Question about Electrolux UltraLux 2000 Bagged Canister Vacuum
Vacum won't ****
Electrolux vacume cleaner won't ****....i put in a new bag.. motor runs great. hose is not plugged
    Scholar:
  • 44 Answers
Do you have good suction right out of the canister without the hose attached? If so, AND your hose isn't plugged, you must have a pretty good sized hole somewhere in the hose. If you don't have suction at the canister, pull the filter cover off the top-back of the machine and remove the filter. This is where all of the air that the machine pulls in is exhausted. If something is plugged here, it will greatly reduce your suction. If you still haven't found the problem, you could have a problem with the fan assembly on the motor. But usually this is accompanied by some noise from the motor, but not always. Good Luck!!
Posted on Jan 03, 2009
Overheat light comes on vacume will not run
Let it sit for 30 minutes before trying to use again. Make sure the bag is not full and check to see if filter is clogged.
Oct 27, 2013 | Electrolux UltraLux 2000 Bagged Canister...
The vacum will run until the hose is inserted and then the motor shuts off. The vacum switch must be hooked up incorrectly. Do you have a schematic?
Before trying to take it apart, check the hose for a blockage. Disconnect the hose at both ends, drop a coin in one end, lift that end of hose allowing coin to drop through. If it doesn't come through, there's a clog. You should be able to clear it by plugging the hose into the exhaust port of the vacuum, holding the other end to the in port, and turning on.
Another possible problem is a dirty afterfilter. Remove the air diffuser/tool holder on the back of the vacuum. If the filter is dirty, it blocks the air flow and the vacuum will shut off due to overheating. Remove it, connect the hose, and turn on the vacuum.
If you don't have a manual, you can download it at the below site. Click on the space under "older models", click on Ambassador III, and download.
Information for removing the air diffuser is on page 9.
http://www.aerusvacuums.com/support/manuals/
Feb 13, 2011 | Electrolux C101 Bagged Canister Vacuum
Hi My Electrolux Oxygen Z5530 stopped working from one second to another. No lights - nothing - totally dead. What can I do? Is there any fuse? Sincerely Eva
I have same problem and I check it out.
The special requrement of Electrolux for his vacum cleaner motors is that they working with high reliably approx 800 hours working time and no more!!! (it should stop safe with no danger for users...)
7 years has past (2 h/week x 52 x 7 = 708 working hours) so it is time for us consumers to buy new vacum cleaner...
Jan 05, 2011 | Electrolux Vacuums
Is the style c the right bag. The vacum cleaner only runs about 5 seconds before it says the bag is full.
If you have a 6500, the C bag is the right one. Try turning the dial on top of the vac to the smallest dot and see if the machine will run properly.
If it is still doing the same thing, take it to your Aerus/Electrolux dealer for repair. The control valve assembly (full bag control) needs to be replaced and I don't recomend that you try the repair.
Joe
Nov 01, 2009 | Electrolux Epic 6500 Vacuum
I have a Electrolux Epic 6500 SR canister vacum cleaner. It is nine years old and for the past few weeks it has started shutting off for no apparent reason.The symbol for bag change lights up and it cuts...
Your machine is probably clogged, look through the wands, look in the bottom attachment, to see if there is anything stuck there. You can also drop a marble through the hose itself to see if anything is stuck there as well. To unclog the hose try holding the attachment end of the hose were you would normally plug the hose in. ( the goal is to **** the clog out the way it came in).
Aug 18, 2009 | Electrolux Harmony Canister Vacuum -...
Vacuum won't stay on
When you open the canister you eill see a little rubber hole that senses when your bag is full. This must be clogged. If you have another vac try to vacume all the dusr from this hole and any other opening inside the vacume that you can reach. I hope this helps. Don't forget to rate this answer.
Feb 07, 2009 | Electrolux Epic 6500 Vacuum
How do i go from dry vacuming to wet vacuming with the rigid shop vac
can I run my sears shop vac without the paper bag, for dry pickup?
Jan 29, 2009 | Ridgid 9 Gallon Wet/Dry Shop Vac 96882...
I HAVE A ELECTROLUX VACUM CLEANER WHICH IS A 1800w BUT ITS NOT SUCKING ANYMORE?
hello customer,
Suspect a tripped breaker, broken on/off switch, or a damaged cord if the motor won't run.
Step12Insure that you aren't running too many appliances on the circuit if the breaker continues tripping. If that's not the problem, you may have a short circuit in the power cord. Replace it immediately to avoid fire hazards. Step23Check to make sure the bag isn't full if you aren't getting much suction. Replace the bag if it's full. Step34Make sure the hose is properly connected to the machine and that there are no obstructions in the hose or fan. Step45Repair a cracked hose with duct tape. Prevent creased hoses by hanging them over two pegs on a closet wall. Step56Remove hair and strings that tend to get wrapped around the vacuum brush with a pair of small scissors. hope u find this useful.thank you.
Jul 09, 2008 | Electrolux Vacuums
Help me fix my LUX7000
Turn the dial down to its least sensitive setting and try that. If not you can call my office at 570-326-1731
Oct 20, 2007 | Electrolux Lux 7000 Bagged Canister Vacuum
Electrolux UltraLux 2000 Bagged Canister Vacuum Logo
159 people viewed this question
Top Electrolux Vacuums Experts
Chris Nomland
Chris Nomland
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
