Question about Dell Alienware Computers & Internet
Ac adapter beeping
Bought a new chager for my laptop and the charge is beeping
    Novelist:
    Champion:
  • 233 Answers
There are a few things you may check why the laptop charger keeps beeping. Click the following link to get details:
http://www.chargerbuy.com/blog/laptop-charger-beeping/
Posted on Oct 29, 2012
map9966
  • 2351 Answers
SOURCE: Toshiba M115 S3094 Battery Probelm
Your battery not able to hold a charge is a bad battery.
Love your precise description & diagnoses. Wish others would describe their troubles as well as you!
Have a great day!
Posted on Mar 14, 2008
  • 1150 Answers
SOURCE: The AC Adapter makes a beeping noise and doesn't charge the batt.
I would verify that the battery will take a charge. If the battery is bad, the charger will tell you that it is not charged. It will not tell you why, just that it is not charged. If not plugged into the computor,again, battery is not charged. Hence, the beep.
Good Luck and hope this helps.
Posted on Mar 15, 2009
ruben_barrer
  • 117 Answers
SOURCE: AC Adapter is beeping
the best would be ebay. type in your model number and you should find a compatible version. i dont recommend the universals, they dont show up on certain computers correctly such as dells. most charges retail on ebay for about 16 bucks. if you want it fast. get it overnighted. still will be cheaper than anything you buy in the store..
heres a link
http://shop.ebay.com/?_from=R40&_trksid=p3907.m38.l1313&_nkw=acer+aspire+charger&_sacat=See-All-Categories
good luck!
ruben
Posted on Jul 13, 2009
  • 1481 Answers
SOURCE: My Dell 5160 laptop slows down with the AC adapter plugged in.
try running ur laptop using the adaptor without the battery in it's place and run it with just the battery...note the difference....it may be a power surge/short issue....some times the battery is supplying power along with the adaptor to the notebook and the power circuit in there is not able to take dual power....check your power options setting in Control Panel...
also do this
clean ur system use Tuneup Utility get it from my website Dowload page
www.sureshayyar.110mb.com
use all the tools and option in that tool...the best is 1n Click Maint in there .....it fixes all ur issues...
Posted on Dec 29, 2009
SOURCE: Gateway laptop will not charge battery.
I have a new gateway laptop with windows 7 and today it said plugged in not charging 8%. I tried everything and nothing worked so I turned it off and unplugged it and took the battery out and put it back in and it started charging...hopefully this works.
Posted on Jan 09, 2010
I have a Toshiba Portege M780. My AC is plugged in and with battery but indicator(Orange) blinks several times and pauses, and then does it again. It will not turn on. How can I fix this?
If your laptop won't turn on with the AC adapter plugged in, I'm afraid you've got some serious problem with your motherboard.
Of course, the problem might be your battery burned out, so to test, remove the battery and plug in directly your AC adapter. No problem to do that, people use laptops with onlt AC adapter, without battery, to save battery life.
Did it turn on? if it did, buy a new battery, that should solve the issue.
If not, you should check if your AC adapter works. You need an electronic voltimeter/amperimeter and you should check output rating. It it is the specified, your charger is ok and the problem is in your laptop, you should take if to repair service.
Once again, if the problem is with your charger, get a GOOD charger, and test if you can charge your battery. Also, with a good chager and no other problem, your computer should power on.
Oct 08, 2015 | Toshiba Computers & Internet
Batterry plluged in not charging
Buy a new AC chager the cables wear out .I have now bought 3 in 4 years.Ebay about 6 pounds.
Aug 17, 2012 | HP Computers & Internet
Toshiba battery charger pa3468u-1aca for satellite L305-s5944 is beeping and the unit is not charging, what is wrong?
Probably a failed AC adapter. Please try to charge the laptop with a good, working AC adapter & see if the problem disappears.
Jun 12, 2011 | Toshiba LAPTOP AC Adapter Power Charger...
My toshiba satellite l300 suddenly not charging. might be the loose power jack, battery or the charger... how can i check which of these is the root cause?
Does the laptop work on the ac adabpter? If it does, you probably require a new battery. Ebay will be the cheapest source of original and copy batteries.
If it doesn't, you probably require a replacement ac adapter, Ebay again.
Hope that helps.
Jan 20, 2011 | Toshiba Satellite Pro L300 Notebook
Battery charger not working. Power adapter checks out ok. Laptop operates on battery only. 7325gz.
if it is not charging the battery will go dead.soo recharge it if it doesnt work then it could possibly be your charger.but alot of times the soldier on the input plug becomes loosened and doesnt get a connection. how did u check the chager
Oct 10, 2009 | Gateway 7325GZ Notebook
Toshiba Laptop Wont Boot.
yes,if the battery doesn't charge with the ac adapter or turn on with it pluged in.it is common on comuters for the power adapter on the motherboard to go bad after a while.downfall of the laptop is that it is very hard to replace it(desktop easy because it is not built into the motherboard)you can either buy a new motherboard or a new laptop.if you got any more questions feel free to email me at gamecrazy944@yahoo.com
Aug 03, 2009 | Computers & Internet
Mar 15, 2009 | Toshiba Portege R100 Notebook
My ibm laptop contionusly beeps and says power scource is battery,when i press esc, it boots normally and shuts down in about 15 mins to half an hour
Either:
A. Bad battery
Or
B Bad power supply.
Sounds like the battery isnt charging correctly , the beeping is warning you it is running out of power.
Take the battery out , and boot normally with the ac adapter.
Does it work?
If yes, Get new battery. about 70-90 dollars.
If no. Get new ac adapter. 20-40 dollars.
links to parts
http://www.nextag.com/ibm-a21m-battery/search-html
http://www.nextag.com/serv/main/buyer/OutPDir.jsp?search=ibm+a21m+ac+adapter&x=0&y=0
http://www.laptopuniverse.com/product/02K6496-Laptop-Notebook-Power-Supply-AC-Adapter-For-IBM-Lenovo-Thinkpad-A21M-16V-60W-Part-02K6496/LU/36124/productDetails.html
Mar 03, 2009 | IBM ThinkPad A21m 2628 Notebook
My laptop battery won't charge
possible when the old AC adapter blew it took part of the power management circuit with it, This is the circuit that detects and charges the battery, I'm not sure whether this a seperate replaceable daughter card or whether it is part of the main motherboard. you will need to investigate this (or send it for a service)
Oct 09, 2007 | Dell Inspiron B130 Notebook
Computers & Internet Logo
49 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
