Question about Nikon D80 Digital Camera with 18-135mm Lens
Nikon D80 Black and White setting
Is there any benefit in shooting on the B&W setting rather than just desaturating colour images on the computer? I know B&W film has much better exposure tolerance than colour film but doubt if the same applies to digital capture.
  • 37 Answers
No, the B&W mode just saves time if you know you want it and is a "feature". You'll have far more control by taking in color (especially if using RAW) and then desaturating. With digital cameras the sensor is the same whether shooting color or using B&W mode...but the B&W mode is just discarding much of the information.
Posted on Jan 03, 2009
I have D80, in my display when viewing photo's any white colors are flashing from black to white. Any solutions?
You're seeing blown-out highlights. These are areas where you've irrevocably lost data due to overexposure. If too much of the picture is blown out, you may want to reduce exposure some and shoot again to preserve the data.
You can press up or down on the multiselector to change your view. The camera provides several different views of your images, including data, histogram, and, as you've discovered, highlights.
Feb 03, 2010 | Nikon D80 Digital Camera
I just got my new Nikon D80 but cannot get the LCD screen to light up. Where do I find the setting or the LCD screen to have it on while shooting pictures?
The D80 does not use the LCD screen to take images. The screen is only used to review images and use the menu system to check or change camera settings. When shooting, you need to use the viewfinder above the screen.
Nov 15, 2009 | Nikon D80 Digital Camera with 18-135mm...
Nikon D80 red and green streaking
check on the shutter speed and also the Aperture priority..
Jul 27, 2009 | Nikon SLR D80 Digital SLR Camera Digital...
Blue corners when shooting in BULB
With the same exposure settings, you should get the same result. When using Bulb in Manual mode, you also need to be sure you have set the lens aperture to the largest opening (lowest number). And don't forget to set ISO to 1600. Since the D80 has shutter speeds as long as 30" (minutes) I recommend you use them instead of Bulb, unless you need longer.
The blue areas are heat noise from long exposure -- other electronic components near the sensor are generating heat from the constant current flow. Be sure you check your Shooting Menu settings to set Long Exposure NR to ON and also High ISO NR to HIGH.
Apr 02, 2009 | Nikon D80 Digital Camera with 18-135mm...
Black & White shots from Nikon D80
You would be better off shooting in regular mode and converting to B&W using photoshop
Jan 03, 2009 | Nikon Speedlight SB-22S TTL Flash
D80 with nikkor 18-200, no picture
raatl, You mean the LCD on the back of the camera right?  The image that shows up (playback) can have the duration changed in the menu settings, it may have been turned off which is a choice as well that mode (not having the LCD on) extends shooting time which used to be a problem with the earl D70 and the earlier battery type.  The D80 doesn't have that issue, try experimenting with how much time you really need to have the display on, if you shoot and like to show the image to people set it longer or just hit the playback a couple of times as you are showing people.
randy320sgi
Dec 20, 2008 | Nikon D80 Digital Camera with 18-135mm...
How do i change a Nikon D70 to black and white
The Nikon D70 does not have a black-and-white mode setting.
However, you can take your photo in color and then use software to convert it to a grayscale photo. (Black and white implies an image with only those two values per pixel; grayscale can have 8 to 16 bits per pixel.) Most photo editing packages have a "desaturate" feature that does an automated conversion to grayscale.
The open source image editor Gimp has a "channel mixer" dialog that would allow you to approximate the effect of various filters before performing the desaturate function. This would allow you to experiment with the procedures if you do not have a commercial photo editor like Adobe PhotoShop. There is a special wrapper of Gimp that puts its interface into a configuration like that of PhotoShop; look for "GimpShop". The open source image manipulation package ImageMagick may also be used if you prefer working with command line utilities.
Sep 25, 2008 | Nikon Cameras
Nikon d80 camera
While in playback mode press up or down on the 4-way controller to toggle between highlights, shooting info, custom settings, histogram, or none.
May 18, 2008 | Nikon D80 Digital Camera with 18-135mm...
Nikon D80 Prints
Have you had the picture printed at a local photo lab. Try that and see if it's your computer/printer matching.
You may have to see if the Camera is set for Adobe RGB (or RGB) and your computer/printer is set for Adobe RGB or sRGB. These need to match. There's a new world with color matching that the point and shoot don't do.
Hope this helps. I could regurgitate all about Color Matching, but why when someone else has it all written out.
Nov 09, 2007 | Nikon D80 Digital Camera with 18-135mm...
Nikon D80 Digital Camera with 18-135mm Lens Logo
162 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
