Question about GE 24 in. GLD5500L Built-in Dishwasher
Light wash and heated dry lights blinking, no reponse from others
Dishwasher lights blinking, cant' get any other functions to illuminate. Dishwasher locked up. I cycled power for 30 seconds and 5 days, not solved.
Dishwasher was running, then pushed buttons and opened/closed in middle of cycle. Ever since, we've had the "light wash" and "heated Dry" lights blinking.
  • 2 more comments
  • paulpellegri Jan 03, 2009
    I also tried a multitude of button push combinations as well as holding the heated dry button for 5 seconds. Nothing resolved. The system also beeps about every couple of minutes. I looked for a tech sheet underneath and behind door skin, found nothing.
  • paulpellegri Jan 04, 2009
    Holding the reset button did not clear issue. We do not have a "clear" futton. Any other suggestions?
    Holding latch switch and pressing reset did not clear issue
  • paulpellegri Jan 05, 2009
    Yes, very helpfull. After being told the door latch switch wasn't recognizing the door was closed, I dug deeper and found the actuator moving too freely due to a broken tap on the door switch housing lid, allowing the actuator to slide of the switch button. I am off to finalize the repair to secure cap. Thanks for the great help and quick response!!
    Sergeant:
    Champion:
  • 338 Answers
Try going back and forth from heated dry to air dry. if your control doesnt reset then you need to replace your touch panel.
Posted on Jan 04, 2009
    Genius:
  • 2,120 Answers
Your dishwasher thinks that the door is OPEN
The microswitch in the door lock assembly is not being tripped. It is stuck in a cycle.
Turn off the water supply, open the door SLIGHTLY, stick your pinky finger in the slot where the latch locks the door then press RESET once and let it run it's reset cycle.
  • Leroy Elliott
    Leroy Elliott Jan 04, 2009
    Actually TRY soution #2 again. I have the same dishwasher and have cured this problem 4 times.
    President:
  • 2,110 Answers
It sounds like you will need a new control assembly
Posted on Jan 03, 2009
  • Sibananda Jena
    Sibananda Jena Jan 03, 2009
    You can try a hard reset,turn off the breaker that powers the dishwasher for 15sec.see if that helps
    Sergeant:
    Novelist:
  • 326 Answers
Press clear button for 5 seconds to unlock ur machine.
Why is heated dry blinking?
FIXED Kenmore dishwasher lights flashing: "Hi Temp" & "Heat Dry ...
www.applianceblog.com/.../40588-Kenmore-dishwasher-lights-flashing-...
Aug 26, 2013 - 10 posts - ‎3 authors
Thread: Kenmore dishwasher lights flashing: "Hi Temp" & "Heat Dry" ... A few months ago, we had a brief power outage and the next morning, noticed the "Hi Temp" and "Heat Dry" lights were flashing. ... Well since then, the dishwasher intermittently stops mid-cycle and these same lights ... Thread: GE Eterna QuietPower 2 Normal and Heated Dry ...
Feb 24, 2012
Kenmore Elist 665 dishwasher Smart Wash red light ...
Dec 23, 2011
Heated dry blinking +17 times - ApplianceBlog
Nov 14, 2010
Heated Dry light blinking
Nov 7, 2010
More results from www.applianceblog.com
Why won't my dishwasher start and why does the "Heated Dry"
www.shopyourway.com > Manage My Life > Questions
Nov 16, 2009 - When I hold down the Heated Dry button to turn the control lock on it ...my dishwasher start and why does the "Heated Dry" light keep blinking ...
Dec 01, 2015 | Dishwashers
Green light is blinking --says clean when you push
Hello & Welcome to FixYa
Flashing green light is reset by pressing two buttons in sequence 3-4 times, to reset your dishwasher press these buttons in sequence:
High temp wash-heated dry-high temp wash-heated dry
Please get back to me if you have any other questions.
Kevin
Jun 10, 2011 | Kenmore 16764 Dishwasher
Blinking "Normal" light on a Maytag model
Hi
Open the door. Within 3 seconds press the following sequence --Try pressing normal wash, heated dry, normal wash, heated dry, normal wash, heated dry three times within 6 seconds and then press cancel to reset the dishwasher. If that doesn't help then try pressing Saini Rinse, Heated Dry, Saini Rinse, Heated Dry, Saini Rinse, Heated Dry or Saini Rinse, Air Dry, Saini Rinse, Air Dry, Saini Rinse, Air Dry 3 times in 6 seconds and then the Cancel Button. Close the door and press Cancel.
Blinking lights would stop and should be able to use your dishwasher normally. If the light is still blinking try and reset the power to the dishwasher and try again. If still the light is blinking then check for the connections on the keypad, it may be due to moisture or shorted connections on keypad.
Hope this helps... Please post back if you need more information.
Daniel
May 19, 2011 | Maytag Dishwasher
Talking about a kenmore 665.16389300 dishwasher. the "normal wash" button is blinking, but none of the other buttons seem to work and the cleaning cycle will not start when i press the...
Hi
Blinking lights would stop and should be able to use your dishwasher normally. If the light is still blinking try and reset the power to the dishwasher and try again. If still the light is blinking then check for the connections on the keypad, it may be due to moisture or shorted connections on keypad. Hope this helps... Please post back if you need more information.
Daniel
May 18, 2011 | Kenmore Dishwashers
Light is on for heat dry but won't allow me to run a cyle or turn on
Hi
Daniel
Apr 17, 2011 | Frigidaire Professional Series 24 in....
Clean light is blinking and I cant start a new cycle
Flashing clean light is reset by pressing two buttons in sequence 3-4 times, to reset your kenmore press these buttons in sequence:
Kevin
Jan 03, 2011 | KitchenAid 24 in. KUDP01DL Built-in...
Control clean light keeps blinking and dishwasher will not function
Your dishwasher will do this as a safety in case the element is broken and feeding electrical current into the water. Sometimes just a false reading.
Reset your console by pressing: high temp wash, heated dry, high temp wash, heated dry
When all the lights are on you are set in diagnostic mode. Just hit cancel a you will be able to run your dishwasher as normal.
If this same light appears again then you have a bad element or thermostat.
Dec 06, 2010 | Whirlpool Gold 24 in. Built-In Dishwasher...
Blinking clean light, will drain with cancel button,wont wash
Hi
Thanks for using FixYa. If the clean light flashes, pauses, and then repeats. When the dishwasher doesn't sense a water temperature increase, it stops working and locks the functions (clean light flashes, all buttons are non responsive). It does this as a safety in case the element is broken and feeding electrical current into the water.
To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
May 26, 2010 | Kenmore 13853 Stainless Steel Dishwasher
The rinse only light blinks and no other buttons will function - is there a way to reset the dishwasher?
hi temp wash and heated dry toggle till all the lights light up try this. if this does not work let me know
Oct 18, 2009 | KitchenAid 24 in. KUDC25 Built-in...
Watch the light closely. If it blinks 7 times then pauses, this indicates a heater or door latch issue.
Press the following buttons in sequence: Hi Temp Wash, Heated Dry, Hi Temp Wash, Heated Dry.
If this doesn't work, check the tech sheet. (should be stuck to inside of the bottom toe panel)
All lights should illuminate then a diagnostic sequence will start.
Listen carefully, as soon as you hear the water begin to fill, open the door and feel the heater. if cold, check the heater for continuity (should be around 10ohms)
Also, bend the door catch on the dishwasher tub downward, this will engage the door latch better. Don't bend too far as it will hit the door while closing.
Jun 15, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
GE 24 in. GLD5500L Built-in Dishwasher Logo
199 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
