Question about Kenmore 78812 / 78814 / 78819 Gas Kitchen Range
Stove burners are Yellow
For two years the burners were blue and did a great job-overnight they turned yellow and now the high burner does not work well. I have tried to adjust each burner behind the turn on knobs with little success. Any suggestions?
  • 76 Answers
Change your gas valve
Posted on Jan 03, 2009
Yellow flame
The problem is with the orifice leading to the burner. If it is not centred then you will get yellow flame. Or you are impeding the flow out of the burner and it is not mixing properley. I would pull the burners apart and make sure everything is clear and the orifice is centred.
Apr 14, 2014 | GE Monogram ZGU48N4GHSS / ZGU48L4GHSS...
FLAME IS YELLOW INSTEAD BLUE for sunbeam gas range
Yellow usually means more air than gas mixing at the burner. The top of the stove lifts off. There are adjustment screws in front of every burner. Turn the burner on after first locating the screw. Turn the adjustment screw until desired flame is achieved. You want a flame with a yellow tip and the body of the flame blue. Please be very careful not to get burned. Hope this helps.
Jan 20, 2011 | Sunbeam SNS3GMNBB (Gas) Kitchen Range
Just recently our 10 year old stove started smelling funny only when its on. the burner burns but the flame is yellow and was normally blue. I understand the air fuel mixture could be off, how Do I fix...
Gas flame on all gas appliance should burn clear blue.
Yellow flame means you need to clean the burners.
This applies to stoves, oven, furnaces, water heaters
I did a google search for: clean burners on gas stove.
There was more information and helpful tips on those links than I can honestly repeat here, including how-to videos.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, fixya expert speaks with you over phone while you work on appliance.
Jan 03, 2011 | Hardware & Accessories
What would cause a high yellow flame on a 2 burner duel fuel stove after it has been on for a while? Could wind cause this or maybe a bad generator?
The pressure drops and so you have to pump it up a little every now and then. What I do is pump it up a hair. Reset the flames to a pretty blue. Yellow flame is too much fuel to air ratio. An air shutter adjustment is needed. Also dust in the burner can cause the secondary air to have an improper mix
Apr 20, 2010 | Coleman 2 Burner Dual Fuel 424-700G Grill
I have a Kenmore 4 burner grill that I purchased about 3-4 weeks ago. 3 of the 4 burners have nice blue flames and work very well but the left middle burner gets a huge yellow flame no matter what temp it...
does the same burner flame turn blue if other burners decreast in flow-with that burner on high and others low-is it still yellow? if so Gas Valve needs to be replaced.
Oct 05, 2009 | Kenmore 700 sq. in. Cooking Area Gas Grill...
Flame way too high and yellow-Frigidaire Model #FGF328GM
call an approved frigidaire gas technician as it is possible that the jets in use are not for the propane gas
they are probably natural gas jets which have a larger jet size
the air shrouds around the jets have to also be adjusted to get the blue flame
you may be able to have it checked out under warranty as it is new
if you touch it your self , the warranty will be void
Mar 11, 2017 | Kitchen Ranges
Toyostove 72 won't go on high.
Replacing the burner ring (center piece?) will do wonders. When it's warped the stove won't work properly.
Jul 22, 2008 | Rinnai Toyostove Direct Vent Heater:...
JGBP89SEMSS BURNER HEIGHT
Sounds right long as you did the conversion okay did you change the spring in the reg ? lp gas does burn lower than nat gas smaller blue flame . you could see if the aeration can be adjusted to the burners You could also check the pressure at the burners lp working pressure is 14in wg .
You could check the reg outside . That's all I got .
Mar 17, 2017 | GE JGBP88SEKSS Gas Kitchen Range
Kenmore 78812 / 78814 / 78819 Gas Kitchen Range Logo
79 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
