have made a driver to allow it to be used in Windows 7.
Aug 09, 2014 | Brother MFC-9460CDN - 25 PPM Multifunction...
2-sided scanning
HI Nada,.. Don't know what exact problem you're experiencing with 2-sided scanning. But from what I've gathered on your machine, it may not be capable.
Please find the attached software guide for a range of multi-purpose machines, including yours. Page 41 leads into that function being available on the MFC-9560. Double there and on page 130 to see if anything helps in clearing up your problem.
Good luck,
~AD
http://www.brother-usa.com/VirData/Content/en-US/MFC/Consumer/SoftwareUsersManual/SUM_MFC_9460CDN_9560CDW_9970CDW_EN_2718.PDF
Jun 26, 2014 | Brother MFC 9460CDN - Multifunction fax /...
What is print unable 40?
The message indicates HVPS (high voltage power supply unit) is faulty, replace it.
May 24, 2014 | Brother MFC-9460CDN Laser All-in-One...
WHERE IS THE INTERFACE CABLE? AND HOW IS IT?
I have a wifi printer and no cables. If you have cd prog, reload from begining then up date from website downloads or go straight to website and download latest update.
Nov 01, 2013 | Brother MFC-9460CDN - 25 PPM Multifunction...
What's your problem?brother mfc-j6710dw paper jam
I had problem with Brother MFC-J6710DW complaining about paper jam. Went through whole paper jam procedure a few times with no avail and no visible paper jam anywhere. Found (googled) this to be a common problem for this device. Turn off / on didn't help either.
Finally ... I followed procedure to the letter, bowed possible dust away and ... pushed tray 1 all the way in. (It turned out it was not all the way in when I first started troubleshooting, and was pushed to the same inadequate position subsequently.)
This MFC is low-cost. Meaning it has few sensors, and subsequently is not very precise reporting errors.
Remember: "paper jam" alert may mean something not on exact place it should be, with this otherwise (so far) good value for money MFC.
Mar 26, 2012 | Brother MFCJ6710DW All-In-One InkJet...
Brother MFC-8840D printer w/false paper jam indication.
With my Brother 8840D I have had paper jams that when cleared would not delete from the display nor would the machine operate until I unplugged the machine for around eight hours. I guess it is a sort of reset or reboot.
Jun 06, 2010 | Brother MFC 8840D All-In-One Laser Printer
My brother mfc-230c keeps saying "paper jam" and there is no paper jammed in the printer
this is an error that could get stuck in the memory, try removing the paper tray then unplugging and replugging the printer then when it's warmed up replace the tray.
if problem persists you may have a broken sensor
Sep 27, 2009 | Brother MFC-230c Printer
Brother MFC-7440N Laser Printer Logo
137 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
