Question about Farmall Cub Tractor Radiator
Hydraulic fluid filler plug location for farmall cub for load lift
4 Suggested Answers
  • 218 Answers
SOURCE: changing the oil
Hi there..my name is Keith and i restore tractors....and to answer your question..a Farmall Cub hold 3 quarts of oil..i hope this has helped
Posted on Jul 01, 2009
  • 6 Answers
SOURCE: what kind of hydraulic fluid can i use in my
universal hydraulic fluid is all we use it is used for the transmission and the hydraulics, about 25 bucks for 2.5 gallons, put in at the gear shift until it comes out plug below cluch pedal. Check any cenex gas station .
Posted on Jan 06, 2010
  • 18 Answers
SOURCE: where are hydraulic fluid drain
1 plug under pto 1smaller plug under tractor on front of transmission 1plugunder clutch housing total of3
Posted on Mar 20, 2011
How do i change hydraulic fluid on my farmall 450
Below the steering column on the bottom side of the resivory tank is a four bolt cover about two inch square. Remove. This is the drain and the hydraulic filter screen.
May 06, 2016 | Diesel Farmall Tractor 400,450 Gas & ...
My hydraulic lift for my 149 cub cadet will not lift when the snow plow is attached.
Try checking the fluid, it may be low. Or the seals in the cylinders may be leaking and bypassing so you can't build up pressure.
Jan 31, 2015 | Cub Cadet Garden
Where are hydraulic fluid drain plugs located on farmall 560
Jan 25, 2011 | Farmall IH Tractor 460, 560, 660, 2606...
To remove 1993 mustang conv. top cylinders should top be up or down? thanks, bill
don't have 93. here's 94
Motor Assembly, Convertible Top Removal and Installation
NOTE: The folding top hydraulic cylinder rods should be in the fully retracted position.
Use absorbent rags or a container to catch any hydraulic fluid that leaks out when removing the fittings.
  1. Remove motor and pump assembly as outlined.
  1. Loosen each folding top motor upper and lower hose fitting on the sides of the folding top hydraulic lift motor and plate kit (533A00) .
  1. Remove the folding top hydraulic lift motor and plate kit .
  1. Remove each of the service folding top hydraulic lift motor and plate kit plugs one at a time and attach the tee fitting to the replacement folding top hydraulic lift motor and plate kit . NOTE: Make sure that the o-ring is installed in the bottom of each folding top hydraulic lift motor and plate kit port before attaching the hose tee fitting.
  1. Connect the folding top hydraulic lift motor and plate kit unit to a 12-volt power source and cycle the folding top hydraulic lift motor and plate kit in and out several times to purge the air from the folding top motor upper and lower hoses (53390) . Some noise squeal may be noticed due to the air. srb~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Do not overfill or the reservoir seal could be blown out.
  1. Carefully remove the rubber fill plug from the back and the reservoir and check the fluid level. The level should be at the bottom of the filler hole. If necessary, add Synthetic MerconĀ® Multi-Purpose Automatic transmission fluid E6AZ-19582-B (ESR-M2C163-A2) or equivalent.
  1. Replace the fill plug with a new fill plug.
  1. To install, reverse Removal procedure.
Section 01-17: Convertible 1994 Mustang. Workshop Manual
REMOVAL AND INSTALLATION Lift Cylinder, Power Top Removal and Installation
NOTE: The cylinder rods should be in the fully-retracted position.
  1. Remove pump and motor as outlined.
  1. Remove the upper and lower hose fitting from the folding top hydraulic cylinder (50600) . Use absorbent rags or a container to catch any hydraulic fluid that leaks out when removing the fittings.
  1. Remove each of the service cylinder plugs one at a time and attach the hose fittings. NOTE: Be sure each fitting is installed in the correct position on the folding top hydraulic cylinder .
    NOTE: Make sure that the tetra seal is installed in the bottom of each of the folding top hydraulic cylinder ports before attaching the upper and lower hose fittings.
  1. Connect the folding top hydraulic lift motor and plate kit (533A00) to a 12-volt power source and cycle the folding top hydraulic lift motor and plate kit in and out several times to purge the air from the hoses. Some noise squeal may be noticed due to the air.
Jan 21, 2011 | Ford Mustang Cars & Trucks
Farmall 560 hydrolics wont work on the bucket
i am not sure but check the levers and the inside of the lever control movements.
Apr 28, 2010 | Farmall IH Tractor 460, 560, 660, 2606...
Where is the rear end fill and level holes on a Farmall 400 Diesel?
Just check you hydraulic and transmission fluid levels,the rear end is lubed with hydraulic oil that is supplied by one or the others oil reservoir.
Mar 21, 2010 | Diesel Farmall Tractor 400,450 Gas & ...
What kind of hydraulic fluid can i use in my farmall 460 that is affordable
Oct 09, 2009 | Farmall IH Tractor 460, 560, 660, 2606...
Hydraulic Fluid Level (Checking and Filling)
hello darrell. yes you just unscrew the plug and fill it full.
Apr 15, 2009 | Toys
Convertible top
here's some info
Symptom Chart Condition Possible Source Action
  • Folding Top Does Not Raise and/or Lower
  • Blown fuse(s).
  • Circuitry open/shorted.
  • Damaged folding top switch.
  • Damaged raise/lower relay .
  • Damaged folding top hydraulic lift motor and plate kit .
  • Parking brake not engaged.
  • Go to Pinpoint Test A.
  • Top Hesitates and/or Comes Up Uneven
  • Damaged folding top motor upper and lower hose .
  • Damaged folding top hydraulic cylinder .
  • Damaged folding top linkage.
  • Go to Pinpoint Test B.
  • Top Does Not Raise or Does Not Go All the Way Up
  • Go to Pinpoint Test C.
  • Hydraulic System
  • Damaged fluid reservoir.
  • Go to Pinpoint Test D.
  1. Carefully remove the rubber fill plug from the back and the reservoir and check the fluid level. The level should be at the bottom of the filler hole. If necessary, add Synthetic Mercon® Multi-Purpose Automatic transmission fluid E6AZ-19582-B (ESR-M2C163-A2) or equivalent.
Jan 04, 2009 | 1989 Ford Mustang
Farmall Cub Tractor Radiator Logo
101 people viewed this question
Top Farmall Garden Experts
Dennis Key
Dennis Key
john h
Colin Stickland
Colin Stickland
Are you a Farmall Garden Expert? Answer questions, earn points and help others
