Question about LG Washing Machines
LG TURBO DRUM DD WT-R854 - LG Washing Machines
My LG Turbodrum DD 8.5 KG WT-R852 have an Error Message (A). What can i do
Posted on Jan 28, 2013
  • Nick Kondisenko
    Nick Kondisenko Jun 26, 2017
    had a read of the manual and the specific error code (A) is not described. However i have done some further research and found the following procedure to reset the washing machine. This then revealed the correct error code for which i can commence repairs. The reset procedure is as follows: How to reset the washing machine: 1. Press POWER to turn the washer off. 2. Unplug the washer from the power outlet or turn the power switch to the unit off. 3. With the power disabled, press and hold the START/PAUSE button for 5 seconds. 4. Plug the washer back in, or turn the power switch back on."
5 Suggested Answers
pride applia
  • 232 Answers
SOURCE: LG Turbo Drum Dd WT R902 wont pump out water
did you take the hoses off both sides of the pump. turn the pump impeller to make sure it turns free. at radio shack you can get a meter for $15.00 to check for power to the pump if it's getting power and it spins free by hand replace it. if no power during drain time it's a bad wire to it or bad control board
Posted on Dec 31, 2009
SOURCE: my LG Turbodrum DD will not drain
Get a new machine. LG washing machines are ****. I have the same model and it has broken down and made horrible noises for years. It finally just stopped working. RIP
Posted on Feb 19, 2011
  • 6277 Answers
SOURCE: I ve lost my manual
You will need to type into your search engine/web browser '(make) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount. During the process you will be asked for the actual model number!
Good luck,
John C
Posted on Feb 21, 2011
I have an LG Wt-R854 turbo drum but it wont wash after it is filled. Nothing in the manual helps.
try filling it halfway first and if that works let it fill up all the way. Good luck
Jan 02, 2015 | LG Washing Machines
LG TurboDrum DD 8 kg WT R801 machine with LE error. Usually I can override the spasmodic message by manually setting the wash, rinse and spin cycles, but not today. The motor speed indicator is not
You have an intermittent problem with the machine's motor. Have the stator and rotor sections of the machine checked out by a qualified electrician.
Jan 01, 2015 | LG Washing Machines
Manual for lg washing machine wtr854
LG has the manual for the WT-R854 on their site: http://www.lg.com/au/laundry-floorcare-appliances/washing-machines/LG-top-loader-washing-machine-WT-R854.jsp . Click on the Support tab and then look on the right side of the page.
I hope this helps.
Jan 12, 2012 | Washing Machines
What's meaning of turbo drum and what's the different between turbo drum and diamond drum
Apr 10, 2011 | LG Washing Machines
I ve lost my manual for my lg turbo drum dd wt-h555th im wanting to know how to do a tub clean the washer is leaving dirt on the clothes
Good luck,
John C
Feb 21, 2011 | LG Washing Machines
My LG Turbodrum DD will not drain
Feb 11, 2010 | LG Washing Machines
LG Turbo Drum Dd WT R902 wont pump out water , I have unblocked it and if i put the hose on the ground the water gravity pumps out, but when i put the hose back up it stops, it will spin but not pump
Dec 31, 2009 | LG Washing Machines
Washing Machines Logo
260 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
