Question about Whirlpool GH7155XHS Microwave Oven
My whirlpool microwave humms even when i'm not using it
  • 2 more comments
  • shuewebb Jan 04, 2009
    I have had the microwave unplugged for hours at a time because of the annoying noise and fear of fire or further damage. I had a hint that it might be a bad diode after the capacitor making the transformer humm. The only thing is that they said that the microwave wouldn't heat and mine still does. Any thoughts?
  • shuewebb Jan 05, 2009
    You're right, the microwave heated a cup of water without setting the timer or pressing start. It also had a burning smell when I took the cup out after about 2 min. The model is a Whirlpool gh7155xkt-0 serial#fgl4501727. This is great! What should I do next? If it can help I am an electrician and can test components with your help. Thanks again.
  • William Miller
    William Miller May 11, 2010
    If you haven't done so already, I would suggest putting a cup of water inside to see if it's possibly heating when it's not supposed to.
    If it's running when it shouldn't, that would be caused by a problem on the controller or a door switch or mount, not the high voltage diode.
    Sorry, but I forgot to ask your full model number from the tag / label on the unit..
  • William Miller
    The
    first thing I would suggest is a hard reset. Unplug the unit for a
    minute or so. Then plug it back in, set the clock and try again.
    If that doesn't work,
    leave it unplugged for maybe an hour. Then let us know if the hard
    reset does not fix it.
    You may have a bad filter capacitor on the control circuit board.
    We
    regularly repair such control units for customers nationwide by mail
    for $39.95 postpaid in about a week with a one-year guarantee.
    Please reply back with
    your full model number from the tag so we can help you
    properly.
  • Whirlpool Master
  • 9,098 Answers
It's almost certainly a shorted cook relay on the control board.
The relay has two metal tabs on top where the wires are connected.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Be sure the oven is unplugged, then you can measure across the two tabs and I think you'll find the tabs are shorted.
A new board for this model runs over $150, but
we regularly repair such control units for customers nationwide by mail for $39.95 postpaid in about a week with a one-year guarantee.
Feel free to contact me directly (and please remind me of your full model number) for more information & help.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Posted on Jan 05, 2009
Why does my whirlpool microwave turntable won't stop turning even when not in use?
There could be a defect in the door latch interface or the control board.
Aug 20, 2016 | Whirlpool Microwave Ovens
Microwave is not heating and making a loud humm. the turntable is spinning though. What is out on it.
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
Oct 14, 2010 | GE XL1800 1100 Watts Microwave Oven
My microwave makes a loud humm when turned on and does not heat the food. If I put in another mode, Meat, it sounds normal but after a mmin it starts to make the same humm. ???
You most likely have a bad high voltage diode. (Item F1 of link but labeled rectifier)
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5154395
However... there are two other possibilties those being the High Voltage Capacitor (F2 of link above)
and the Magnetron istelf. (F7 of the link above)
More often than not the diode / rectifier is the problem.
Thanks for using FixYa.
Kelly
Mar 19, 2010 | Frigidaire PLMV169DC Microwave Oven
Not cooking food even though it comes on
Check the power setting. You can tell if it is on a lower setting because it will cycle ( you can hear it humm lower for a short time then the sound is different and then it humms the same again. It happens...it is new.
Sep 02, 2009 | Oster 0.7 Cu. Ft. Compact Microwave
No heat when Microoven is turn on. GE XL1800 Spacemaker
If there is a loud humm the magnatron tube has gone bad. and some times there is no humm at all but i would say its the mag tube has gone out.
Jun 13, 2009 | GE JVM1850 1000 Watts Microwave Oven
Microwave wont heat
Test the high voltage capacitor, the rectifier diode.or the magnetron.
If it additionally does not spin and no light, then check also the door switch.
The diode and capacitors can br tested. The capacitor must be allowed discharge before testing, or you risk to get electrocuted, even if power is off. Capacitors can get discharged by shorting their two contacts.
Replace the magnetron if the checks and all of the high voltage component tests are good, but the unit still does not heat.
All locations, and description of this parts can be located using the diagram here: Counter top.
Parts must be tested to find out what is wrong.
Remember that microwaves are potentially dangerous devices if not repaired properly, the job must be done by a competent person.
A microwave energy leakage test must always be performed when the oven is serviced for any reason.
Regarding parts, contact the seller here to purchase parts. (here in UK).
Apr 04, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
My whirlpool microwave oven humms
Yeah, that's fan which stuck in "on" state. However the root cause is in a control board.
Jan 25, 2018 | Whirlpool GH7155XHS Microwave Oven
Microwave no heat
The "HUMM" indicates a breakdown in the High Voltage Side. The loud "POP" was the breakdown. You have only four Components in the High Voltage side.
1. High Voltage Transformer. You can eliminate this as the problem. Why? If it was the problem it would have blown the line fuse, and would have given off a burned transformer smell.
2. High Voltage Diode. Usually will Burn or Pop when shorted, but will then OPEN the Circuit and there is no "HUMM".
3. High Voltage Capacitor.This is the Silver Can with the two terminals on top. It can SHORT internaly between the plates (the two terminals) and give the "HUMM".
4. Magnetron. This is my number one suspect. A SHORTED Magnetron.
Feb 03, 2008 | Kenmore 63652 Microwave Oven
Microwave not heating unless exhaust fan is on high
check the control unit and high voltage circuit, and megnetron, high voltage diodes, wiring and high voltage fuse etc.,
Sep 26, 2007 | Samsung MW1030WA Microwave Oven
Whirlpool GH7155XHS Microwave Oven Logo
122 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
