Question about Bose Lifestyle 38 DVD Home Entertainment System System
No sound A child played with the remote control and now even though the volume is up, there is no sound.
    Genius:
  • 1,199 Answers
Look for a mute button and press it,If that doesent work unplug for ten min and try again!
Posted on Jan 03, 2009
Nikai japan ntv2190stf no working remote control
To open its child lock, you might have its original remote control. Try these methods. Locate the manual for your television. Though slightly embarrassing, accidentally turning on the child lock to a TV is a common problem. The section In the manual about how to set the child lock feature will also explain how to unlock it.
Try a few "universal methods" for unlocking the child lock. Some televisions have a universal code built in for disabling the child lock --no matter what your code is. A common code is "0000."
Unplug your television for a few minutes. The internal battery of the TV is what helps remember what your code. If the TV is unplugged for an extended period of time, it clears the internal memory, which in turn will reset your child lock code.
If you wish to buy its original remote control, you have to contact the authorized service center. If you wish to buy a universal remote control, you should know about, which brand remote control have setup code to your TV/device brand. You should first make sure about the number of digits in the codes to your device have. There are 3-digit, 4-digit, 5-digit and even 2-digit codes. You can get this detail by the code list attached to every universal remote control. The brand name of the remote control you select isn't a matter; but, its code list should have setup codes to your TV/device brand, otherwise you can't set it up with your device. Check this link and note which brand remote control have set-up codes to your device brand, and buy that brand remote control, according to availability.
Dec 01, 2013 | Philips Magnavox 27MS343S 27" TV
Apex digital LD3288T
Check to see the set is on the right input---the one the Dish is connected to----input or source or even on the Dish remote it is set not to something other than the button for the Dish box.
Jun 07, 2012 | Televison & Video
Very weak sound on television from dvd. player recently bought. It is a Silvercest KH 6524 player and some official dvd discs.. Even using maximum volume of my t.v. , a flatscreen Samsung and my...
Some brand name of the DVD player.Some brand name DVD player,u must used it own DVD player remote to turn on the volume higer or lower to get it up or lower on the movie DVD discs or any kind of DVD discs are playing.The tv dosen't control the output volume of the movie,if the function require the DVD player remote to do it.Check ur DVD player remote see if u have a volume control buttons + - used those buttons on the DVD remote control u will control the volume of the movie DVD disc it is playing on the DVD player.
Aug 09, 2011 | Televison & Video
When I hook up my computer to the receiver and play music it is hard to find a point on the master volume where the music plays clearly. The music skips and i have to be very careful with the master...
Master volume control pot is dirty and needs to be cleaned out. You can do this by unplugging the receiver and turning the master volume control back and forth from zero volume to full blast a couple of hundred times to clean the surfaces and restore normal operation.
Aug 24, 2017 | Pioneer VSX-509 Receiver
Cable Set-Top Box remot won't change sound vol. Only TV Rem. does
They volume indicator you are seeing is meant to show the volume of content if it were to be recorded on the cable's dvr. This indicator has no effect on the volume of content as it is being watched. This feature allows recording of sound at a set volume even while the tv is off. It sounds as though you'll just have to use the volume buttons on your tv's remote, though you might want to try seeing if there is alternative set-up for those cable volume buttons.
Jan 05, 2009 | Samsung LN19A330J LCD TV
Tv and dvd remote controls interfere with each other
found out that signals from both remotes were on same waveband
moved dvd player tp differnet tv in diferent room and bought new dvd player to couple with LG flat screen
Not a technical solution bit did the trick
Ray
Dec 08, 2008 | Televison & Video
No sound, No more
Sorry it took so long to reply, to your request for help. You need to use you owners manual and go to the section on audio controls. Check every function that can turn off the volume to the television while it is playing. Make sure all the controls are set properly for the use of the audio on the television. If you cannot find the problem and correct it this way, you can call the RCA customer support telephone number 1-800-645-4994. Give them the model number of your remote control and ask them for their assistance. I hope this information helps you with your remote control problem. Thank you for using FixYa and have a nice day!
Oct 26, 2008 | RCA DIRECTV Satellite Remote Control
Sound
The DVD player has a separate volume control - make sure the DVD player's remote volume is turned up as well as the TV's.
May 29, 2008 | Philips Magnavox MWD7006 DVD Player
GE GTD120 System
Assuming your speaker wires are securely connected, and that you have tried more than 1 or 2 DVD's, access your main menu via your Remote Control and Restore Defaults. If you still cannot get even so much as noise, manually turn your volume control, and ensure that the LED lights follow your turning movement. It has a fairly fancy volume controller, and if the carbon liner witin the physical volume control is cracked, you cannot adjust the volume even if you use your remote.
May 12, 2007 | GE GTD120 System
UNCONTROLLABLE SURROUND VOLUME
bad solder connections and or dirty controls.
Dec 12, 2006 | Technics SA-AX530 Receiver
Bose Lifestyle 38 DVD Home Entertainment System System Logo
76 people viewed this question
Top Bose Audio Players & Recorders Experts
jjcicala
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
