Question about Duracell AAA NiMH Battery Charger with 4 Rechargeable AA Battery
Model CEF14N Class 2 Battery Charger
I bought the above battery charger for my digital camera and recharged the batteries once. I've tried every plug in my home thinking there was something wrong with the plug I was using and have had no luck in recharging the batteries a second time. What's up? Can I get my money back?
4 Suggested Answers
  • 7 Answers
SOURCE: rechargeable batteries are blinking red when
put one battery at a time ,when it turns red that battery is bad.
Posted on Jun 08, 2009
  • 35 Answers
SOURCE: new charger
it may not be the charger on most occations have the battery checked out at your nearest cellphone tech. to find out if you need a replacment battery
Posted on Jun 16, 2009
  • 10865 Answers
SOURCE: only used twice Walmart agrees its a problem but
whoa.....if you bought this two months ago take it back to Walmart and speak to the store manager. This should not have happened. I am quite sure the manager would rather take this back rather than have you file a written complaint with the local better business bureau. Regards, Joe
ps kindly rate my answer as helpful. thank you.
Posted on Feb 19, 2010
SOURCE: flashing lights
I had the same problem. 1 of four way's can fix it. #1 Put a batt. that has a little charge in that flashing spot 1st. and see if that works. #2 put the batt. in that flashing slot first and then in the 1st slot, If that did'nt work, #3 Put Batt. in backwards for 1 sec. in and out fast. and I do say very fast, In that flashing spot. #4 buy a new one. The one that fixed mine was #1 and it stoppppped flashing, The order I put them in was - 3-1-2-4 I put in #3 batt. first, it was the one flashing And it worked, You may have a bad batt. or it's on it's way out, but try It. worked for me!
Posted on Mar 31, 2011
I accidentally left my camera on, and the battery died. Later, when I plugged it in to charge, the charger light just binks orange continuously. The camera won't turn on at all, and I can't get the...
I think the battery was already damaged,a rechargeable battery once you use it,it needs to recharge again so that the battery memory will stay longer.use a new one,regards....
Jul 03, 2011 | Samsung SL102 Digital Camera
Fujifilm battery fully charged but camera says no charge or very little. Just bought a new Duracell Battery and Charger for my Fuji FinePix J10 Camera. Used the charge on the battery in the camera from...
Well you mentioned that it worked fine yesterday with the battery out of the box. That should tell you that the camera and the battery are both fine. The issue is likely the charger itself. Try recharging it again, and double check that you inserted the batteries correctly, and that any switches (such as for 2 or 4 battery charge) are set in the correct position on the charger. If this doesn't work, take the charger back to the store for exchange/refund as defective.
Jun 11, 2011 | Fuji FinePix J10 Digital Camera
How do I use the recharger?
The L20 uses AA batteries, either disposables or rechargeables. If you want to use rechargeables then you must charge them using a separate battery charger.
With most battery chargers, you simply put the batteries into the charger and plug the charger into a wall outlet.
Feb 09, 2011 | Nikon COOLPIX L20 Digital Camera
How do you recharge the battery on the power shot sd 1100?
A quick look on Cnet reviews says the specs for battery and power are:
Power
  • Power Device Battery charger - External
Battery
  • Supported Battery Canon NB-4L
  • Supported Battery 1 x Canon NB-4L Li-ion rechargeable battery ( Included )
An NB-4L battery charger is what you need to charge the battery for that model. My Canon charger is a small box with fold out wall socket prongs and a mount for my battery to slip into.
This looks like a Generic version sold on eBay, that includs a Euro/mexico Socket adapter.
Dec 11, 2009 | Canon PowerShot SD1100 IS Digital Camera
I plugged my camera into the car charger as the battery died, so it blinked and then turned off. when i arrived home, i recharged the battery and tried it on the camera, it didnt work, is it the camera or...
The Canon NB-5L is rated at 3.7volts. I don't know how you plugged the car charger into the camera, but if you got the 12volts from your charger on your camera ... you fried it. To check the battery, put a voltmeter (multimeter) across 2 terminals of the battery, it should read between 3.5volts to 4.0volts.
Oct 06, 2009 | Canon PowerShot SD870 IS Digital Camera
How do I recharge my vivitar DVR 560g. I tried plugging it in via my phone charger - but no go.
I believe your camera has a charger included. when you bought it. Battery type is li-ion battery (NP-40). You'll just need to remove the battery off the camera and plug it to the charger kit that came with it. Hope this helps :-)
May 05, 2008 | Cameras
For use with compatible battery only????
I've heard of this issue with more than one Sony (seems like there was a post in the forum not long ago with the same issue...). If you've bought a new battery, the problem would appear to be in the camera's power controller. With that in mind, I'm afraid you'll have to decide if the cost of repair is worth it, rather than simply putting the money toward a new camera.
Farid
Mar 23, 2008 | Sony Cyber-Shot DSC-T1 Digital Camera
Canon ixus 60
The ixus 60 is also known as the SD600. It's actually quite a good camera. It uses the "NB-4L" battery. You'll need a charger for your camera's battery. Simply remove and place the battery in the charger and plug it in the wall. If you don't have a charger, generic ones are very inexpensive (so are the generic replacement batteries):
http://www.amazon.com/Camcorder-Battery-Charger-PowerShot-Bargaincell/dp/B000U96EW4/ref=sr_1_23?ie=UTF8&s=electronics&qid=1199121852&sr=1-23
Dec 31, 2007 | Canon IXUS V2 Digital Camera
Epson 3100 life battery
I have a 3100z and you are right that alkaline batteries do not last long. The thing to do is buy a couple of sets of NiMH rechargable batteries and they last much longer. I,ve just been on holiday and had no problems at all with the batteries. (Although the camera does not give much warning when they need replacing).
Sep 13, 2005 | Epson PhotoPC 3100Z Digital Camera
Duracell AAA NiMH Battery Charger with 4 Rechargeable AA Battery Logo
1,119 people viewed this question
Top Duracell Electronics - Others Experts
Carl Glas
Carl Glas
Robert McClure
Are you a Duracell Electronics - Other Expert? Answer questions, earn points and help others
