Question about Poulan/Weed Eater No. Te475 952711797 17" Le Gas Trimmer/Edger
Need a Poulan ppb150e service manual
Where can I get a full service manual for a poulan pro ppb 150e
5 Suggested Answers
#1 Taper
  • 1040 Answers
SOURCE: This is a Poulan Pro Link model PPB 250E week
Take the casing off of trimmer and see if the one of the wires to the on/off switch is touching the engine.
Or it may even be a fuel line. If this is the case, look for damage to the fuel lines as well.
Jim
Posted on Jun 07, 2009
#1 Taper
  • 1040 Answers
SOURCE: I need to remove the head from my poulan pro ppb
After all the bolts have been removed from the head, tap all the way around,(http://www1.mscdirect.com/CGI/NNSRIT?PMPXNO=4760615&PMT4NO=65151144), where the head meets the bottom of the motor. It will come off with a little coaxing.
Jim
Posted on Jun 10, 2009
  • 4 Answers
SOURCE: Poulan Prolink PPB 330 starts easy, bogs down on high speed
poulan ppb 330 33cc trimmer .idles but no high speed power.
my solution was to remove postage size screen on muffler known as spark arrester and clean. runs great know !
Posted on Jul 02, 2010
rycgl
  • 1545 Answers
SOURCE: how to test a poulan pro 31cc ppb 250e gas string
The proper way to test it is with an ohm meter by doing a continuity test. If your switch isn't working on the machine, there is the possibility that the wire from it that connects to the coil module is loose or is off. I would check for that first and then do the continuity test if needed. The coil is under the front cover of the machine and will require disassembly to access where the black switch wire spade terminal is.
Posted on Oct 21, 2010
Poulan pro brushcutter ppb150e is starting but cutting off after a few minutes, why is this?
FAQ Trimmers ' Poulan Pro
www.poulanpro.com > Customer Support > FAQ
If the unit has an on/off switch, move it to the on position (usually indicated by the ... This should happen between 1-6 pulls, but no more than 6 pulls. 7. ... Some units use a carburetor which does not require holding the throttle trigger. ... If you smell fuel after following the starting procedure, assume the engine is flooded.
Poulan Pro Trimmer dies when I give it gas.? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
May 22, 2007 - If you remove the two springs holding that cover on the muffler off you can ... Put it all back together and you should be able to crank up and cut. ... Poulantimmer PPB 100 JUNK, since new hard to start cannot keep running ... If, it sit with fuel in the carb then it may still need cleaned with some Carb Spray.
[PDF]OM, PPB150E, 2007-01, TRIMMERS/EDGERS - Poulan
Nov 25, 2015 | Poulan Garden
My poulan prolink ppb 150e will not start how do i get it started
You must first have a starting place, check for fire and fuel and then ask additional questions.
Sep 28, 2014 | Garden
Gap coil on ppb 330 poulan pro
First and foremost ppb330 is a model number for a grass line trimmer, gas model.
Second, I am unsure what you are asking. Gap coil?? Do you need the spark plug gap for your chainsaw? That gap is .025.
I hope this helps. If not, please re-post with the correct model number for you chainsaw.
Jul 08, 2014 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
How to get the cutch off a poulan pro link ppb 200e
Their should be a nut their to remove the clutch.
Aug 18, 2013 | Poulan Garden
My Poulan Pro 150E pull cord will not engage to start the weed eater. The rope comes out adn retracts back with no problem, but there is no pressure on the clutch to cause the motor to start. There is...
Sounds like the starter dogs are broken. They are little plastic teeth that engage to turn the engine when you pull the cord. You'll need to replace the whole starter assembly to fix this.
Aug 26, 2011 | Poulan/Weed Eater No. Te475 952711797 17"...
RE: Need plug type and manual.
Remove the existing plug and check the number on the top plug housing. That's thge plug you need. Manuels are usually available for download at the manufacturers web site.
Mar 24, 2010 | Garden
Poulan ppb 250 weed eater, only runs with choke on,
HOW IS YOUR FUEL LINES. SOUNDS LIKE IT MAY HAVE A AIR LEAK
Sep 20, 2009 | Garden
Sep 04, 2009 | Poulan Weedeater/Electric Trimmer 4.1 Amp
Jim
Jun 07, 2009 | Poulan Garden
Poulan/Weed Eater No. Te475 952711797 17" Le Gas Trimmer/Edger Logo
80 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
