Question about Bosch 11236VS Rotary Hammer
Remove the chuck on a 11236vs - Bosch 11236VS Rotary Hammer
2 Suggested Answers
comax
  • 154 Answers
SOURCE: The chuck has been pulled off. Whats the easiest
The chucks on the 11236 are designed to be removed, if you were not aware of this it may look like the tool has failed, it has not. To replace the chuck set the chuck back on the shaft of the tool, grip the outer collar of the chuck and rotate it counterclockwise while pushing down .The chuck will drop into a set of grooves on the shaft and lock there, give it a wiggle after to make sure its seated. Sometimes it takes a couple of tries to get it. To remove it just grip the collar turn counterclockwise and pull up, the chuck will come off.
Posted on Jan 07, 2011
The bit wont lock in the drill, how do i fix this problem
This is a very easy fix - you have a quick change chuck on this tool. Turn the chuck counter-clockwise and pull it straight off - the new one goes on the same way. Quick Change Bit Chuck
May 23, 2014 | Bosch 11236VS Rotary Hammer
HOW DO I PUT THE QUICK RELEASE CHUCK ON A BOSCH HAMMER 11236VS?
I don't know that drill in detail but in general chucks for this type of machine are removed by pulling back the plastic ring behind the chuck and pulling the chuck out. So hold the drill with the chuck facing away fron you and grip the plastic ring behind the chuck (nearest you). Pull this toward you and pull the chuck away from you. Replacing a chuck is the reverse.
Jan 04, 2011 | Bosch Drills
The chuck has been pulled off. Whats the easiest way to reinstall it on my Bosch 11236vs Hammer Drill?
Nov 22, 2010 | Bosch 11236VS Rotary Hammer
Bit will not lock into chuck. Ball inside chuck is stuck in "in" position, Bit slides all the way in and out w/o engaging the ball.
Open locking sleeve, clean the inside with a good "rust type cleaner" WD40 if you can't find anything else, let it sit overnight, I suggest doing this 2 or 3 times, leave tool with drill end facing down. Clean out with small round wire brush, lubricate with white grease.
Oct 08, 2010 | Bosch 11236VS Rotary Hammer
Roto hammer works but leaks oil out the chuck
If you are getting leakage out the chuck end, the shaft seal needs replaced. You can get it done at a Bosch service center or get the seal and replace it yourself. Don't wait to long there is only a limited amount of lubricant in the tool.
Jul 27, 2010 | Bosch 11236VS Rotary Hammer
How do we get the chuck to stay on, has 4 ball bearings and slots but won"t stay in place.
You twist the chuck counter clock wise while pushing down on it. It will not go on if you rotate it clockwise. Must be COUNTER CLOCKWISE. If this doesn't work then the bit sleeve in the chuck is worn too much and needs repalced. You remove the chuck by rotating counter clockwise and pulling up on it.
Jul 08, 2010 | Bosch 11236VS Rotary Hammer
BIT FALLS OUT/ WON'T TURN
try pulling the chuck back at the same time turning the bit while installing it should drop into place release the chuck,then make sure the lever just in front of the trigger is switched over to the rite side to use the hammer action.hope this helps
Jun 20, 2009 | Bosch 11236VS Rotary Hammer
Chuck came off of drill on a Bosch 11236VS hammer drill
Have you pulled the collar to release the pressure on the steel balls. Just pull the collar usually forward and slide on the shaft and then release and twist till it locks. Let me know if I can help further
Jan 07, 2009 | Bosch 11236VS Rotary Hammer
Chuck
Probably just the ball come adrift or worn. Depends on teh age of the drill. If you pry the end cap off the tool holder and remove the chuck sleeve you should be able to see the spring lock mechanism. There should be a ball held in place by a dished washer. The ball can come out and get lost so check that. If this is the case it should be very cheap to buy a new ball, and easy to replace. Just remember to lay the parts out in the order you remove them so it easier to re-assmemble them properly. If the ball has jsut dislodged and not fdallen out you should be able to refit it but may need to repalce the chuck as it in this case it is probably worn.
Nov 01, 2008 | Bosch 11236VS Rotary Hammer
Bosch 11236VS Rotary Hammer Logo
66 people viewed this question
Top Bosch Drills Experts
Matt Olenzek
Matt Olenzek
woodzowl307
Are you a Bosch Drill Expert? Answer questions, earn points and help others
