Question about HP Photosmart C8180 InkJet Printer
Error code 0cx18a0301 shows after changing one ink cartridge. I can't even turn the printer off to try to reset
agnelkj
  • 210 Answers
SOURCE: inkjet refills
hi,
as you are using a refilled cartridge, it is causing this problem. the thickness of ink in a hp genuine cartridge and a refilled cartridge varies. and also the refilled cartridge may make your printer faulty. so it is good to try with a new hp genuine ink cartridges.
thanks and regards
agnel
Posted on Mar 18, 2008
faishortcake
  • 12 Answers
SOURCE: Expired ink cartridge
You may be getting this error message due to the printer being able to tell that it is a non-hp cartridge. I don't know how it can tell, but mine says that too. I uninstalled the software and then reinstalled the software. And then I took out the cartridge and put it back in. See if this works for you.
Posted on May 14, 2008
yooperbud
  • 8637 Answers
SOURCE: the ink system has failed
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 27, 2009
pineworks
  • 4041 Answers
SOURCE: This is for an HP Photosmart 3310 all in one. The
Reset the product:
  1. Without turning off the product, disconnect the USB cable from the rear of the product.
  2. Remove the cartridges from the product.
  3. Wait for the 'Insert Cartridges ' message to display on the control panel.
  4. Disconnect the power cord from the back of the product.
  5. Wait 60 seconds.
  6. Reconnect the power cord. If the product does not automatically turn on, press the Power button (c01602202.gif ).
  7. Reinsert the cartridges, and then close any open doors on the product.
  8. If you receive a prompt to print a calibration page, do so.
  9. Reconnect the USB cable to the rear of the product, and then try printing again.
Posted on Jan 25, 2010
SOURCE: HP C6188 ink system failure
hp C6188 PRINTER ERROR 0XC18A0106
Posted on Oct 29, 2010
Error Code E05 Canon MP258
Error Code E05 Canon MP258 may solve by the following steps.
1. Press Stop/Reset button for 5 seconds.2. After five seconds release the button.3. Now your printer will start its process and it is ready to use... thanks
Sep 25, 2011 | Canon Pixma Mp250 Allinone Inkjet Photo...
It says i have a automatic alignment problem it shows i have ink i have'nt changed the ink since i brought the printer.
It could be that the cartridges are not seated properly in the cartridge carrier or the encoder strip got unseated from its position. Please follow steps below to fix the problem:
  1. Open the printer cover.
  2. Remove both cartridges from the printer.
  3. While the printer cover is open, check the cartridge area for a loose encoder strip (transparent strip).
  4. Close the printer cover.
  5. Unplug and re-plug the printer into the power source to reset it.
  6. When the printer turns on, re-insert one cartridge first.
  7. Close printer and check for any errors.
  8. If no error appears, reinsert your other cartridge.
  9. Replace whichever cartridge is causing the error to appear with a new cartridge.
Jul 25, 2011 | Lexmark Z2420 Printer
Error code U052. I know this has to do with the chip in the ink cartridge. I changed all cartridges and still the same code. I cannot use any function on this MP530 with this error code.
Please remove all cartridges. Using a moist cloth clean the golden contacts on cartridge as well as printer. DO NOT touch nozzle of cartridge. Dont insert the cartridge yet.
Please do this :
1. Remove the power cable from printer. Remove the USB cable that connects printer to computer (remove it from printer as well as computer's usb port)
2. Press the printer power button and keep pressed for 3 minutes then release
3. Now plug in the power cable and usb cable (connect printer to computer) and power on the printer.
Now insert cartridges and see if error goes away.
Do not forget to rate my answer.
Jul 06, 2011 | Canon PIXMA MP530 All-In-One InkJet...
I changed my ink but it wont let me print it keeps saying i need to change my ink why?
What is the version of your ink cartridge? It could be that it's not seated properly in the cartridge carrier. Open the printer cover and remove the cartridges. Close the cover. Unplug and replug the printer into the power outlet in the wall to reset it. When the printer turns on, open the printer cover and reinsert one cartridge first. Close the cover. If no error, open the printer cover and reinsert the other cartridge. Replace whichever cartridge is causing the error to appear. You could also try to insert a different known working cartridge to determine if the other is faulty.
May 19, 2011 | Lexmark Z2300 InkJet Printer
How di I reset my Pixma printer MP150 from
Use this method with your own risk!!
E2-2 = No paper (ASF)
E3-3 = Paper jam
E4 = No ink
E5-5 = The ink cartridges are not installed or a non-supported ink cartridge is installed, or the ink cartridges are not installed properly
E8 = Waste ink absorber full, or platen waste ink absorber full
E9 The connected digital camera / video camera does not support Camera
Direct Printing
E14 The Ink cartridges whose destination are wrong
E15 Ink cartridge is not installed E16 - Ink remaining is unknown
E16 -E19 Failed to scan head alignment sheet
E22 Carriage error
E23 Paper feed error
E24 Purge unit error
E25 ASF(cam) sensor error
E26 Internal temperature rise error
E27 Waste ink absorber full or platen waste ink absorber full
E28 Ink cartridge temperature rise error -
E29 EEPROM error
E33 Paper feed position error
E35 15 USB Host VBUD overcurrent error - USB
E37 17 Abnormal motor driver error
E40 20 Other hardware error
E42 22 Scanner error
Reset E27 Waste ink absorber full or platen waste ink absorber full
First way
turn off printer.
- put your finger and hold on/off with reset/stop button together
- turn on printer power switch
- release on/off button but in the same time still hold stop/reset button and then press on/off button again and hold.
- wait at the moment
- relese stop/reset button 2X.( your will see alarm led blingking for 2X)
- relese on/off button.
wait until your printer digital screen shows number 0.
- after printer panel screen shows number 0.
- press reset button 4x
- press on/off button 1x
wait until your hear printer roller is moving
after your hear roller moving, wait until your dont hear anything from your printer :)
then turn off and turn on your printer again and your will see your printer back to normal.
Second Way
turn off printer.
Good Luck
Jul 18, 2010 | Canon Office Equipment & Supplies
I changed my catrige but its showing the error E5
I use refilled cartridges. Okay, the printer says ink low, but it does that all the time. I ignore it. However, yesterday it printed not a problem, today it gives me code 5. Does anyone have a real solution or should I throw the printer away?
Jun 08, 2010 | Canon PIXMA MP160 All-In-One InkJet...
On the screen show 5e
Procedure to reset Printer canon MP145, MP150 and Canon MP160 with Error Code Message for Printer Canon MP145 and Canon MP160, you can find error code message the end of this post:
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding the Stop/ Reset button.
2) When the Power is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a service mode. (Waiting for menu selection)
4) When the on/off lights in green, press the Stop/Reset button the specified number of time(s) according to the function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in orange and green, starting with orange.)note: press 4 times for waste ink counter reset.
The number of the Reset
button pressing
LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset
5) Unplug cable power. (for MP145 / MP150)
6) Turn Off Power. (for MP160)
Error Code :
E3-3 = Paper jam
E4 = No ink
E9 = The connected digital camera / video camera does not support Camera Direct Printing
E14 = The Ink cartridges whose destination are wrong
E15 = Ink cartridge is not installed E16 – Ink remaining is unknown
E16 -E19 = Failed to scan head alignment sheet
E22 = Carriage error
E23 = Paper feed error
E24 = Purge unit error
E25 = ASF(cam) sensor error
E26 = Internal temperature rise error
E27 = Waste ink absorber full or platen waste ink absorber full
E28 = Ink cartridge temperature rise error -
E29 = EEPROM error
E33 = Paper feed position error
E35 15 = USB Host VBUD overcurrent error – USB
E37 17 = Abnormal motor driver error
E40 20 = Other hardware error
E42 22 = Scanner error
Aug 09, 2009 | Canon PIXMA MP150 All-In-One InkJet...
My MP160 has an error code E5 and nothing I do will move it
I think you may have answered your own question.
Here is a list of error codes for your printer, as you can see the code E5, means the cartridge is not installed properly or un-supported.
I would remove cartridge, check slot for debris, clean contacts on cartridge, re-seat cartridge and then try again. If all fails then try a new cartridge, as the other one could be faulty.
If you still have no joy, you probably have a faulty print head unit.
E3-3 = Paper jam
E4 = No ink
E15 = Ink cartridge is not installed E16 - Ink remaining is unknown
E29 = EEPROM error
E35 15 = USB Host VBUD overcurrent error - USB
Feb 07, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Printer show E 2 7.
Hi zaris79,
The E27 code means that the waste ink absorber is full. You'll need to clean the absorber pads and reset the error code. Here's how:
The absorber pads are on the right side of the printer, under the ink cartridges. With the printer on, lift the top to expose the cartridges. They will automatically move out of the way (you can move them to the left by hand if the printer is off). You might need a flashlight to see the pads - each is positioned in a rubber retainer.Take the pads out of the retainers with tweezers and clean them with warm water. If there is ink in the rubber retainer, wipe it out with a paper towel. Finally, put the clean pads back into the retainers.
If the printer does not realize that the absorbers are clean, it may still give you the error code - here's how you reset it:
1)With the printer powered off but connected to a power source, hold down the Stop/Reset button and press Power (the power light should light up).
2) When the Power is lit, hold down the power button, and press the Stop/Reset button two times (then release both - the printer should enter service mode. (Waiting for menu selection)
3) Press the Stop/Reset button 4 times to reset the waste ink counter.
4) Turn off the printer, and turn it on normally. That should do it.
For your reference, here is the complete list of error codes for the MP150:
E2 No paper (ASF)
E3 Paper jam
E4 No ink
E5 The ink cartridges are not installed or a non-supported ink cartridge is installed, or the ink cartridges are not installed properly
E8 Waste ink absorber full, or platen waste ink absorber full
E9 The connected digital camera / video camera does not support Camera-Direct Printing
E22 Carriage error
E29 EEPROM error
I hope this helps - please let me know if I can be of any further assistance.
Kind regards,
H2H
Dec 13, 2008 | Canon PIXMA MP150 All-In-One InkJet...
Mp 145
How to reset the e27 for canon mp145 printer?
May 04, 2008 | Canon PIXMA MP150 All-In-One InkJet...
HP Photosmart C8180 InkJet Printer Logo
Seeker5211
Seeker5211
