Question about Minolta Magicolor 3300 Color Printer
How do you calibrate a Konica Minolta Magicolor 3300 printer?
The Magicolor 3300 I own, just has a blue haze that covers the entire printed sheet; I'm thinking it needs calibration, but I'm not able to follow precisely how to do it from the documentation. Please help.
  • Minolta Master
  • 6,161 Answers
More then likely the Cyan Image unit needs to be replaced
Posted on Feb 08, 2015
SOURCE: Konica Minolta Magicolor 2300 DL - Fatal Error Code 0EH ????
I had the same problem one time, they told me to pull out all of the toner cartriges, power off, power on, power off, replace all cartridges and the problem went away.
Who knows why. If this doesn't work....
Call Konica Minolta tech support.
They were pretty helpful to me.
Dave
Posted on Jan 06, 2008
  • 214 Answers
SOURCE: minolta magicolor 2300
16H means, that the transfer belt does not rotate correctly, open all covers, remove any paper, whats stack inside, remove waste toner box, drum unit then open 2 nipple screws and pull out the transfer pelt, if the belt looks ok, reinstall everything and power on again. if works, then everything is ok, if not, then there is something wrong with TBU or TBU
Posted on Feb 28, 2008
  • 81 Answers
SOURCE: magicolor 2200DL
calibrating FW:412050G123D0 I think it says calibrating firmware. what happen before you get this error? did you try to wait for a long time?
Posted on Oct 06, 2008
SOURCE: Imaging Unit Missing on Konica Minolta Magicolor
I had the same problem previously. I had a small piece of paper jam in the imaging unit
pulled it out and got the Imaging Unit Missing error. I could not solve the problem so I called it in under the extended warranty. Even the printer tech could not solve this issue. But, I look at this file, took off a the side cover moved the gear an viola! fixed..
Try page 3-308 of this PDF.
ftp://ftp.qms.com/pub/cta/out_going/other/diagcd/mc3300sm.pdf
Posted on Apr 17, 2009
  • 8 Answers
SOURCE: to change opc drum in konica minolta
To Change OPC DRUM UNIT in KONICA MINOLTA 2300 w
Switch Printer Off
Open Front Door Cover
Remove Waste Toner Box
Lift Transfer Belts Blue Knob until it's placed at 11 o'clock. (it's directly behind the waste toner box)
The OPC DRUM UNIT is directly under the BLUE KNOB
SQUEEZE HANDLE and PULL OUT the OPC UNIT
Be VERY CAREFUL NOT TO SCRATCH THE GREEN COLOURED ROLLER on the OPC DRUM UNIT.
Replace new OPC DRUM and turn BLUE KNOB of TRANSFER BELT back to 7 o'clock position
Replace Waste Toner Box, Close Front Cover and Switch On.
Status Display will show OPC Drum at 100%
(You can also replace the fuse in the OPC DRUM UNIT and save yourself HUNDREDS on a new one)
I posted this on another solve problem previously, worth looking at.
Posted on Mar 13, 2011
How do I print 8-1/2" x 14" paper. I only have one 8-1/2" x 11" tray? Konica Minolta Magicolor 5430DL
On the 5430 DL there is an aux legal tray that can be purchased for legal printing. On a later successor the 5550 a manual feed option was included, however for the 5430 there is no option for printing legal without the extra tray being installed. On a side note, I have this tray and when not printing legal it lets me load an extra 500 sheets of letter paper which is very convenient when I need to print a bunch of sheets overnight.
Mar 15, 2010 | Konica Minolta magicolor 5430 DL Laser...
Magicolor 2500W keeps faulting when printing reverse side of already printed sheets. Will not pick up sheet from tray
Possibly the paper grip rollers (inside at bottom rear) are waxed and not gripping. Take a small drop of Isopropyl alcohol and wipe the surfaces clean, this usually works.
Oct 06, 2009 | Konica Minolta magicolor 2500W Laser...
Imaging Unit Missing on Konica Minolta Magicolor 3300 after paper jam?
Apr 02, 2009 | Minolta magicolor 3300 Laser Printer
My printer prints photos with a blue tinge to it.
Go ahead and get another toner
also run the printer cleaner a couple times
Feb 18, 2009 | Konica Minolta magicolor 2300DL Laser...
My Konica 2300DL is showing an error that reads AIDC Error and I cannot print anything
you may try bellow for your print trouble
1) clean laser lens cover using soft cloth,
2) perform an AIDC calibration cycle through the manu--- Engin/service/power on/test
reference user guide P81-82
Feb 01, 2009 | Konica Minolta magicolor 2300DL Laser...
Konica Minolta 5430DL error code 111112
I couldn't find the install disks so downloaded the driver from the Konica website, un-installed the software and re-installed it. After calibrating the colours everything seems fine now.
Oct 01, 2008 | Konica Minolta magicolor 5430 DL Laser...
Konica Minolta magicolor 2430DL
Open the top cover. Remove the drum (part with long green handle). Below the drum you will see a strip of glass about 4-5 inches long. Take a cloth and wipe across the glass.
This will normally clear up any white lines in your print.
Jul 11, 2008 | Konica Minolta magicolor 2430 DL Laser...
Konica minolta magicolor 5430 DL
pleas make color calibration from printer quality menu and try again
Apr 21, 2008 | Konica Minolta magicolor 5430 DL Laser...
Printing an A3 document on an A4 printer
Set your paper size to A3 - it should print out the docs on two seperate sheets of A4.
Oct 11, 2007 | Konica Minolta Magicolor 2450 Printer
Minolta Magicolor 3300 Color Printer Logo
98 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
CheckitRight
CheckitRight
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
