Question about Car Audio & Video
Circuit breaker on the back of my B600H amplifier trips when you turn it on
Comes on for a few seconds then trips out the circuit breakers on the back, the signal clip light also illuminates for a few seconds...no sound at all
catriver
  • 878 Answers
SOURCE: Dishwasher tripping the circuit breaker
Andy, leave the breaker off and remove the toe panel (bottom panel) from the dishwasher. Remove the cover of the junction box where the cord connection or wiring is made. Look at the wire caps and see if they are not burnt. Sometimes these connections become loose and arch, tripping the breaker. If so, cut the wires, strip a new end and reconnect. Catriver...post back.
Posted on Aug 21, 2006
likha
  • 790 Answers
SOURCE: the led of protection is on in my amplifier z1000d
maybe you have defective speaker! try to cut out your speaker from the amplifier then you power on again! if the protection is in again you have defective power output! transistors or mosfet transistors.
Posted on Sep 27, 2007
SOURCE: fuses
If you connect the fuses in parallel yes. You can use 12v circuit breakers as long as they are the same fast/medium/slow blow speed as the fuses the manufacturer recommends.
Thing is that most standard fuses are not made to exact standards and one of the two might blow earlier than the other which then in turn wil blow. I would go for either a 40 amp single fuse made for something other than a car situation and place that in the power line or get a 12v circuit breaker
Posted on Jan 12, 2008
Jimster
  • 240 Answers
SOURCE: whirlpool electric dryer keeps tripping main circuit breaker
First off, be sure the pigtail is wired correctly to the back of the unit. Black and red to the outside terminals, white to the middle, green to the frame or cabinet (should be a green screw close-by). If that is ok, you probably have an issue with possibly a bad pigtail, bad outlet, wiring issue, or possibly a bad circuit breaker or breaker box. Probably going to be more of a electrical problem than a appliance problem. Good Luck!!!!
Posted on Feb 02, 2008
SOURCE: LG washing machine trips GFI Circuit Breaker
WASHING MACHINES ARE NOT TO BE CONNECTED TO GFI OUTLETS AND TRY TO CONNECT IT TO A CERCIUT THAT IS NOT WITH YOUR DRYER. (REG) OUTLET.
Posted on Jan 31, 2009
How to reset a cutler hammer HMCP E Breaker
Well, you should first - stand off to the side (not in front of any electrical panel, or device) when re-energizing a circuit breaker/switch, etc... Use your off hand, not your dominant hand when doing this. Reason is, if the breaker/switch blows up or out - and it happens to burn your hand (hopefully not...) - you will still have your good hand to work and get around with. Also, look away when doing this too - which will protect your eyes and face. This is why you DON'T stand in front of these electrical devices when turning them ON. Now, stand off to the side of this breaker/switch - look away, and using your less dominant hand - first turn the breaker/switch OFF (listen and feel for it to click in the OFF position)...then, turn the breaker/switch back ON. This should re-energize the breaker! If it trips again, then leave it in the TRIP position - and ask for further help. You'll need an experienced electrician to troubleshoot the problem. On this particular breaker - the two 40amp breakers are together, and the two 30amp breakers on the outside are together. When turning these OFF, and back ON...turn the two 40amp breakers OFF together, then back ON - and do the same to the two outside 30amp breakers as well. What you have here is what they call a Quad Breaker (4poles/circuits - which take up two spots in your electrical panel). So, you have a 2 pole/circuit...240 volt/40amp breaker - inside of a; 2 pole/circuit...240 volt/30amp breaker. This is most likely running a dryer and a range. Either way, SAFETY FIRST! I hope your problem is just a tripped circuit breaker! Also, make sure whatever you are trying to re-energize again - is ALL OFF!!! If your breaker trips again, disconnect ALL appliances involved - and then try it one more time! If it trips again, then call a licensed/certified electrician! Best of Luck to You...:)
Jul 13, 2014 | Cutler Hammer Bq Circuit Breaker Bq230240...
Breaker installed on generator. Keeps tripping under no load after approx. 1 minute of generator running
A tripping circuit breaker is an indication of an overload. You say there is no load on the breaker - how are you making this determination? Are you using an amprobe or some other meter?
A circuit breaker with NO load shouldn't ever trip. Likewise a circuit breaker carrying up to 80% of of the current it is rated for shouldn't trip either. Circuit breakers that carry more than 80% of their load will trip - if the load remains connected long enough. This is called "duty factor" or "service factor" The greater the load is in excess of 80%, the less time that the breaker will carry it before tripping.
An example of a 100 amp breaker with different loads on it (this 100 amp value was chosen for ease of doing the math):
80 amps - never trips
85 amps - trips after 48 hours
90 amps - trips after 16 hours
95 amps - trips after 8 hours
100 amps - trips after 4 hours
105 amps - trips after a few minutes
120 amps - trips after a few seconds
150 amps - trips instantly
This is only an example to show how a certain circuit breaker might trip under a load less than the rating stamped on the body or handle.
A circuit breaker that trips with no load or a load equal to or less than 80% of its rating is most likely defective. You need an amprobe or ammeter for amp readings. If the load is found to be 80% or less, there may be an issue of harmonics that is causing the tripping. You'll need to have special equipment and qualified persons to check harmonic problems. Most harmonic problems occur when the loads are not linear device (transformers). Examples of non-linear devices are "switching" (or solid state) power supplies like those in computers.
I hope this helps and good luck. Please rate my reply. Thank you.
Apr 07, 2011 | GE Tjk436f000 3pole 400a 600vac Circuit...
My crown 602 xls tripped a breaker, I reset breaker regained power to receptacle , I lost power to the amp no led's come on front when i pushed the small reset button on the back I still did not regain...
They use a breaker instead of a fuse.
http://www.retrevo.com/support/Crown-XLS-602-Amps-manual/id/19050ci763/t/2/
CONDITION: No
power to the amplifier.
POSSIBLE REASON:
• The amplifier's Power switch is off.
• The amplifier is not plugged into the power receptacle.
• The amplifier's high-voltage power supply circuit breaker has tripped. Verify that the AC mains
voltage is correct, then press the Circuit Breaker button on the back panel.
Take it to the ER.
Jan 12, 2011 | Crown XLS 602 2-Channel Amplifier
Malibu Lighting Breaker Switch
There are two possible problems you could be facing (excluding the transformer going bad) If you have replaced light bulbs with higher wattage ones, you could be drawing too much current through the transformer. (It is common for MR-16 style lightbulbs to be 20w in landscape lights, but 50w for inside lights, and the local hardware store usually only carries the 50w replacement lamps) Each transformer has a specific amount of "watts" it can supply (anywhere from 100w to 1000w) If you exceed the supply wattage of the transformer, the breaker inside the transformer will trip. The quick and easy way to test this is to take a few of the lightbulbs out and see if the breaker will hold.
If you are positive that the total lamp wattage does not exceed the rating of the transformer the second possible problem (but less likely) is that you have a lamp socket or wire connection that is full of water. This water between the two conductors draws current just like a light bulb and can cause an overcurrent fault. This is usually more common if it starts to trip right after a heavy rain when the ground gets saturated with water.
Good Luck!
Jan 20, 2010 | Malibu Intermatic Inc. ML121RT Low...
Trips on power up
It has a short circuit on the final steps of the outputs, maybe the common called "final transistors or power amplification IC (integrated Circuits)"are blown. You don't have the ability to resolve this problem, so take the unit to a facility authorized repair.
Dec 29, 2009 | Behringer EUROPOWER EP2500 Amplifier
20amp breaker tripped unexpectly tonight. tried resetting at panel but won't click all the way over and little red indicator also on the breaker
Hello, In order to reset circuit breakers that have tripped under load, you must first flip the breaker all the way OFF, before you can then turn the breaker back ON. This should reset the breaker to turn the power back on to the circuit supplied by this breaker.
The red indicator is just there to make it easier to find the tripped breaker. Typically, the red indicator flag is a special feature of Square D QD breakers and panels.
If the breaker immediately trips again and doesn't stay on, then the device it is providing power to, still has a fault and it needs to be looked at to determine what is causing the fault and the tripping of the breaker.
Be sure to turn the breaker OFF if you are going to check the device for potential problems.
I hope you find this Very Helpful and best regards!
Nov 13, 2009 | General Electric 20amp 2-pole GFI circuit...
Two 15 amp arc fault breakers installed on two adjacent circuits. One works fine - does not trip. The afi breaker beside it trips as soon as it is flipped on. We tried switching circuits, but both circuits...
It's possible that the first breaker that you said does not trip - it could be that breaker is failing to trip on a bad circuit. That is, it could be you have a bad circuit but that first breaker is not detecting it and pretends everything is OK. If your new breaker trips on the first breaker's circuit, the curcuit it probably bad and the breaker in not working properly. The most common problem for failed circuits is a stray ground wire in a box somewhere in the curcuit resting against a hot or neutral wire. You'll have to take apart every connection on that curcuit to find it. Not fun.
Jun 14, 2009 | Siemens 20Amp 1-pole arc-fault circuit...
The past Few days the microwave would trip the breaker. today I went to use it and it worked for 30 seconds when I checked what I was heating and turned it bakc on and it would not work
Microwaves that are either built in, a part of the oven, or over the range are on a dedicated circuit by law. This means nothing else could have tripped that breaker but the microwave.
If it has a problem severe enough to trip a 20 amp breaker several times, it is only getting worse each time you reset the breaker and turn it on.
There is a possible chance of fire. I recommend you turn the circuit breaker off and replace the microwave. Is it a plug in, or over the range type?
May 18, 2009 | Microwave Ovens
Circuit breaker trips when turning unit on. only unit on circuit has triped on several circuits can find no shorts on wiring.
DOES IT BLOW THE BRAKER AS SOON AS IT TURNS ON OR DOES IT TAKE A FEW SECONDS. INSTANTLY WOULD MORE LIKELY BE A SHORT IF FEW SECONDS THE COMPRESSOR IS PROBABLY DRAWING MORE AMPS THAN THE BREAKER CAN HANDLE SO IT BLOWS. TRY TAPPING THE COMPRESSOR NEXT TIME YOU ATTEMPT A HOUSE CURRENT START UP. i HAVE A WINDOW AIR CONDITIONER THAT NEEDS TAPPED FOR STARTUP FOR THE SUMMER SEASON. GOOD LUCK
May 01, 2009 | Dometic RM2852 Refrigerator
Car Audio & Video Logo
26 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
