Question about Kyocera Mita KM-4035 Printer
Kyocera KM 4035 driver installation failed. I get message "one or more software installations have failed."
    New Friend:
I had the same problem "One or more software installations have failed", until I realised the Kyocera driver download was a zipfile, and I'd tried running setup from Windows explorer's extension (zipfile preview). When I unzip the file, then run setup, setup finds its supporting files and I no longer get the error. Doh!
Posted on Jun 02, 2013
leroyal
  • 2120 Answers
SOURCE: Kyocera Mita km-1820
Unplug the power cord for 10 seconds.
Posted on Jan 15, 2009
SOURCE: kyocera km-2050 scanning function
The km 2050 was on network, but moved to home and directly into tower system via usb interface connector. Printer works, but can not get scanner to work? read instructions without a clue. can someone help with correct proceedure?
Posted on Mar 12, 2009
n25an
  • 622 Answers
SOURCE: light copy on KM 4035, KM 2035 even the spare
if copies and printouts are the same then do the following... if only copies then change your scanner lamp
make sure you are using kyocera toner... empty developing unit and run sim mode 131.... make sure that you have changed the transfer assy.... thats the black roller on the door... also play with sim mode 101....
Posted on Dec 10, 2009
  • 903 Answers
SOURCE: we have a Kyocera FS3830N - message install MK -
MK is the maintenance kit. You can check the Kyocera site to find out where to get a new kit and how much they are:
http://usa.kyoceramita.com/americas/jsp/Kyocera/products_printers_details.jsp?pid=12331
Most of the time the message is just displayed because the machine has reached a certain number of pages, but it should still let you use it normally.
Posted on May 27, 2010
n25an
  • 622 Answers
SOURCE: I'm using Mac OS 10.5.6 and the Kyocera KM-3035
use the generic print driver in mac and tune it with this tutorial also set the press printer on the copier and set emulation to kpdl auto... also see if you can make the driver spool...
if that doesn't work... then try moving a zipped 10 mb file from one pc to another on your network... make sure one pc or laptop is connected where your copier is... if you open the zipped file and its corrupted... then the problem isn't your copier... its your network...
Posted on Dec 24, 2009
HOW DO I SOLVE ERROR 0610 IN KYOCERA KM 4035
repara la unidad fusora y luego hay que resetearla para que opere tu equipo no te pongas a jugar con las targetas que tiene la maquina o complicaras las cosas,espero que te sirva
Jul 20, 2016 | Kyocera Mita KM-4035 Printer
Driver copystar cs 4035
go to Kyocera website enter your model number and list of drivers will show even though you have a copystar machine its made by Kyocera so match your model number use km instead of cs
May 22, 2014 | Copystar CS-4035 Copier
I need to download windows 7 drivers for a kyocera cs 3035
windows xp drivers will work...
google the km 4035 windows 7 driver
but specify 64 bit or 32 bit...
Aug 13, 2011 | Kyocera Mita KM-4035 Printer
What type of corona wire is used on Kyocera products: FS-9520, KM-4035, KM-3530, and KM-C2520. Is it 60 Micron Oxidized?
The service manual does not specify but you will probably be ok with tungsten or oxidized. If the copies look bad with one try the other. The main charge is replaced as a whole charge assembly so I can't say that I have had to restring one.
Jul 13, 2011 | Kyocera CS-4035 Copier
Kyocera km 4035 always add toner
It sounds like you may have a bad toner.
May 20, 2011 | Kyocera Mita KM-4035 Printer
How do I install driver for Kyocera CS 5035 on MAC
Kyocera and Copystar models are the same just replace KM with CS.
The following instructions should help you. TO download the current driver use this link to th emanufacture website; http://usa.kyoceramita.com/americas/jsp/Kyocera/resource_details.jsp?rid=18657.
Kyocera Printer Drivers and Mac OS® X 10.5 Leopard FAQ:
Is the installation for Mac OS X 10.5 the same as for Mac OS X 10.4 and earlier? Mac OS X 10.5 introduced a new printing architecture that requires changes to the installer and installation process. For this reason, Mac OS X 10.5 requires a new printer driver installer.
I cannot see my Kyocera AppleTalk® printer. How can I make it visible to OS X 10.5? AppleTalk is disabled by default in Mac OS X 10.5. Enable AppleTalk to discover your Kyocera printer.If you use the Kyocera installer, a message will appear, asking you to enable AppleTalk. Click Yes to continue the installation.
I cannot find Printer Setup Utility on Mac OS X 10.5. Is it still supported? Apple has removed Printer Setup Utility from Mac OS X 10.5. To install a printer, open System Preferences and click Print & Fax.
When I manually install a printer, multiple PPD files are listed for the same Kyocera model. Which should I choose? When manually installing a printer or changing a PPD for a installed printer, both Linux and Mac OS X PPDs are listed for some older Kyocera models due to a change in PPD handling in Mac OS X 10.5. Linux PPDs can be identified by the word Gutenprint in the PPD filenames.
Supported Multifunction Printers: KM-1650, KM-1815, KM-1820, KM-2050 ,KM-2530 ,KM-2550, KM-3035, KM-3050, KM-3530, KM-4030, KM-4035, KM-4050, KM-4530, KM-5035, KM-5050, KM-5530, KM-6030, KM-6330, KM-7530, KM-8030, KM-C830, KM-C830D, KM-C850, KM-C850D, KM-C2520, KMC2525E, KM-C2630, KM-C3225, KM-C3225E, KM-C3232, KM-C3232E, KM-C4008, KM-C4035E, CS-1650, CS-1815, CS-1820, CS-2050,CS-C2525E, CS-2550, CS-6030, or newer. Supported Printers: FS-820, FS-920, FS-1018MFP, FS-1020D, FS-1030, FS-1100, FS-1118MFP, FS-1300D, FS-1800, FS-1800+, FS-1900, FS-1920, FS-3800, FS-3820N, FS-3830N, FS-6020, FS-6026, FS-9100DN, FS-9120DN, FS-9500DN, FS-9520DN, FS-C5016N, FS-C5020N, FS-C5030N, FS-C8008N, FS-C8026N, FS-C8100DN, or newer.
I hope this is helpful,
Shawn
Mar 08, 2011 | Kyocera Copystar CS-5035 Copier
How do I make my kyocera mita 4035 printer print without the need of pressing go
change paper size from printer properties maybe the paper size is LTR so you have to change it to A4
May 21, 2010 | Kyocera Mita KM-4035 Printer
Kyocera cs-c4035e driver for mac 10.5.8 platform have older driver which works but won't give me color
You can copy and paste any of these links into your address bar to bring you to the driver download site:
www.nodevice.com/driver/KM-4035/get35425.html
driverscollection.com/?H=KM-4035&By=Kyocera...5
www.opendrivers.com/driver/.../kyocera-km-4035-twain-source-driver-v1.10.1-windows-os-free-download.html
Aug 24, 2009 | Office Equipment & Supplies
Light copy on KM 4035, KM 2035 even the spare parts inside was new.
May 14, 2009 | Kyocera Mita KM-4035 Printer
Kyocera-Mita going offline
Try an updated driver from the manufacturer or see if they have any know issues with 2003 sp2 and the driver.
Hope this helps!
Nov 27, 2007 | Kyocera Mita KM-5035 Printer
Kyocera Mita KM-4035 Printer Logo
282 people viewed this question
Top Kyocera Mita Office Equipment & Supplies Experts
Kyocera HP Expert
Adorjani Laszlo
AAAA262430
Are you a Kyocera Mita Office Equipment and Supply Expert? Answer questions, earn points and help others
