Question about Canon PowerShot S2 IS Digital Camera
Blurry pictures Hi...I use the camera for wildlife photography a lot. Mostly birds. I find that more often than not, the camera focuses on branches or leaves in front of or behind the bird instead of the bird itself. I've also had blurry pictures result when taken in bright sunshine where lighting wasn't an issue. Any ideas or suggestions? Thanks Jeanne
  • 1 more comment
  • Jeanne Hall May 14, 2007
    Thanks Jackboy. I've seen this method mentioned before, but it's often difficult to put into practice because of the location of the bird. What I don't understand is why the camera doesn't focus in the center of the green box.
  • Jeanne Hall May 17, 2007
    "You have to develop a technique of offsetting the image in the viewfinder to compensate"
    The most frustrating example was a baby owl sitting on a tree stump. The camera focused on the leaves behind the owl, I'm assuming because they were brighter. Would offsetting have fixed the problem? What exactly is offsetting?
    I'll give it a try. Thanks.
    Jeanne
    Genius:
  • 2,985 Answers
Try differential focus That is point to something near the distance you want- half depress the button -turn to subject complete the press down Bear in mind that if the subject is really close to the view finder is not looking where the focus window is-Parallax- learn to shift you frame slightly to allow for this.
Posted on May 13, 2007
  • john ash
    john ash May 17, 2007
    If you are close to the subject the focus element is looking at something other than the view fonder- it is called parallax
    A common problem with all non SLR photography
  • john ash
    Offsetting is best explain with an illustration- but I shall try with words.
    Look at the subject through the viewfinder to compose the shot.
    Now the focus window is a tiny window on the front of the camera, and to one side of the lens
    So check out where that is -The manual will tell you.
    If when looking through the finder the window is a few mm to the right, having composed the shot, move slight off to the left-thus replacing lens with focus window-
    Now half depress the release- the camera is now focussed on the subject- move back to check your composition and press.
    Practise makes perfect.
SOURCE:
Own DSLR camera would like to know the single best lens for the DSLR?
"Best" lens depends on several things:
1. What kind of pictures do you intend to take?
2. Do you mind a heavy leans? Some are 10 pounds or more.
3. Your budget.
The "standard kit lens" that most come with is perfectly good for general photography. If you want to take architectural pictures, you'll need something different. If you want wide landscapes, you will need a wide angle, and if you want wildlife/bird pictures, you'll want a telephoto lens. It all really depends on what you intend to do...
For example, I have a very wide lens I use for interior architectural pictures, medium telephoto for portraits, and a variety of long to very long telephotos for wildlife pictures...
Yes, there are some extreme zoom lenses that cover 'normal" to "very long" telephoto. They're expensive, not especially sharp, and very heavy. Everything is a compromise.
Dec 18, 2015 | Canon EOS Rebel G 35mm SLR Camera
My pics on my Canon rebel eos looked clear on my camera but when downloaded to the computer they are bluury. Lanscape photos are fine but wildlife is blurred.
First of all this is a digital camera, not a 35mm film camera, but it is the same fix... You need to use a faster shutter speed for your wildlife pictures. Or use a tripod, or both. The small screen on the camera is not big enough to tell if a photo is really sharp. Also check the way you have your autofocus set up, or focus manually to test a few closer shots. It may be that the auto focus is set to focus on a part of the picture which is not the bit you are interested in. There should be some indicators in the viewfinder to tell you where in the frame the camera is picking out to auto focus onto. Blurry can only be either out of focus or shake. (It could be both of course!)
Jan 08, 2011 | Canon EOS Rebel G 35mm SLR Camera
My Panasonic Lumix® DMC-ZS3 will not focus properly. All pictures are blurry. Anyone know what might be the problem?
Try checking your settings or menu for a vibration sensor or changing the focus. You might also be using the wrong setting, like indoor, when you're at the beach. You can also change the quality of the pictures and if you are taking still photography or movement.
May 31, 2010 | Panasonic Lumix DMC-ZS3 Digital Camera
Flash phtography....need advice
Some cameras have a problem focusing in lower light settings. If they don't have enough light to focus, the pictures will come out blurry almost every time. You can try a few things. Some cameras have a 1/2 way setting on the shutter button, that forces the camera to try to focus, and then a green indicator will come on the screen when it's ready to shoot. Another option is to set the camera to manual focus (if there are options for it). Another fix is to add more background lighting, to allow the camera to focus easier. I've heard a lot of people complaining about the same problem- it's pretty common with today's digital cameras.
Mar 15, 2010 | Casio Exilim EX-Z110 Digital Camera
Canon rebel xsi, using 75-300 lens, taking photos of basketball game, pictures are blurry, especially the ones in "action" using the sports mode. also tried my 18-55 IS lens, same thing happening, using...
That's a big lens and for sports photography you are going to need a lot of light to ensure you can use a fast shutter speed to capture the action. Sports mode may do too much for you and you might want to try switching to a more manual mode. Try switching to Tv mode which gives shutter speed priority. Set the shutter speed to something around 1/150 or higher (1/200) which should be fast enough to freeze the action. Make sure the ISO is set to 200 or 400 for best results and see how you get on. This should stop any action based blur which would leave you with focus problems if the pictures are still blurry. Check out http://www.dpreview.com/reviews/canoneos450d for info on what this camera can really do for you
Jul 28, 2009 | Canon EOS Rebel XSi Digital Camera
Virtual tour
the picture is blurry due to lack of focus in the lens.
Im using a fish eye lens. my f\stop is 6.3 shutter is 30.
Im trying to due a virtual tour of my kitchen so its a big picture that i want all in focus. i have tried different settings on my camera but i think im making it worse.
Feb 07, 2008 | Nikon D70s Body Only Digital Camera
Blurry or dark pictures in low light
Low light= slow shutter speed = camera shake
Use a tripod
Nov 04, 2007 | Kodak EasyShare Z740 Digital Camera
Blurry Images
The camera display is a two-stage progressive display. The image is roughed out, then the interleaving lines are filled in. This has no effect on the image itself, just the monitor display. Apart from the media, digital photography is the same as film photography, and subject to the same challenges and requires the same time-honored techniques. If your pictures are blurry, you may be shaking the camera. Practice holding the camera firmly to your eye, and squeeze (don't poke) the shutter release. If you are holding the camera at arms length to shoot - what can I say? You can also increase the ISO speed, so that the shutter speed is faster. You may not be focusing on the right area. Focus on the subject (line up the box in the viewfinder), particularly on the eyes, by pressing half-way on the shutter release. Holding, to lock the focus, re-point the camera to compose the picture before pressing the shutter release the rest of the way. Make sure you hold the shutter release and wait the 1/2 second or so for the exposure to complete (the 5700 is painfully slow), indicated by the "green" light in the eyepiece, before whipping the camera from your face.
Sep 19, 2005 | Nikon Coolpix 5700 Digital Camera
Why do my Fun! Digital 320 pictures come out blurry?
Blurry images can be caused by any or all of the following: * Distance/Focus range -- the Fun! Digital 320 has a fixed focus range of 3 - 6 feet (1.8 meters) for brightly lit indoor photography, 3 ft. (1 meter) - infinity for outdoor photography. For best results, make sure that the camera is at least 3 feet away from the subject(s) when taking pictures. * Camera/Subject movement -- This is a common cause of blurriness, especially in low-light situations (see Lighting below). Hold the camera as steadily as possible while taking a photo, or use a tripod (a tripod mount is located on the bottom of the camera). Avoid subjects that are in motion. * Insufficient lighting -- the Fun! Digital 320 is designed for taking photos outdoors or in brightly lit environments. Inadequate lighting can exaggerate camera movement and contribute to blurred, "muddied," or uncrisp images. * Lens condition -- Check the lens periodically for smudges. If necessary, wipe the lens clean with a soft, lint-free cloth. Do not use cleaning solutions or chemically treated tissues. * Enlarging images using software -- otherwise normal digital images can appear to become blurry and/or blotchy when over-enlarged in software. To see an image's "true" appearance, use the software's Zoom In or Zoom Out feature to view it at 100%.
Sep 14, 2005 | Polaroid PhotoMax Fun 320 Digital Camera
Canon PowerShot S2 IS Digital Camera Logo
140 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Doberman
sathish kumar
sathish kumar
Are you a Canon Camera Expert? Answer questions, earn points and help others
