Please help me, need to open it!!!!!!!!!
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Step
Thanks
Testimonial: "But, i mean, i have to hold the source key up to open it? But how do i suppose to open without it?"
SOURCE: nokia N80 "phone lock code"
Hi have you tried 0000 thats usually the code that is stored when phone is new failing that you will need to get a flash lead and nokia softtware that scans the phone and gives you all the codes allowing you to change them but this is expensive to buy.
I have alot of nokia software but not sure if it works through usb lead as i use from computer then into black box then into phone as i have this as it works on all makes an model of phone if it can be done through the usb lead i can tell you where you can get this software from ok just give us a shout back
SOURCE: Please Help Phone code N73
When you enter wrong code for more than 5 times your mobile gets locked,so if you enter master code/unlock code also your mobile will not get unlock.....
Solution :just switch off your mobile ,start it after 15 minutes and enter the unlock code i have given below i.e :5335036136
Your mobile IMEI no is :356406017443168
Just use this no to unlock your mobile :5335036136
This will definitely break your mobile security code ...........enjoy
Please let me know your feed-back.
Thanks
dilipbagdi
Technical Associate
SOURCE: Forgotten My Phone Lock Code
hi
you can call the company of the sim card that you have and ask for instructions.
i hope this will work :-)
SOURCE: need unlock code for nokia 2600c security code
What is your IMEI number? i will generate a master code for you.
SOURCE: i just reset my e71 cox i forgot my lock code n
this doesn't work for the E71 (BB5) - any other solution?
