Question about Konica Minolta DiMAGE Z5 Digital Camera
My Konica Minolta Dimage z5 won't play back photos
I get "system error' and the camera shuts off when I try & review photos I've taken.
This never happened before but I haven't used the camera in awhile. It was inside, not in cold or hot temperatures.
What's wrong?
  • Sandista May 18, 2009
    System error keeps appearing when I turn on my camera. I am unable to view pictures or take pictures as the camera automatically turns off within secondsof the error message. Any ideas?
  • Anonymous May 24, 2009
    I have the same problem. I've tried using 2 different memory cards and it doesn't make any difference.
What size memory card are you using? I have had this problem trying to use a a 4gb card, which apparently is not compatible with the Z5. Using a 2gb card seems to alleviate the problem.
Posted on Jun 03, 2009
I can't get rid of Error message on my Konica Minolta Z5 : SD card seems blocked, even after reformatting, because some pix may have been rotated 90 degrees ???
The Z5 can display photos that it took. However, it cannot display edited photos. Due to the way the JPEG standard is defined, a rotation of the picture constitutes editing. If you rotate it four times, or once and then undo, it still constitutes editing. If you open a picture and then save it without doing anything else, it still counts as editing. Thus, if you want to put pictures back onto the card, you'll have to use the original pictures.
The proper workflow is to download the pictures to your computer. Then, if you're going to do any work on any of these pictures, do it on copies. This way, if you totally mess up an edit, you'll still have the original.
Feb 01, 2012 | Konica Minolta DiMAGE Z5 Digital Camera
Tip
I have almost identical issue with a Dimage Z5 (Konica/Minolta). I have had the...
Many digital cameras (eg Samsung D53, Nikon 2100) have extremely poor battery life with alkaline batteries (under 20 shots!). Sometimes they won't even take a single picture.
Try using rechargeable batteries or "oxyride" disposable batteries. They perform infinately better.
on Dec 01, 2007 | Samsung Digimax D53 Digital Camera
I require the driver for Vista O/S for the Konica Minolta DiMAGE Z5 Digital Camera.
You don't need a driver.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa ( http://picasa.google.com ).
Jul 12, 2011 | Konica Minolta DiMAGE Z5 Digital Camera
My Konica Minolta Dimage z5 won't play back photos. I get "system error' and the camera shuts off when I try & review photos
After calling Sony and doing all the things they said to do, that I had already done, they then said to send it in for repair to the tune of a minimum 175.00. So I had this brainstorm. I put the memory card back into my computer and formatted it from the computer. It worked for me, so try it, maybe it wil work for you.
Apr 13, 2010 | Konica Minolta DiMAGE Z5 Digital Camera
Konica Minolta Dimage Z2 camera will not read any SD card
hi there
you don't say how big the card is, my guess is its bigger than 2 gig which is the maximum allowable size for that camera.
hope this helps
beergut707
Oct 20, 2008 | Konica Minolta DiMAGE Z2 Digital Camera
Konica Minolta DiMage Z5
The odds are you have a broken spring in the anti-shake assembly which has allowed the lens unit to shift to one side. The smudge you are seeing is the edge of the lens housing and will have a slight rounded shape. As you zoom in, you are extending the lens past this area so it no longer shows.
Feb 28, 2008 | Konica Minolta DiMAGE Z5 Digital Camera
Can not review photos taken
First try new batteries. But, if your lens has been damaged (dropped it or maybe got sand in it) it will react like that. It is going to need service.
Sep 08, 2007 | Konica Minolta DiMAGE X60 Digital Camera
KM DiMAGE Z5
Try using a different Memory Card.
Then try takeing the batteries out overnight to let the camera reset.
Otherwise I dont have good news options. Sounds like It would be something internal that wouldnt be cost affective to fix.
Hope its the Memory Card,
Caleb
Mar 25, 2007 | Konica Minolta DiMAGE Z10 Digital Camera
What print size can the DiMAGE Z5 provide at maximum?
Approximately up to B3-size (43.3 x 32.5cm) is available when printing at 150dpi.You can print on up to B5-size (21.7 x 16.3cm) for photo-quality at 300dpi.
Sep 13, 2005 | Konica Minolta DiMAGE Z5 Digital Camera
Konica Minolta DiMAGE Z5 Digital Camera Logo
370 people viewed this question
Top Konica Minolta Cameras Experts
Greg Cann
Greg Cann
Willem.
Willem.
Are you a Konica Minolta Camera Expert? Answer questions, earn points and help others
