Question about Linksys WRLS BRIDGE |WMB54G MUSIC R
Linksys WMB54G: No Connection Via the Software Utility
I can connect perfectly via both of my home computers wirelessly to the WMB54G at 192.168.1.1.121 using my browser (IE 7) but no matter what I try, I cannot get the Linksys WMB software to detect/recognize the WMB. Only when I connect the WMB via one of the ports on my WRT54GS via cable and run the utility does the software detect the WMB. I've tried reloading software, upgrading to the latest firmware, rebooting, adding IPs to my AV firwall, diabling wireless security, etc.. Nothing seems to work after I installed XP SP2 and a newer version of Norton AV. I've been at this for over a month! Anyone have any ideas? Thank you in advance!
Sincerely,
-Dave
  • david_jenkin Jan 03, 2009
    Sorry...my typing skills coupled with my terrible proof reading -- indeed, I intended to say that I have and continue to successfully connect via IE 7 on 192.168.1.1 but no luck connecting via the Linksys WMB Utility after the setup procedure.
  • jbelcourt Apr 17, 2009
    I am trying to connect to the WMB56G on a Vista machine and it doens't see the device. I worked with tech support and they had me send my device in on an RFA, but the replacement does exactly the same thing. From reading on the web, seems this is a common problem. Installed as Admin and in XP compatible mode. Still no connection with the utility. HELP
The problem is that might be the 121. I would try using the hightest IP address your router will allow. Mine was 192.168.1.190 chance of a conflict less likely. I would also try pinging the bridge's address from using the dos box and typing in ping 192.168.1.121 if the bridge doesn't respond it is no longer working. The ping can be done when connected to the ethernet port or wirelessly. If the ping fails most likely the bridged is fried in that case phone linksys tech support the will try to set it up if they are unsuccessufl they will give you a case number after the have determined it is not functioning. Make sure the tech get the case number from the supervisor. Then you go to the Linsys wmb54g page and click on the request for an RMA and follow the instructions. If you if is still under 3years you will get a replacement. That is why you always regester your product with linksys. If you haven't I suggest you do that then phone tech support and go through the grueling steps to get an RMA (return merchandise authorization). Pain but better that than a $90 doorstop.
Posted on Aug 28, 2009
You stated that you have the latest firmware installed, you must also load and use the latest software to be compatible with the new firmware. The Linksys site has both of these downloads. Be sure to remove all the old software before the new load. If you are still having problems read through the tutorial on this site. Hope this helps
http://forums.linksys.com/linksys/board/message?board.id=Media_Adapters&thread.id=35&view=by_date_ascending&page=1
Posted on Mar 04, 2009
  • Linksys Master
  • 32,281 Answers
It appears the configuraion IP address you are using is wrong it should be 192.168.1.100 or 192.168.1.1
Posted on Jan 03, 2009
Have 2 computer's in home, on will link t network, other will not even bring up network when attemptingto get on internet via router
Usually under these circumstances, one of your computers may not have a compatible wireless network card. An example would be if your computer has a Wireless G Network Card and your router is Wireless N, you might run into problems. You can try reinstalling the drivers for your Network Card. You can also go to the Linksys website and install the installation utility to set up the connection from scratch again.
The router itself is fine, it's the wireless card in your computer that isn't finding the router.
Jan 22, 2011 | Linksys Wireless-G WRT54G Router
Another application is controlling the wireless adapter
I believe you are using WINDOWS XP.
In case of windows XP, there might be 2 different wireless utilities can control your wireless adapter.
First utility is the manufacturer's utility. If you have Dell wireless adapter then you can use Dell utility to connect to the network.
Another utility is Window's utility. You are getting the error message in this utility because your computer is using another utility.
To use window's utility you will need to start the " wireless zero configuration ".
Click Here
for more information about wireless connection
Feb 22, 2010 | Linksys WRT54GX2 Wireless-G Broadband...
The linksys utility always sends signal to PC speakers, even when wmb54g unit shows connected. The wmb54g and router are up-to-date and run WEP 128 security encoding. The wmb54g flashes faster when...
I can disable the sound card, set the music bridge as the default sound output device and it works just fine (after rebooting). But if I enable the sound card again, even when keeping the music bridge as the default, the sound goes exclusively to the PC speakers, no matter what device the connection is switched to on the Linksys utility. (By the way the music bridge shows correctly to be connected or disconnected....with no effect on the sound output.) The major hassle is that any usable change of output device requires a reboot. Still testing. Not a single answer from the community. Also I never required the promised temporary password.
Dec 25, 2009 | Linksys WRLS BRIDGE |WMB54G MUSIC R
Can't get wireless connection from PC to Linksys WRT160N
To setup a wireless connection on a computer, the wireless card in the computer needs to be configured with the wireless router's settings.
For instructions click on this link :-
http://www.fixya.com/support/r3559128-wireless_router_security
Dec 11, 2009 | Linksys WRT160N Wireless Router
I upgraded to windows 7 and now my linksys (WMB45G) wireless music bridge software utility doesnt seem to work anymore
It seems like a driver incompatibility issue. You may be need to contact linksys and see if they have a modern driver
Nov 27, 2009 | Linksys WRLS BRIDGE |WMB54G MUSIC R
Cannot connect lap top or printer wireless and also connect to the internet via AT&T motorola modem
yes. Here is Linksys' page on how to:
http://linksys.custhelp.com/cgi-bin/linksys.cfg/php/enduser/std_adp.php?p_faqid=3687
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Apr 12, 2009 | Linksys Wireless-G WRT54G Router
Unable to access the internet via my laptop
One of two problems. The Security Key for your wireless connection is wrong, or the McAfee is causing a problem. Most likely conflicting with any other virus software on your computer. Try removing McAfee from the computer and your solution should go away. Try another virus software such as Avast! Home edition. McAfee is known for having issues with wireless internet connections.
Gary
Jan 25, 2009 | Linksys Wireless-G WRT54G Router
Wmb54g and apples
The utility needs to be installed in a computer in order for you to use the WMB54G and it will only work with windows version. You can't use it on a MAC computer.
Jul 10, 2008 | Linksys WRLS BRIDGE |WMB54G MUSIC R
Actiontec GT704-WG wireless connection not working
you say it suddenly stopped working, if you can connect to the router via ethernet cable then try to access the router's web utility page and make sure your router is in mixed or G-only. If you can't still connect to the router through wireless then try restarting the Wireless Zero Configuration from windows. This is how it's made: Go to control panel and double-click "administrative tools", then double-click "services". You will see a list, scroll down to Wireless Zero Configuration and click "stop", you'll see a progress bar. After that click "start", you'll see another progress bar. Now try connecting to your router via wireless connection. If you still can't connect then repair the connection by right-clicking the wireless icon at the bottom right corner. Keep repairing until you connect.
Hope this works!
Feb 16, 2008 | Actiontec GT704WG Wireless Router...
Dropped connection
Step 1:
Connect the Wireless-G Music Bridge to your router using an Ethernet cable. For instructions, click here.
Step 2:
Access the Wireless-G Music Bridge’s web-based setup page. For instructions, click here.
Step 3:
When the Wireless-G Music Bridge’s setup page appears, scroll down to the Wireless section and look for Wireless Mode and select Infrastructure.
Step 4:
Look for the Wireless Network Name (SSID) field, enter the wireless network’s SSID.
If this doesn't work let me know
Aloha
Bob
Dec 13, 2007 | Linksys WRLS BRIDGE |WMB54G MUSIC R
Linksys WRLS BRIDGE |WMB54G MUSIC R Logo
1,869 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
