Support
information the X75 printer can be found
here.
Support
information the X74 printer can be found
here.
On these page are a link to Windows 7 Information; if you open you will find that Lexmark does not support your printer for Windows 7.
There are no Windows drivers available for the X75; however drivers for Windows, 2000, 98, Me and XP (32-bit) are available for the X74 and these will probably work for the X75.
If your operating system is one of the above check under the tab labelled
Downloads; select your operating system to download your driver and save in a known location.
When you connect your printer Windows will try to install but you should be prepared to point to the driver location. If the printer doen not autoinstall you will have to add your printer manually through the Printer section of your Control Panel.
I have the same problem ... bummer!
