Question about Nordic Track Nordictrack EXP3000 Console
Nordic track exp3000, the console is powered (lights up) but the motor doesn't run, when I push keys in console I can hear a chime
When I push any button in the concole I can hear a chime......
SOURCE: Buttons doesn't work...
you more than likely need a new keypad
www.AtlantaFitnessRepair.com
Posted on Aug 24, 2009
  • 18 Answers
SOURCE: Nordic Track exp 2000I. Consol lights, buttons do not work.
If the console lights up but the buttons don't work, then unfortunately it's probably the console and they're not repairable that I know of. You may want to check the wiring harness and the connections at the console and at the controller under the motor hood. Pull them apart and check for bent pins. If they look good, the console is most likely bad.
Posted on Mar 10, 2010
maxtreadmill
  • 832 Answers
SOURCE: nordic track exp 1000 treadmill console
Sound like function pad or upper console I don't know if you can purchase the function pad, but you may have to purchase the entire console and that may quite expensive.
  • For questions about parts, service, user's manuals or non-working products, please call our NordicTrack Customer Service Department at 1-877-993-7999.
  • For questions about parts, service, user's manuals or non-working products, if you purchased your equipment at Sears, please call our NordicTrack Sears Customer Service Department at 1-888-825-2588.
Posted on Apr 21, 2010
ercupa190
  • 12223 Answers
SOURCE: BUYER BEWARE!! I purchased
Watch this video:
http://www.youtube.com/watch?v=E-q-uS4t6so
1. Power
o 1
Ensure that the treadmill is plugged into a grounded outlet using the correct surge suppressor. Use a UL 1449 suppressor listed as a transient voltage surge suppressor (TVSS). It must be rated for 15 amps and 120 volts AC. Secure the services of an electrician if the outlet is not grounded, or move the Proform treadmill near a grounded outlet. Do not use an extension cord.
o 2
Insert the safety key fully into the display. Treadmills with keys are designed not to turn on without the safety key in place.
o 3
Find the circuit breaker on the front of the frame and make sure it is not tripped. The circuit breaker is a vertical switch on the 540S and a horizontal switch on the 540 Interactive Trainer. Press it to the "Reset" position, which will be labeled.
2. Reed Switch
o 1
Unplug the treadmill and remove the safety key.
o 2
Move the upright base of the treadmill down with the help of another person and lift the uprights so that you can get to the underside of the console. Use a Phillips screwdriver with at least a 5-inch shaft to remove the screws. There are five hood screws on the 540 Interactive trainer and four screws on the 540S.
o 3
Remove the motor hood to get to the small reed switch by pivoting the hood off the frame. Find the reed switch and magnet, which are on the left side of the pulley for both models.
o 4
Turn the pulley with your hand until the reed switch aligns with the magnet. There should be 1/8-inch gap between the two. Fix the distance so that it is 1/8 inch by loosening the reed switch screw and sliding it to the correct distance. Tighten the screw.
o 5
Reverse the directions to put the hood back on and the treadmill upright in the original position.
Check too:Optical Sensor. If have it
Posted on Nov 08, 2011
ercupa190
  • 12223 Answers
SOURCE: Nordic Track EXP 1000XI belt not working.
1) lube the deck belt,according the maintenance routing
2) lube the rollers bearing
3) measure the input voltage motor, if there are the motor need repair
4) measure the output voltage board, if there are NOT the board is faulty.see the block
God bless you
Posted on Jun 20, 2012
I HAVE A NORDIC TRACK E 3500 WITH AN INCLINE PROBLEM WHERE BY IT DOSEN'T RESPOND TO THE REQUIRED LEVEL .I'VE TRIED TO RESET MANY TIMES WITH NO SUCCESS .IT SEEMS TO CHANGE THE ACTIONS ON...
1)Lube the shaft, gear from elevation motor see the picture
2) adjust the POT a little.
3) see the diagram attached.
4) RUN the software calibration go under the hood motor and see the instructions for troubleshooting, and fix it.
God bless you
Nov 11, 2012 | Nordic Track NordicTrack Professional...
How to troubleshoot Nordic Track X7i Console not turning on
In normal operation you put in the key and display should light up. Also there is a reset switch on the frame near the power chord which might be off. Below is link to the User Manual for NordicTrack x7i. I got that info on pg 16.
http://www.sportsmith.net/images/product_support%5CNordicTrack%5C248194%20-%20NORDICTRACK%20INCLN%20TRAINER%20X7I%20INTERA%20TREADMILL%5CNTL20909.3-299073.pdf
Jun 19, 2012 | Nordic Track Incline Trainer X7i...
My nordic track treadmill 8600 has controller error08 and belt does not move
Dear Sir:
Please run the software calibration that coming with your equipment, see the instructin under the Hood motor, and follow the steps. or user manuals.This will guide your for diagnose and troubleshooting.
See the attached block diagram for troubleshooting and diagnose that I did prepare for customers.sincerely.
God bless you.
ernesto cuadra
managua, nicaragua. c.a.
Feb 13, 2012 | Nordic Track NordicTrack Treadmill, A2550
My treadmill (nordic Track EXP3000) was working until I took the ''key'' out which turned it off as expected. Upon replacing the key nothing works... Some lights come on but you can't start it you can't...
In some cases what happens the internal switch that your key engages to start your treadmill breaks free from its bracket. Try this press the Stop and the Speed Up keys down while inserting the safety key.
Press the Stop key one time. The Time window should read EP:2P. Some newer models may also say FP, Pass, or the like. This means that it passes the EPROM test.
You will be able to determine whether you can get in to this calibration mode if the key switch actually working and also at the same time it test the upper console to make sure its functional.
May 15, 2010 | Exercise & Fitness
Mar 04, 2010 | Nordic Track Nordictrack Apex 4100i...
Nordic track c2255 console displays FF and will not do anything
Hold down the speed up button and the stop button while inserting the operator key,if a bunch of numbers come up hit stop once, if nothing changed the console is bad.If the numbers change pull the key and reinsert it again, if nothing changes the console is bad.Also there usually is a tech sheet and test mode guide on the inside of the motor cover if you remove the screws and take the motor cover off you will see a white paper with lots of info.
Jul 25, 2009 | Nordic Track Exercise & Fitness
Nordic Track Treadmill will not run
If console lights up but doesnt respond when buttons are pressed, you more than likely have a console problem. Key pad issue would be my best guess.
Jun 08, 2009 | Exercise & Fitness
Nordic Track Ifit Treadmill has power but walking pad not working
If everything on the display console is working correctly then we know it is either a problem with the wires from the console to the controller or the controller itself. In most cases this means you need a new controller. To verify, take off the motor hood and find the green circuit board called the motor controller. With the power on go into manual mode and push the speed up button to a slow speed. If you see an LED light with "spd ctrl" next to it flickering but the belt still does not move then we know the problem is with the controller sending the signal to the walking belt, in which you should check the wires that go to the motor. If they are connected correctly then we know a new controller is in order. If you do not see a flickering light then it means the speed signal never got there and the problem will be with the wires going from the console to the controller. This is called an upright wire harness.
Apr 18, 2009 | Nordic Track NordicTrack Treadmill, A2550
Nordic Track Nordictrack EXP3000 Console Logo
Top Nordic Track Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Electro Med Services...
Paul Sikkema
Paul Sikkema
Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
