Question about Amana Dryers
Amana Dryer warm but not hot.
Hi,Drying time for our Amana has almost doubled in the last 6 months. A load of towels that took 45minutes now takes 90minutes. The Dryer is Model PLEA30AL. We had the vent cleaned and the air flow seems good.The temp in the cabinet when running is warm but not hot, even on the highest temp setting.Any Ideas??Thanks in Advance,Mike
    Genius:
  • 1,550 Answers
  • The lint filter should be taken and washed with a soft brush using warm water and soap if you use fabric softener sheets or liquid fabric softeners.
  • Disconnect vent tube at the back of the dryer and with a thermometer check the temperature on a high heat setting. Depending on the age of the appliance it should be roughly 135-165 degrees Fahrenheit.
  • Check for lint build up in exhaust tube on the dryer or your lint trap and surrounding area.
  • If your problem still exists then call service technician as you require many parts to be replaced.
Posted on Jan 03, 2009
    Genius:
  • 3,422 Answers
HI,
if your dryer doesn't heat, check these:
Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
    Genius:
  • 1,199 Answers
You need to replace the thermostat in the dryer and it will get HOT once again!
The drum stopped spinning when it was drying a load of towels and will not start again.
I had the exact same thing happen. I was drying a heavy load of towels and jeans and it just quit. No tumbling, no heat, no air.
I took my dryer apart and found that there's a thermo switch on the duct between the fan and exhaust. When open, this cuts power to the motor (which I think also cuts power to the heater).
This is the part: http://www.appliancepartspros.com/part_details.aspx?part_id=4045367
I made a temporary jumper past this and it started. So, I have a new switch on order.
Jan 04, 2011 | Amana NED7200TW Electric Dryer
I bought a used GE Profile 8 cycle dryer - I have been trying for 2 days to get one load of towels dried - I set the knob at cottons, dryer is warm butnot hot - could I have a setting wrong?
If your dryer is not drying like it once did or if you just have nottaken the time to give yourself a clean dryer in a long time then youneed to do that. At least once a year the dryer cleaning should takeplace. Lint build up in the dryer duct is one of the main causesfor your dryer to fail.
Here is the rest of this tip about DryerMaintenance
heatman101
Oct 26, 2010 | GE Dryers
It takes my dryer an average of 4-6 hours to dry a load of towels. A regular load of clothes is about 2-3 hours. What can I do?
heatman101
Oct 19, 2010 | Fisher and Paykel DGGX1 Electric Dryer
Our new lg dryer model #DLE1310w is not drying properly. We have 6 medium side towels that are not very wet in the dryer even on the hottest setting it is taking two cycles to dry the towels. When we...
Recheck the vent all the way to the outside and make sure the vent hose is not smashed behind the dryer.
Long time to dry complaints almost always are due to a restricted vent.
Remove vent to dryer and test a wet load if they dry ok then the house vent is at fault.
Jan 17, 2010 | LG Dryers
Takes 2-3 times running to dry a load of towels (5-6 towels) dryer is hot but not drying
There is blockage in the venting system. Check from the blower wheel to the outside. It is blocked somewhere.
Eric
Oct 14, 2009 | Kenmore Dryers
Clothes aren't drying properly
look behind dryer is vent hose kinked or mashed flat? ck a load with hose completely disconnected may get warm and a little dusty but if problem solved reck hose all the way through
Nov 17, 2008 | Frigidaire Dryers
Dryer not drying
be sure vent to outside is not blocked or hose behind dryer flattened..quick ck is to dry a load with rear hose disconnected..if problem still there suspect heating element ..ge/hotpoint elements are double strung if 1 coil is open (burnt into) dryer will not get hot eneough
May 19, 2008 | Hotpoint NBXR463EBWW Electric Dryer
Dryer not drying
try taking a flashlight and look over the back of the drier see if the vent got mashed or is all coled up and stuff let me know also you can remove the vent from the back of the drier and run 1 load to see if it works normal if so then you know the vents the culprit.
Jan 16, 2008 | Amana NDE2335AY Electric Dryer
Clothes not drying
A couple of possibilities to check. First, is the lint trap empty? If so, then the symptoms point to hot air bypassing the drum. Look for broken or misaligned plastic ducting inside the dryer itself. Check the exhaust air for moisture, as that is a better indicator than temperature. Don't forget that towels hold an enormous amount of water, & can be extremely long in drying, especially if not spun enough.
Jul 10, 2007 | Kenmore Elite HE4 Electric Dryer
Dryers Logo
97 people viewed this question
Top Amana Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De GO PATS
Are you an Amana Dryer Expert? Answer questions, earn points and help others
