I often use the flame lights without using the heater, depending on the room temperature. Now recently, the flame lamps go out, but I can still hear the motor running. At one time I was able to toggle the main switch and the lamps would come back on. However, this no longer seems to work. Is there an electric lamp module that controls this circuitry? Or are there sensors near the heater that should be cleaned?
SOURCE: remote control working with fireplace.
try www.dimplex.com go to customer sevices they should be able put you on to a local dealer in your area
hope this is of some help
SOURCE: My on switch is lit up red all the time
Hell Yes, my electric bill was 200.00 ave. a month last yr
SOURCE: Dimplex SHB20 Sherbourne Electric Stove -Flame Effect not working
Call Dimplex : 1-800-668-6663 ext: 358 they are kind and very helpful, they will send you arts to repair.
SOURCE: Dimplex Compact Electric Flame Stove Heater
call Dimples !-800-663-6663 ext 358 They will be able to help you out.
SOURCE: Dimplex Convector Heater EPX1000 turns off by itself
I have the same problem with 3 of the 5 EPX1000s I have fitted in my flat, although mine don't even warm up. They just immediately turn themselves off. My only conclusion is that they are rubbish. Specifically, the so-called overheat protection doesn't work. Avoid.
