Question about Sony SLV-D350P DVD Player/VCR
Power Failure I can't get the unit to turn on either with the remote or the power button. I have checked the power cord and fuse and found no problems there. Is this thing worth fixing?
  • 2 more comments
  • djdeli Dec 18, 2007
    Can't get the DVD or video to work. LED display isn't working either. Just died overnight. Have replaced the fuse but that didn't help. The machine is obviously working as it interferes with the tv when it is turned on at the wall. Any suggestions????
  • Anonymous Feb 24, 2008
    Unit powered itself off in a VERY WARM room; it displayed a row of dashes at first. Unplugged it, opened it up and manually turned the worm gear to eject a valuable VHS cassette.
    Later plugged back in, and NO DISPLAY/RESPONSE AT ALL! Fuse was intact. Power switch has no effect; totally dead. Help!
    Pete
  • Anonymous Dec 20, 2008
    power light blinks slowly~unit won't turn on?
  • jacomk Jan 13, 2009
    I was rewinding a video and suddenly the power went off. The digital display is on very lightly, but nothing works or moves. I unplugged but t did not help.
BLOW OFF FUSE
Posted on May 16, 2007
Samsung tv LN40B500P3F will not turn on
you must test the power cord first for open or faulty 2) test the receptacle for faulty see the diagram 3) test the power button +fuse and repair or replace.
Dec 19, 2013 | Samsung Televison & Video
Sony trinitron 32" wont turn on KV32s16
if their is no any power indicator that light in the front panel, it was a power supply board failure. you must look first the fuse if busted, then before you replace it ensure no other part has damaged like shorted diode, transistor, transformer and regulator.
Jul 18, 2012 | Sony FD Trinitron WEGA KV-32FS120 32" TV
How to fix power on problem?
This can be a result of a stuck button on the TV or remote. Remove the the batteries from the remote to prevent a signal from it being sent. Operate all the buttons on the TV one at a time in an attempt to "un-stick" any stuck button(s).
Press the power button on the TV to see if it will turn on. If it does not, check for an open fuse or tripped circuit breaker. Check for the presence of power at the outlet by connecting a table lamp or other electric device. If power is off, see if a wall switch is off somewhere - as it is not uncommon for a switch to control 1/2 of an outlet.
Make sure the power cord is connected at the TV set. Many power cords are completely removable and the end the connects to the TV may have been loosened or fallen out. Visually check the length of the cord to make sure it has not been damaged or cut. Do not use you hand to feel for damage unless the cord has been unplugged from the outlet first.
Unfortunately, if you're unable to turn the TV on; it will probably need to be serviced professionally. There are typically no user serviceable parts inside the TV itself. If your TV has a fuse holder on the outside of the TV, you should unplug the TV and remove the fuse for replacement if found to be open or blown.
Lastly, operate all the buttons on the remote - again to un-stick any button. Return the batteries to the remote when done. If your remote has a lamp to indicate when a button is pressed, check to see if it is on with fresh batteries. Old batteries may not show the lamp being on, but still allow the remote to send a signal.
Jan 09, 2012 | Sharp LC52D85U 52 in. LCD TV
Vizio plasma tv will not turn on by button or remote, cable box is lit. We had a loss of power last night due to a storm. What do we do to check it.
hi usually the cause of won't power on problem due to the storm is the current fluctuation which the tendency is power supply failure. now since totally dead set what you need is to open the tv unit then look for the power supply where the power cord is connected. check obvious defective component part like blown fuse and burnt part like resistor and capacitor. just replaced with the same value and ratings to avoid damage from others component.if their is no problem with the power supply the output voltages are good the main board get damaged. good luck thanks for consulting the fixya.
Jul 14, 2011 | Televison & Video
HP 7410 All-in-One Printer A 'Scanner Failure' message is desplayed on the printer's front panel
I know i'm not going to get 4 thumbs up for providing this resolution because it seems like a hardware problem but what the heck you need some sort of help so here goes.
This error usually occurs when trying to scan or make copies. The scanner bulb is not hot enough or the electrical conditions are not suitable for the HP All-In-One product. Follow the instructions listed below to resolve this failure. The scanner lamp lighting should be viewable under the scanner glass right or left corner.
  1. c00439542.jpg 1 - Scanner lamp lighting 2 - Scanner glass If the scanner bulb does not light up, the HP All-In-One product may be defective.
  2. Make sure that the room temperature is suitable for the HP All-in-One product. Perform a Power Cycle on the unit by following the steps below:
    1. Turn the unit off.
    2. Unplug the power cord from the unit.
    3. Wait 30 seconds, and then re-connect the power cord to the unit.
    4. Turn the unit on.
    Check the power connections:
    1. Make sure that the unit is connected directly to the wall outlet and not to a power strip.Try a different wall socket.
    2. Every PC provides a standard power cord; it is possible to use it to check whether the electrical failure is prompted by the cord or not.
  3. If the Warming up or Scanner failure error messages persist, please move the unit to a different room or building to verify that the building (or room) is grounded properly.
  4. If your HP All-in-One product uses a external power module, check the power module part number against the part number listed in the User Guide to ensure the proper power module is being used. If both part numbers do not match and your product is still under warranty, please click the Contact HP link at the top of the page. If your product is out of warranty, please click the How to Buy link at the top of the page. c00458738.jpg
  5. Perform a Partial Reset by following the steps below:
    • Unplug the power cord from the HP All-in-One product.Press and hold the appropriate button combination for your HP All-in-One product. The appropriate combination for your model can be consulted in the HP All-in-One Products - Performing a Partial Reset of the All-in-One document.While still holding the buttons down, plug the power cord back in. Release the buttons after the HP All-in-One unit displays the Partial Reset message.
    Make a test copy of any document.If this copy is successful, the scanner mechanism is functioning correctly.If the error appears again, Follow the below troubleshooting
Noisy scanner This failure can occur when the HP All-in-One product is initializing.Every time the unit is turned on, the scanner carriage should move. Sometimes, when the scanner carriage returns to its home position, the carriage could crash and make a loud noise.Within a few seconds, the unit gets blocked, and the front panel display shows a Scanner failure message.Scanner noise could also be caused by the scanner sensor inside the HP All-in-One product being damaged or not properly in place.To solve this failure, follow the steps below:
  1. Perform a Power Cycle on the unit by following the steps below:
    Make a test copy of any document by pressing the Start Copy (black or color) button.
    • If this copy is successful, the scanner mechanism is functioning correctlyIf the failure remains unsolved, skip to the following step.
  2. Perform a Partial Reset on the unit by performing the following steps:
    • Unplug the power cord from the HP All-in-One unit.Press and hold the appropriate button combination for your HP All-In-One product. To know the proper combination for your model, check the HP All-in-One Products - Performing a Partial Reset of the All-in-One document.While still holding the buttons down, plug the power cord back in. Release the buttons after the HP All-In-One unit displays the Partial Reset message.
    Make a test copy of any document by pressing the Start Copy (black or color) button.If this copy is successful, the scanner mechanism is functioning correctly.
  3. Now if this still doesn't resolve the issue then it's a definite hardware problem my request would be regardless of the thumbs up,call up hp at 1800-474-6836 and ask for their upgrade machines because u'll get a machine with a 50-60% discount and an extended warranty with a 70-80% discount or u may get a warranty for the next two years for $1....Sorry if I can't help you
Oct 05, 2010 | HP OfficeJet 7410 All-In-One InkJet...
I have a Sharp portable room air conditioner model CV-P10NC. The power plug RESET button and TEST button will not click in order to check out the power plug as the unit will not turn on. They did test O.K....
the fused9G.F.C.I.) cord you speak of is probably the G.F.C.I. built onto these units by design, can you or someone you know get access inside the unit and :Hot-Wire" the units cord and,bypass the power cord ( Just To Test the Unit)and see if it stays operational then replace bad unit cord if this is it.
Sep 12, 2009 | Heating & Cooling
No power on 2002 Mitsubishi VS-60609
You have a short in the power supply or high voltage. You will need a sevice tech to deal with that problem. Make sure to get an est before repair
Jun 19, 2009 | Mitsubishi VS-60609 60" Rear Projection...
No power
Obviously, first check for AC pwr at the outlet, plus check the power cord connection at the set itself. If you have an AC voltmeter, use it to confirm that power is actually getting to the set.
Have you tried both power buttons on the remote AND on the set itself?
If all is well in these checks, then the set likely has an internal problem- perhaps just a fuse, but usually fuse failure is caused by other circuitry failure. If the latter is the case, then services of a tech-savvy are necessary- costs probably $100 plus.
Jul 07, 2008 | Protron PLTV-32 Television
Frigidaire AC Window, Model # FAC107P1A2
please leave the unit unplugged from the main power for few hours and check if it works
Jun 29, 2008 | Frigidaire Heating & Cooling
Sony SLV-D350P DVD Player/VCR Logo
195 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
