My charger port is starting to not work
Well lately my charger has started to play up i have to hold my charger in a straight postion overwise it doesnt charge
    Novelist:
    Champion:
  • 233 Answers
Obviously, your laptop dc jack is loose. You should repair it or replace it. If you are good at repairing computer, you can follow up the following instructions to do it by yourself:
http://www.chargerbuy.com/blog/dc-power-jack-repair-guide-do-it-yourself-instructions/
Posted on Oct 29, 2012
Fix it Out
  • 90 Answers
SOURCE: dell inspiron want charge nor start up
Since when the problem arised, is it under warranty? Either the connector or terminal worn out. It need to be replaced. Let me know if the Laptop bootup or not.
Posted on Oct 05, 2008
  • 5 Answers
SOURCE: battery not holding charge and now charger not
Just replace your charger and battery. It will solve your prob as soon as possible.
Posted on Oct 23, 2009
  • 115 Answers
SOURCE: my laptop works but the battery doesnt charge.
YES.
DO NOT USE IT, UNPLUG THE CHARGER, GET UR LAPTOP SHOWN TO A REPAIR SHOP OR IF IN WARRANTY TO UR VENDOR.
IF U KEEP THE CHARGER CABLE PLUGGED THEN IT MITE LEAD TO MOTHERBOARD FAILURE OR SUM OTHER BURNS.
Posted on Nov 01, 2009
  • 2567 Answers
SOURCE: we just bought this acer
First of all, you need to make sure your power adapter is providing enough power to both run the laptop & charge the battery. A very good way to do this is to compare your laptop voltage & ampere requirements (written on a sticker on the bottom of the laptop) with the voltage & ampere ratings of the power adapter. Voltages should be the same, or the power adapter's voltage about up to 0.5 volts more than the laptop's voltage rating. Amperage of the power adapter should be at least equal to or greater than the laptop's rating. It should never be less than the laptop's rating, or else the power adapter will be providing insufficient amperes to charge the battery. Of course, the power adapter's nominal amperage might be ok, but it degraded on usage. You can verify this by testing using a good or new power adapter.
If the battery did not charge using the new power adapter, take the battery off the laptop, & using a dry tooth brush, scrub in between the fins of the battery connector on the motherboard & on the battery it self, then put the battery back into the laptop & try again.
If this still did not resolve the problem, then the battery itself could be bad. Try it on another laptop, or try a good or new battery in your laptop.
If this did not work, there might be a possibility that the charging circuitry on the laptop's motherboard is defective & needs servicing. In order to do this, the laptop needs to be disassembled & the motherboard checked for defective/burned out components in the area near the DC jack. Any defective/burned out components found should be replaced, or you might need to replace the laptop's motherboard altogether.
Posted on Oct 07, 2010
  • 1087 Answers
SOURCE: My Advent 5431 wont charge unless I hold in the
http://www.laptopjacks.com/products.php?gclid=CLu2laTuw6oCFcPBKgodmAxO7g
Posted on Aug 10, 2011
2007 Honda crv 2.2 diesel,difficult to start after being left a few days.
When cranking it seems like no diesel getting through. If I tow it down the road it will start almost straight away. AmanStino QUICK CHARGER 3 0 USB charger Multi Port Intelligent USB Wall...
Nov 30, 2016 | 2007 Honda CR-V
I need a 6 ports charger, what can I do?
If you need a 6 ports charger then you can visit this site because to know all the information about this 6 ports charger. So why are you late.
http://www.amazon.co.uk/dp/B00MGJAXC8/
Sep 07, 2014 | Audio Players & Recorders
My galaxy 3 phone will not charge properly how do i fix it
Charging issues is a process of elimination. First the charger....many chargers will fit but not all that fit will work. A bluetooth charger will fit but would never charge your battery completely. Make sure you are using a proper charger. 2nd is the charging port on the phone. If the charger is loose it could be a bad port or the prongs on the charger are not holding....is it loose? Or if there is corrosion on the port. If corrosion, clean with alcohol and tooth brush. 3rd is the battery. If its swollen, then it's toast. A li-on battery will start to decrease after 400 to 500 charges.
Jun 18, 2014 | Samsung Galaxy S 4G Cell Phone
1993 suzuki sidekick, when I turn on the engine nothing happens, I can jump start it and it works. some times it works fine when I turn it on but lately more often it's not doing anything. I tried jumper...
This sounds like a bad starter, it has dead spots and when it lands on one sometimes the jump starting will make it start due to extra power, check to be sure the battery is good then make sure the battery connections are good and if all of that looks good then its got to be the starter, you will need to test it, a testlight will be needed to do this, you will need someone to hold the key in the crank postion and you will use the test light to check for power at the starter, there are to cable going to starter a big one and a small one. the big cable that connects to the starter comes from the battery and has power at all times, then theres a small wire, this is the wire you check, you will see it bolts or slides onto connector on the back of the starter, with key in the crank postion test for power at the small wire if theres power then the starter is bad, good luck, hope this helps.johnjohn2_83.jpg
Mar 19, 2011 | 1993 Suzuki Sidekick
Code 0700 with 1391 stand to what
P0700 its a transmission codefrom what i understand while the 1391 is a crank postion sensor. the P0700 comes up when the neutral safety switch starts to fail, but the crank postion sensor...to get that error code, means you timing could be off..have you replaced a timing belt lately, if so, it might be a couple of teeth out, that might do it. i would check the sensor too though
Jul 11, 2009 | 2002 Jeep Liberty
My usbkeyboard is not working and I can't logon
If this is the first time you have installed this USB keyboard or its recently changed USB ports all you need to do is wait till the machine is at the login prompt remove the keyboard and put it back in and wait. It will install the driver in the background. If after 10 minutes the keyboard is still not working it may be faulty. If this keyboard has changed ports lately and it won't detect try changing to the other ports one by one and restarting. When its plugged into the port is was in before it should start working straight away.
May 07, 2009 | Acer Aspire T690 (AST690UP820A) PC...
Flashing lights on Rince, Start & 0 speed.
washer think there water over fill to clear this u need ruin a diagnostic test. think of timer knob light a clock straight up being at 12 oclock an one click at 1oclock to enter the test first rotate knob to any postion except postion 6 staight down press start and fs button at same time wait 3 seconds an rotate knob to to postion 6 wait 3 second then release both button , all light should blink . you should now be in test , rotate knob to various postion to test wash cycle an rinse an spin postion 9 an 10 are the waster valve onces the test finish tun the knob to another postion to turn test off an unplug washer an plug bach in this should clear it . if still have a porblem call a applince service ok
Dec 13, 2017 | Whirlpool AWM6120 Front Load Washer
Wont play
have you tryed pressing play for 5 seconds.....
Dec 26, 2007 | Coby MP-C582 MP3 Player
Problem with xbox 360
I'm not sure if you've sorted this already but the 360 will go straight to the dashboard if you have it set up to start that way, you can set the console to automatically run games by going into the 'system' blade of the dashboard and choosing 'start up'.
Hope this helps (although may be a little late)
Please rate if at all useful, thanks!
Nov 05, 2007 | Microsoft Xbox 360 Console
Computers & Internet Logo
47 people viewed this question
David Payne
David Payne
