Question about Dell UltraSharp 1907FP 19" LCD Monitor
Height adjust for Dell UltraSharp 1907FP 19" LCD Monitor
I cannot physically adjust height on this monitor please help
  • Anonymous May 09, 2009
    Thank-you! Best advice ever...you've saved me hours of frustration and a trip to the other side of town for the people in the store to tell me that simple advice!!
    Scholar:
  • 63 Answers
Is it stuck, or just not adjustable? Try setting it on a phonebook. I'm kidding. If it is an adjustable base, sometimes they need a little downward pressure before the button will depress and allow it to move upward.
Thanks,
Chris
http://BoiseLCD.webs.com
Posted on Jan 03, 2009
  • Chris McLellen
    Chris McLellen Dec 29, 2009
    http:/www.boiselcd.com
The best demonstration!!!!! This will definitely tell you how to adjust height. http://amoebe.wordpress.com/2007/09/23/get-your-dell-height-adjustable-monitor-unstuck-from-lockdown-position-push-the-monitor-down-just-a-bit-further/
Posted on Jun 04, 2009
Dell LCD 1907FP 19" have
Unfortunately this is an early indicator that the LCD display panel is starting to break down and the cost to replace the part will exceed the amount of a new monitor. I recommend using present item until it completely fails. Sometimes the video cable is the issue and should be subbed provided you can detach from both ends.
Sep 06, 2011 | Dell UltraSharp 1907FP 19" LCD Monitor
How do you adjust the horizontal and vertical gain?
Using the computer system settings to adjust pixle definitions. usually not situated on the monitor. the monitor has to be connected to a computer unit in functionality to achieve definition pixel adjustments usuing the ssytem settings
Jan 29, 2011 | Dell UltraSharp 1907FP 19 inch LCD Monitor
I do not know how to make my dell monitor usb ports active please help me
  • Check that your monitor is turned ON.
  • Reconnect the upstream cable to your computer.
  • Reconnect the USB peripherals (downstream connector).
  • Switch off and then turn on the monitor again.
Jan 19, 2010 | Dell UltraSharp 1907FP 19" LCD Monitor
Where can I find an on/off switch for my Dell 1907FP monitor?
sholmes, Try Digikey.com or Mouser electronics. You WILL match it up exactly and may need to do some tricky "unsoldering" and "soldering". Good luck! YOU'RE on your OWN. 12fixlouie.
Nov 18, 2009 | Dell UltraSharp 1907FP 19" LCD Monitor
Power Button Broken?
Yes, I think your right, if it is under warranty send it back to Dell for repair, I had the same issue about a year ago.
May 20, 2009 | Dell UltraSharp 1907FP 19" LCD Monitor
Cannot raise vertical height after pushing button on back of monitor (button stuck in)
With the monitor in the lowest position, push down slightly on the monitor and push the button in. While holding the button in you should be able to raise the monitor with your other hand. This worked on the one I have.
May 01, 2009 | Dell UltraSharp 1905FP 19" LCD Monitor
Sad to say, I can't figure out how to physically adjust the hight of the monitor. We just moved, aparently in the packing process, the movers shortened the stand of the monitor to make it easier, and I...
I had the same problem here at work, then the solution just came to me...
Push and hold the monitor down (I know its already in the down position, but it can go down slightly further), then push the thin, wide horizontal button in, then you should be able to pull the monitor up to the desired height. Kind of goofy engineering.
Dec 11, 2008 | Dell UltraSharp 1907FP 19" LCD Monitor
Whats the meaning of a Dell Ultrasharp FPt 19" Monitor and a FP
It just the teminology used in dell flat panels e.g. FPT and FPV
FPV ( flat panel with Vesa mounting holes)
FPT ( Flat panel with Tilt adjust )
Thanks
proton
Nov 04, 2008 | Dell UltraSharp 1907FP 19" LCD Monitor
Dell 1900fp 19" moniter Ultrasharp
Button on the bottom back base raises and lowers, if not low enough then you can remove the base. removal button is back and center of monitor.
of course you will have to deal with a way to mount it then.
Dec 12, 2007 | Dell UltraSharp 1900FP 19" Flat Panel LCD...
Dell UltraSharp 1907FP 19" LCD Monitor Logo
3,482 people viewed this question
Alun Cox
