Question about Hoover F5835900 Upright Steam Vacuum
Machine will not **** up the water.
It appears that instead of sucking action it is blowing out air ? clogged??? The water spray button appears to be ok? thanks......
  • 1 more comment
  • Anonymous Feb 13, 2009
    I have a Hoover SteamVac and it's seriously blowing out air, not sucking up the water. This has been used once, sucessfully... How did this happen and mainly, how do I fix it??
  • Mark Paluszynski
    Mark Paluszynski Mar 10, 2009
    machine worked great in the beginning. But now it spills water on the floor after sucking it up.
  • Anonymous Mar 24, 2009
    Mine is doing the same thing and looking for answer. Any ideals?
  • 174 Answers
E-mail me for the parts manual (firehead@rogers.com)then do the following
Go to figure 3.1 and clean the filter if necessary. Goto figure 3.8 and make sure pate E is clear. Make sure the part isslides up against when inserted downward is clear. Go to figure 3.11.The slotted holes in the recovery tank lid must be clear. Finally therecovery tank lid must fit snugly and air tight. I hope this works
Posted on Jun 28, 2009
  • theswizzer Sep 02, 2011
    My SteamVac is doing the same thing as "Guest" above - It worked fine in the past but now it's blowing out air. It's as if the motor reversed itself. I checked all of the things you mentioned above - still the same result. Is there any way to re-reverse the motor?
Its a reverse vacum, not sucking up anything just blowing it everywhere. The belt is fine and the filters are clean. Please help.
Hi r_holdsworth,
You got a deal! 2in1, blows and vacuums....
Actually, when vacuums blow instead of sucking, there is a clog somewhere. Usually, it's something that has been vacuumed up.
If you can't find the clog, please reply back with your model number and I'll find an exploded view of your machine for you to look at.
Hope this helps. If it does, I'd appreciate a 4 thumbs up. Thanks,
Handie Andie
May 20, 2011 | Bissell Cleanview Helix Vacuum
It seems to blow air out instead of sucking up
Remove the bag on top and the plate on the bottom. Clean out the air passages, top and bottom, looking for a clog. When it seems clear, turn on the vacuum to see if air is moving through. Don't allow a full bag to remain in place Check the brush on the bottom for string, hair, or thread caught in the bristles or bearings on either end. Hope this helps!
Mar 12, 2010 | Hoover Tempo Widepath Upright Vacuum -...
Bissell proheat blowing out air instead of sucking in air
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
vm,v
Feb 16, 2009 | Bissell 1699 ProHeat Clear View Upright...
I have a Bissell Proheat 2X Carpet/Upholstery cleaner and I can't get the soap and water to come out of the attatchment. The vacuum part is working, but the spray isn't. I can see the fluid is trying to go...
I have a Bissell "Little Green" cleaning machine that acted like yours. I found several clogs in the fluid system. The power for the fluid in my unit is provided by a small AC motor independent from the vacuum motor attached to a small plastic pump. This pump then fed into the input of the heater. Inside the heater is a sort-of mirror-image, redundant labyrinth that the fluid passes through before it exits. My heater was completely blocked on both sides, and exhibited signs of corrosion. My choice was to disable the heater and to instead hook its output line straight to the pump. I also found clogs in the fluid line, particularly where there were bends. One of the clogs was where the vacuum and fluid line made a right angle turn out of the base of the machine. The other was in the trigger handle itself in a jog of the small line that connects the valve to the spray nozzle connector.
I would suggest examining the trigger handle first. The only thing to watch for is the position of a small flat metal spring with a square hole in the center that lives between the trigger and the valve (which is also sprung).
I made good use of some slightly smaller standard aquarium air line so I could blow water and air through without having to actually taste the internal lines of the machine.
My new resolution is to run clean water through the fluid system before putting it to bed!
Jun 28, 2008 | Vacuums
No suction generation 3
there is a clog in the line try blowing it out with compressed air
Jun 27, 2008 | Kirby Generation 3 Bagged Upright Vacuum
Stair and upholstery attachment
After tearing things down and inspecting the handle switch, etc., I found that my problem was detergent. It sets idle for a while or doesn't get used very much and the detergent dries and actually clogs the inside of the hose. I cleared it by fully extending the hose, pressing the button and allowing the clog to clear itself. The built in heater helped out a lot once the flow started again. I used a can of compressed air to provide a little blow back to get things moving but not too much or the pump would be damaged. Remove the tool and hold the nozzle into an empty cup while depressing the trigger. A warm vinegar solution clears things out nicely. It's kinda hard for this piece go defective but easy to overlook when wrapping up and storing the unit. Remember, clean water rinse with 1/4 cup white vinegar. There, I fixed it and wasn't even broke!
Apr 08, 2008 | Hoover F5881-900 Vacuum
Dysin vacuum blows air instead of sucking it!
If it is blowing air, then it is still clogged up somewhere, you didn't give your model number, but some of these have removable covers on each side and on the back. Also make sure that all covers are back on securely.
Jan 07, 2008 | Vacuums
Dysons aren't supposed to clog up, but they do. There a number of ports you can open to see if there are clogs in any of them. Usually a clog is why it will blow air and debris out instead of sucking. You just need to find it.
Jan 05, 2008 | Vacuums
Blowing warm air
Is there a part missing on the front of the dirty water tank? On some of these machines, there is block that you take out so you can insert the hose in its place. So if this spot is open, then it can't suck and will be blowing warm air.
Dec 15, 2007 | Hoover SteamVac F5914-900 SpinScrub...
HELP!!!!!
The hose is probably clogged. It is supposed to blow out at the filter. It filters the exhaust air so you don't get dust back into the air.
Oct 16, 2006 | Regina RG3100 Vacuum
Hoover F5835900 Upright Steam Vacuum Logo
459 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
