NetGear N300 WNR2000v3 stops broadcasting SSID every few hours.
I bought me a new NetGear N300 WNR2000v3 the other day but every few hours it stops broadcasting the SSID. All connections, bother wired and wireless, will lose their connectivity and the connection disappears from the WiFi list. The only way to bandaid this problem is to unplug the router and plug it back it. It happens on average of 5 times a day. I've tried changing security settings, I've tried changing wireless channels, I've tried repositioning the router across the room, I've tried upgrading the firmware -and- downgrading to previous versions, I've tried resets and power cycles, and I have tried using the troubleshoot features on every laptop connecting to it. (Three of them.) When the connection is active, the signal is excellent and the speed is wonderful. But every few hours it will suddenly drop and everyone loses connection. The wireless light remains active green as if it still has internet, but it doesn't show up on anyone's laptop nor does being wired with an ethernet cable provide any connectivity until after it is unplugged. From thorough research online, it appears that this specific model of NetGear routers has affected many users with no solutions. What can I do to fix this, without having to go back out and buying a different one?
4 Suggested Answers
sandrew
  • 2961 Answers
SOURCE: Issues with the BR-6114WG
Depending on how your router is set up, it may be a DNS problem. Start from beggining and make sure your router is enabled for wireless, wep or other encryption is off, DHCP is enabled for assigning IP addresses automatically. Run this programme on pc's, click Start>run then type ipconfig /flushdns then press enter. Clean out your old cached and temp files. Go to your wireless adapters properties and ensure that they are set to obtain ip address automatically in TCP/IP settings. Restart systems and hopefully you are away. Every time you use windows to repair the connection it will try to re-new IP addreses, but it won't be the one your router uses, so don't use it, as you will lose connection to the router.
Posted on Jan 31, 2007
  • 112 Answers
SOURCE: Issue with router and ethernet cables
I imagine you reset/unplugged all of your routers, switches, and computers, starting with your modem, then router, and then each system?
There is a setup disk that need to be used to program your router with the ISP settings, passwords, and protocols for port forwarding, etc. I imagine you tried that.
Did you try all of your cables to make sure they weren't defective?
If you tried these,and the problem persists, the issue is a defective router. By default, the unit should transmit a wireless signal, and be ready to act as a routing switch for your other systems.
Posted on Mar 26, 2009
  • 143 Answers
SOURCE: Hi I keep losing internet
http://techpaul.wordpress.com/2008/04/08/how-to-fix-a-lost-internet-connection/
Posted on Jul 11, 2011
What is the ssid #
How to Locate a Router's SSID and SSID Broadcast Setting
Applies to: Wii U Deluxe, Wii U Basic, Wii, New Nintendo 3DS, New Nintendo 3DS XL, Nintendo 3DS, Nintendo 3DS XL, Nintendo 2DS, Nintendo DSi, Nintendo DSi XL, Nintendo DS, Nintendo DS Lite
Published ' Updated --> Step by step instructions on how to locate your router's SSID and broadcast settings.
Note:
Was your router provided by your Internet service provider? If so, before continuing check for a sticker on the bottom or side of the router that has the default SSID printed out. This is usually labeled as the SSID or "Network Name" and may be located next to a barcode.
What to Do:
  1. Log in to your router's settings. How to
  2. Search through your router for phrases such as SSID or Wireless Network Name. The terms and locations can change from router to router. Below are examples for common router brands:
    • D-Link:
      You can typically find the SSID by selecting the "Setup" option, and then "Wireless Settings."
      Enable SSID broadcast by selecting "Visible" for the "Visibility Status."
    • Netgear:
      You can typically find the SSID by selecting the "Basic" settings option, and then selecting "Wireless Settings." The SSID may be labeled as "Wireless Network Name."
      The option to enable SSID Broadcast is often located by selecting "Wireless Settings" under the "Advanced" settings.
    • Belkin:
      You can typically find SSID by selecting the "Wireless" tab and then selecting the "Channel and SSID" option.
      The option to enable SSID broadcast is located here as well.
    • Linksys:
      You can typically find the Network Name (SSID) by choosing the "Wireless" tab, and then "Basic Wireless Settings."
      The option to enable SSID broadcast here as well
If you require additional assistance locating your router's SSID settings, please refer to your router manual
Oct 07, 2015 | Nintendo Wii Console
What is Router name or SSID
It is what the router broadcasts so devices can find the connection. For example, when you are using a laptop or smart phone you can check for available WiFi connections. The SSID for all connections in range will be listed. The SSID enable you to find your router on the list.
Aug 21, 2014 | Linksys E900 Wireless N300 Router
How do I set the network in my netgear N300 for my laptop?
Visit http://www.routerlogin.com. You can also use the following if the http://www.routerlogin.com does not work: Enter the following default login credentials:
  • Username: admin
  • Password: password
Then go to Wireless and chose Name (SSID): and Passphrase :
Jul 04, 2014 | NetGear N300 Wireless Router
How can i install netgear genie n300 if i lost installation disk, i need to install netgear genie n300 wierless usb adapter to my windows 7 pc
This page: WNR2000v3 has Genie user manual, Installation guide, and the setup guide. It's the support page for Netgear.
Jun 20, 2014 | Computers & Internet
N300 wireless router
If you are just looking for the SSID and the password on a NETGEAR router, then all the information should be on the side of the router itself. Most times the SSID are NETGEAR07 or something like that and the password should be right beside that.
May 12, 2014 | NetGear WNR2000 Wireless Router
How to uninstall my router?
Can you be a bit more clear? I don't understand? You want to reconfigure the SSID and Security Key? You want to remove the SSID in the computer software so it will not auto connect?
Mar 28, 2013 | NetGear N300 Wireless Router
Netgear DGN2200 wireless issues
Check the DC supply from AC supply or try to replace the AC DC power your Netgear
Sep 17, 2017 | NetGear DGN2200 Refurbished WirelessN N300...
How do I password protect my NETGEAR N300 WNR2000 from outside connection?
Connect a LAN cable from the Netgear to the LAN port on yourcomputer, open a browser and enter the Netgear configuration URL -
http://192.168.0.1
The default login = admin
The default PW = passwordYou can now change the default admin password and configurethe wireless settings.
Go to the wireless configuration and set up the SSID and WPA or WPA2encryption.
Apply these settings to the wireless card in your laptop/computer.
To secure your wireless network from unauthorized access, please click on thislink and follow my instructions :-http://www.fixya.com/support/r3559128-wireless_router_security
Mar 16, 2012 | NetGear N300 Wireless Router
Cannot find security key for netgear N300 wireless router WNR2000v3
You will ahve to connect by wire to the router and go to the section for wireless security and see what it is set to. If asked for a User and Password and you know it was never set the the default is one of these combinations:
User: admin
Pass:password
User: admin
Pass:administrator
User:password
Pass:password
If none of these work you can try using the master reset which should be on the backside and usually requires a toothpick to press. If you do this you will need to redo all the settings because it will erase them.
Jun 28, 2011 | Computers & Internet
Computers & Internet Logo
117 people viewed this question
David Payne
David Payne
