Compaq nx6125 is not charging even though the adapter is working fine and the battery is fine too
Laptop battery indicator shows that it is charging but in fact its not
    Novelist:
    Champion:
  • 233 Answers
Firstly, try the following steps to check the problem:
Turn off laptop.
Unplug AC power adapter.
Remove battery.
Replace AC power adapter.
Turn on laptop, allow OS to boot.
Once logged in to the machine, perform a normal shut down.
Replace battery.
Turn on laptop, allow OS to boot. The battery should once again be charging as normal.
Posted on Oct 29, 2012
myrlex
  • 674 Answers
SOURCE: My laptop is a Sony Vaio PCG-6Q2M with Power and Battery Problems
fix first the power adapter/ it not charging some problem of your power adpater,, check the charger if it is working properly or not, then follow by dc connector should know that your dc connector has no deffect// if its okay check the motherbaord of your pc maybe som chips need to replace or damage...ic capacitor fause..ech..
Posted on Sep 11, 2009
leecom72
  • 4806 Answers
SOURCE: Acer aspire laptop won't charge
First of all you have to determine whether it's the battery, charger or the laptop itself.
Remove the battery and boot the laptop on AC power only, if the laptop boots up you can rule out the charger and the laptop, you may need a new battery if that is the case.
Regards.
Posted on Sep 08, 2009
The best advice would be to update the BIOS and then go to the BIOS utility and restore the settings back to default. This might resolve the issue if it is software related. If not then visit the manufacturer's website and download the latest chipset drivers. Restart.
Try using a different power adapter of the same kind and check for the issue.
Turn off system and remove the power cable and battery and press the power button for about 30 seconds to power drain the system.
Turn on and check.
If not the main board itself is the issue for which I would request you to contact the manufacturer.
Posted on Sep 10, 2009
  • 115 Answers
SOURCE: my hp compaq presario c700 laptop's battery is not
There are problem with your battery, so change your battery as soon as possible otherwise it can put bad effect on your laptop's motherboard.
Regards
Ashly
Posted on Feb 02, 2010
SOURCE: Compaq Presario F700
my presario crashed, and i do not have the recovery software, canyou help?
Posted on Jul 04, 2010
Dell inspiron not charging
Dear Mathew,
You should you Dell Utility and it has the function called Dell Battery Metter, it can enable or disable charging
Nov 12, 2012 | Computers & Internet
My laptop not charging
When you say it won't charge, does it charge at all?
1. It indicates that it is charging, but as soon as you unplug the charger the battery quickly or immediately indicates it is dead. If the laptop is off, the LED on the laptop shows it is charging but the battery is always dead,
Or: 2. It is as if you didn't have the charger plugged in. No light on the laptop at all when the charger is plugged in.
Possible solutions:
1. The battery has died and is no longer capable of taking a charge. An alternate explanation if you can't even get the laptop to turn on even though the laptop charge LED is on, is that the internal power supply that converts the incoming and battery voltage to all the voltages required has died.
Or: 2. The power connector inside the laptop is a common failure point. The solder joints break from various minor shocks over time. This is going to become more common with lead-free solder as it is more brittle. Less likely is that the charging circuit inside the laptop has failed.
http://www.chargerbuy.com/laptop-ac-adapter/universal-ac-adapters.html
Oct 28, 2012 | Computers & Internet
What'My laptop works fine when I have just the battery but when I plug it in it does not work even without the battery. Could it be the Adapter cause all my outlets work and so does the battery.s
if the charger cannot charging is the problem,then you need to repair the Battery management software,because you say that the battery is working,then the error should be on the software,that it doesn't indicate that the battery is charging,first go to Device Manager (Right click My Computer,select Properties,click Hardware,click Device Manager) by type "Device" on the start menu and select Device Manager
Expand the Battery categories and right click on Microsoft ACPI Compliant Control Method Battery listing, and select Uninstall
WARNING: Do not remove the Microsoft AC Adapter driver or any other ACPI compliant driver.
On the Device Manager taskbar, click Scan for hardware changes .
Aug 26, 2012 | Compaq Presario CQ50-215NR Notebook
How do i reset bios password on hp nx6125
1) dismantle laptop and remove laptop BIOS battery (as per HP documentation)
2) attach power adapter and power on laptop WITHOUT the battery in place
3) reassemble laptop and enjoy the reset BIOS
May 28, 2011 | HP Compaq Business nx6125 Notebook
Compaq N610c does not power on on AC adapter or on Battery :(
it might be that the AC adapter is no more working. To confim this, remove the laptop battery and test the AC adapter with the laptop.
You can also borrow a friend's AC adapter and test it with your laptop.
I wish you good luck.
Mar 03, 2010 | Compaq Evo N610C Notebook
Hi forum, I have been using Compaq N610c notebook and was working fine but was not power ON . on AC adapter but it was working on Battery. From last day, the battery become zero showing battery indicator...
It's possible that the AC adapter "died", and then your computer ran on battery-power until the battery went to 0%.
Or, the socket on the laptop where the AC adapter connects could have broken, or become disconnected from the motherboard, such that the power from the AC adapter was not being accepted, meaning that your computer was running on battery-power.
Take the AC adapter and the computer to a qualified technician, who can test that the AC adapter is working fine, and can disassemble the laptop, to inspect that socket where it connects.
Laptop won't power on
A few things to try:
First remove the battery from the laptop plug in the power adapter and see if it powers up without the battery in. If this works there is a problem with the battery or the battery driver. If it works login go to device manager and disable the Microsoft ACPI-Compliant Control Method Battery. If battery works then it was the driver if still fails its a dead battery.
Try with just the battery it is probably dead though as its had no power to charge it.
Check if the power adapter has a light on it some have lights that indicate its receiving power. Also check if the lights on the laptop to say the battery is charging even though you indicated it isnt.
Let me know how you go or if you need further help.
Mar 23, 2009 | Lenovo ThinkPad T500
COmpaq Presario V5000 Battery will not hold charge
Problem with the motherboard connector that charge the battery.
Oct 03, 2008 | HP Compaq Presario V5000Z Notebook
Power up
i think urs battery get damaged....
but before replacing it first remove it safely n again fix it on laptop....
then restart ur laptop if same problem is coming...than it is sure dat ur battery get damaged or its efficiency get lower....
send me feed back if ur facin more problems wid ur laptop at shriii2@rediffmail.com
Jun 13, 2008 | Compaq Evo N610C Notebook
Computers & Internet Logo
134 people viewed this question
David Payne
David Payne
