Question about Maytag 24 in. MDBH955AW Built-in Dishwasher
My maytag dishwasher MDBH955AWB won't start. The control panel lights up when selecting wash cycles and options, but not when selecting start/cancel/delay. Any suggestions?
  • becklee20 Jan 09, 2009
    I have a similar problem with the Maytag MDBH955AWQ Dishwasher. My prolem is that the control panel is out of control. Intermitantly lihgts up to rinse only, then will only do that. I found if I wait for that light to go out, Then it will operate. Also by disconnecting the power seems to (sometimes) resets the Control Panel.
gwshaw71
  • 83 Answers
SOURCE: maytag dishwasher MDBTT60AWW
if you can select different cycles such as rinse only and that light up and then if you change it to normal cycle and it light up,then that tells me you touch pad is working,Check your door switches if those are good and your touch pad is responding, i would replace cpu board.If you remove the kick plate there should be a tech sheet there you can put unit into diagnostic mode with a certain key dance if your touch pad is responding.
Posted on Nov 25, 2007
SOURCE: Control panel lights OK; Won't start into cycles
Hey, just had the same problem with my 9150. Moisture got into the electronic key pad. $300 to replace it. I was 5 months out of warranty.
I called 800-688-9900 and Maytag agreed to cover the part and we have to cover the labor. Not completely satisfied but a little bit helps.
Posted on Jan 16, 2008
catriver
  • 878 Answers
SOURCE: Maytag diswasher problem
liberty, it sounds like your keypad is bad, here is your tech sheet for your dishwasher, it will give you detailed instructions for checking it out. Catriver
http://www.servicematters.com/maytag_library/docs/16026393.pdf
Posted on Jan 18, 2008
SOURCE: blinking lights on kenmore 665
key pad need to be change
Posted on May 09, 2008
  • 58 Answers
SOURCE: Contol panel not working
do all your buttons work on the panel? if not, replace the user interface, if they do, replace the main control.
Posted on Jun 25, 2009
MAYTAG DISHWASHER MDB7749AWQ2 CONTROL PANEL WONT START
You will need to replace the control panel, about a $200 part.
Jun 27, 2017 | Maytag Washing Machines
Reset button maytag dishwasher
  • 1 Open and close the dooricon1.png of your Maytag dishwasher.
  • 2 Locate the "Rinse" button on the dishwasher control panel. Press and release the button five times in quickicon1.png succession.
  • 3 Press and release the adjacent "Drain/Off" button on the control panel two times; this will deactivate the dishwasher's demo mode and reset your dishwasher.
  • If you need to restart your dishwasher or forgot some dishes and want to open it during a cycle and restart it
  • 1 Press the "Cancel Drain" button on the display. Allow about 2 minutes for the dishwasher to completely drain.
  • 2 Choose a cycle under "Cycles" on the panel.
  • 3 Select an option or options under "Options" on the panel.
  • 4 Push the "Start Resume" button.
  • Oct 24, 2013 | Dishwashers
    Maytag mdb7749awb1 won't start
    Thank you very much after doing the normal heated dry three times all the lights on the panel lit up and my dishwasher started running
    Aug 18, 2012 | Dishwashers
    Maytag MDB4651AWS Dishwasher will not start.
    Do you ever hear the fill solenoid click on to begin the filling. That is the first thing that has to occur. The water supply generally connects right to that solenoid. Ohm out the solenoid coil. ( breaker power off)
    May 21, 2012 | Maytag Dishwashers
    I changed the handel and switch assembly on my dishwasher because the old one was broke.The dishwasher does not turn on. It still doesn't work. it doesnt even light up. although one button does glow a...
    check for line voltage at the door switches and from there to the control board thats to the right of the door latch switches for line voltage,if you have line voltages in all these areas then replace the front membrane push button control panel that connects to the control board
    Jan 31, 2011 | Maytag MDB9600A Jetclean II Built-in...
    Flashing lights on Maytag dishwasher
    Check whether the door is getting closed fully. Try pushing little hard. If the door close switch problem it may work.
    Contact service for help if u can not proceed further with electrical circuits. Micro-controller board to be checked!
    May 18, 2010 | Dishwashers
    Maytag Quiet Series 200 dishwasher doesn't start
    The electronic control panel has gotten wet and needs to be replaced (about $200 for parts plus about $200 for service call/labor) I just had mine replaced about 10 month ago, stopped using the type of dishwasher soap I had based on Maytag Service staff recommendation, stopped using hot wash to prevent high condensation at the door and now its broken again and in need of a new control panel again. You may be money ahead to go buy a new dishwasher that does not have the plastic encased control panel at the top. My understanding is the control panels are poorly engineered and made for most dishwasher manufactures by one of the mega electronic/appliance companies.
    Dec 05, 2009 | Maytag EPIC MFW9700S Front Load Washer
    Water is not coming into my Maytag dishwasher.
    Is the door open or unlatched?Make sure the door is completely closed and latched. On models with a dual-digit display, the control displays "- -" during a cycle if the door is not latched. Check for obstructions (spoons or utensils), that may be interfering with the door operation. A lower dish rack that is installed backward will also cause incomplete door closure. The lights for cycles selected will flash if the door is opened while running a cycle.
    Is there power to the dishwasher?Check your household electrical box to see if a fuse has blown or if the circuit breaker has tripped. If the unit has a plug-in power cord, make sure it is plugged in.
    Does your dishwasher have a rotary timer knob?The cycle selection must match the position of the timer knob. Turn the timer knob to the beginning of the preferred cycle. The timer knob should click when you reach the start of the cycle.
    Is the control lock option activated?
    The indicator light next to the lock graphic will illuminate when the controls are locked. Press and hold the Heated Dry option (button with lock icon) for three seconds and the light should turn off. Instructions are also placed on the label on top of the inner door to unlock the controls.
    Is the delay start option activated?To cancel the delay and cycle, press Start/Cancel twice.
    Is the water shutoff valve turned on?Make sure that the water shutoff valve is turned on.
    Mar 03, 2009 | Maytag 24 in. MDB6600A Jetclean II...
    Maytag 24 in. MDBH955AW Built-in Dishwasher Logo
    331 people viewed this question
    Top Maytag Dishwashers Experts
    Charles T Nevin
    Charles T Nevin
    Mike
    Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
