Question about Citizen Office Equipment & Supplies
Too many zeros on EL-510r calculator
Too many zero's when I turn it on. I only want the one zero to show.
SOURCE: Finding Rational Zeros of Polynomials on a Casio FX-115 Sci. Calc.
I'm not sure how to do x4,
but from -5x3 and on yes. Mode-5-4, and insert coefficients.
Here the solution:
1. 1.927
2. -0.413
3. -2.514
Posted on Dec 02, 2008
SOURCE: Casio calculator/printer won't print digits ending in zero
Unfortunately, I found there is no "solution." I called Casio and was told that there is no way to change that format on this model.
Posted on Jun 16, 2009
  • 8064 Answers
SOURCE: ten zeros when you start
The Fix sign on the top of the screen (smaller size) are indicators that calculator is using the FIXed format: All numbers are displayed with a fixed number of decimal digits (in you case it may have been set to 9 decimal digits). You can change that in the setup.
The Grad symbol means that the angle unit is set to grad. This too can be changed to degrees or radians in the set up.
A sure way to achieve mastery of calculator use is to learn how to configure it to fit the types of calculations to be performed.
Hope it helps.
Posted on Sep 20, 2009
  • 102366 Answers
SOURCE: When i turn on my HP 11c calculator a zero with a
You're in scientific notation. Press f FIX and a digit to get into a fixed decimal mode.
Posted on Jan 23, 2010
lbrown1806
  • 488 Answers
SOURCE: My calculator shows 0.00000000 instead
At the top left of the calculator, you will see a sliding switch that is labeled: DECIMAL A,0,2,4,6,F. Move the indicator to the "0". This will remove all excess zeros. The numbers represent how many decimal places the screen will show. I have the manual for this calculator if you need it. LBrown18062@hotmail.com
Posted on Jan 03, 2011
Turn off the fix mode
Press SETUP and choose 0 for FSE. Then choose 3 for Norm 1. This will put the calculator back to the original setting.
Mar 20, 2014 | Sharp el-531x scientific calculator
Have a sharp EL-506w calculator i have ten zeros on the screen it will do problems but it s a bunch of zeros behind it it aiso says x10 in small context at the far right side bottom of the screen.
Your calculator is set to display in scientific notation. To change it, press SETUP 1 then choose the desired mode. For most purposes you'll probably want Floating Point. For more details see the third column of the first page of the manual.
Oct 22, 2012 | Sharp Office Equipment & Supplies
My sharp el-506 advanced d a l calculator dispays 10 zeros, it will fuctio but how do i get rid of all these zeros
Oct 22, 2012 | Sharp EL-501WBBL Calculator
How do I set the decimal place on the calculator - cleaning crew moved it
Feb 28, 2011 | Sharp EL-2630P Calculator
Hi I have a EL-1197PIII. I have moved it from my
The "E" is an error indication. If you divide a number by zero that would cause it. But a reset should clear it. Also dead backup battery will cause it.
FIRST replace the backup battery in the unit. There is a small panel on the bottom to access it.
Then do the reset. There is a "poke hole" to reset it that should be marked. Refer to your manual which is also available for free download online.
Nov 05, 2009 | Sharp EL-1197P Calculator
EL 1801V - how to set time/date?
To change the date, enter the date in MM.DD.YY format, pressing the decimal key between the month and day (will show as a decimal on the display) and the day and year (will show as a dash on the display). Then, press the Time/Date key (the one that looks like a clock and a calendar). The new date will show on the display. Note that if the month is less than 10, you do need to press the 0 (zero) key for the first digit, even though it will not show on the display. To change the time, enter the time in 24-hour HH.MM format, pressing the decimal key between the hour and minute. Then, press the Time/Date key. The new time will show on the display. Note that if the hour is less than 10, you do need to press the 0 (zero) key for the first digit, even though it will not show on the display. Hope this helps! :)
Sep 02, 2008 | Sharp EL-1801P Calculator
A DOT AFTER THE ZERO
Hi - I think you have the "Grand Total" switch set. For normal operation set the switch to the central position as below:
Hi - You can download the manual from the link underlined in blue below:
EL-1801P
Please update the question & let us know if the information given was useful to you - Good Luck!
Jul 14, 2008 | Sharp EL-1801P Calculator
516 people viewed this question
Top Citizen Office Equipment & Supplies Experts
Tejodhar Atreya...
Tejodhar Atreya...
jay kaye
jay kaye
Are you a Citizen Office Equipment and Supply Expert? Answer questions, earn points and help others
